Question about HP Laserjet Printer P2035 P2055 Laser Scanner Rm1-6424
PRINTER 2055 COUNTINUES INITIALIZATION - HP Laserjet Printer P2035 P2055 Laser Scanner Rm1-6424
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 66 Answers
Problem With Logic Card.
Posted on Jan 02, 2013
Cannot connect to network. It show IP address 0.0.0.0
contact your service provide for assistance on how to set it up
Apr 28, 2015 | HP LaserJet P2015n Printer
How to fix error printer 2055 laser jet has massege output bin is full
there is a small flag sensor in the output tray over the roller that deliver the printed paper , its not return down after paper get out. so the the printer scene the tray is full , check it may lost if not try to lubricate the support pour it hasn't spring it move to its weight. or it may
Nov 12, 2014 | HP laserjet 2055 series 500 sheet paper...
Laserjet 2055 install black cartridge error
hello for all my dear the problem in hp lj 2055 install black cartridge error massege here the solve iam engineer in hp service center and i meet that problem in my daily work the problem in dc control must t replaced sure 100%
May 30, 2012 | HP P2055DN LaserJet Monochrome Printer
How can I perform an NVRAM initialization with my HP CM1015 MFP
CAUTION NVRAM initialization will erase all network settings. Before performing NVRAM
initialization, print a Network Configuration page, which contains network-setting information.
NVRAM initialization performs the following actions:
? Resets all customer-accessible menu settings via control panel and software back to the factory
default settings
? Resets the language to the value set at the factory
? Resets the default media size to cold reset media size
? Resets the symbol set to PC-8
NOTE The following steps reset the same NVRAM locations that are reset using the
Restore Defaults option in the control panel Service menu. The following process should be
used if the MFP does not come to a Ready state and an NVRAM initialization is desired.
Use the following procedure to perform an NVRAM initialization.
1. Turn off the printer.
2. Press and hold the Right arrow and Cancel buttons simultaneously.
3. Turn on the printer.
4. When you see the message Permanent storage init, release the Right arrow and Cancel buttons.
When the NVRAM init is complete, the printer returns to the Ready state.
Aug 02, 2011 | HP LaserJet CM1015 MFP All-In-One Printer
HP 2055 printer displays 10.1000 memory error.
install the printer driver and then reinstall the printer driver. This problem may occur due to the reason the the printer driver might not installed properly
May 31, 2011 | Office Equipment & Supplies
Can you tell me what error code 124-315 means on Xerox Docucentre-II 2055 ? and what the recommended fix is. (Multifuncton printer). Thanks, Gajj
hi
regarding your error go to following link
http://www.copytechnet.com/forums/xerox/36062-xerox-docucentre-ii-2055-error-016-315-a.html
Jul 24, 2010 | Office Equipment & Supplies
Had a problem with HP Photosmart C5180 All in One says cartridge cannot be used after initialization. Cannot find telephone number to ring HP in Ireland for support. This happens every time. I just had a...
Introductory cartridges come with the printer and carry special ink formulations intended for printer initialization. During initialization, inks in the introductory cartridges mix with inks in the printer to create a normal ink formulation. After initialization, introductory cartridges can be used in any compatible printer. However, if introductory cartridges that have not been through initialization are installed in a printer that has already been initialized, the printer cannot print
If the issue persists, perform these steps
try the cleaning steps advised in this link...
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00709715&cc=us&lc=en&dlc=en&product=1153481
Remvoe all Cartridges, disconnect the printer from the computer and connect it to the direct wall outlet and Reset your Printer to initial factory default settings:-
* Remove the power cord from the back of the product.
* Press and hold down the OK and Help buttons at the same time.
* While still holding the buttons down, plug the power cord into the back of the product.
If the issue persists, perform these steps.
1. With machine powered on, unplug power cord from back of printer and wait for 30 seconds.
2. While holding down the "ok" and "?" buttons, plug the power cord back into the printer.
3. Let the Printer power up again and give it time to go through all of its process.
Sep 22, 2009 | HP Photosmart C5180 All-In-One InkJet...
Hp designjet 1050c printer displays a system error
Printhead failure this is.
Turn the printer on.
Following initialization,
use the Down Arrow key to scroll to the Ink system menu icon and press Enter.
NOTE:If the error code appears during initialization press the Enter
key to allow printer to complete the rest of the initialization process.
Scroll to Replace Printheads and press Enter.
The printer should now move the carriage to an accessible position.
Open the top cover.
Remove all four printheads.
Turn the printer off using the main power switch located on the back of the printer.
Following initialization, insert one printhead at a time, starting with the black printhead.
Determine whether or not the printer accepts the printhead.
Turn the printer off and repeat steps for each of the printhead.
Replace the failed printhead.
Hope this helps
Regards
Apr 17, 2009 | HP DesignJet 1050c InkJet Printer
HP Laserjet Printer P2035 P2055 Laser Scanner Rm1-6424 Logo
195 people viewed this question
Seeker5211
Seeker5211
