Question about Sewing Machines
I keep getting an E 1 - Sewing Machines
Put down pressure foot
Posted on Jan 19, 2009
Found the manuel which told me I just needed to put my pressure foot down. It worked!
Irregular stitch length in machine sewing
1. Lengthen your stitch length
2. Use your even feed foot (walking foot attachment)
Nov 30, 2012 | Sewing Machines
My juki serger keeps getting stuck in the needle down position even without thread! Something is keeping it down?
it sounds like the machine needs to be checked at a sewing
machine shop to see what the problem is for sure
May 30, 2012 | Sewing Machines
#1 thread keeps coming out on the 3/4 thread kenmore serger. How do I fix this problem?
try rethreading the needle & keeping thread tails of at least 4 to 6 inches that you can keep pulled behind the needles
May 03, 2012 | Kenmore Sewing Machines
Cannot get the tension right and the thread keeps braking
Good day!
please try this simple tips:
Good day!
A sewing machine operator can often help themselves when their machine does not operate properly.
Here are some simple instructions, which if properly used can save time and mechanics service calls.
TROUBLE;UPPER THREAD KEEPS BREAKING;
This could be trouble;================Do this;
1.Top tension to tight================loosen tension 1 turn
2.Machine improperly threaded=========check threading
3.Thread twisted on guide post========"
4.Thread twisted out of tension======="
5.Take up spring bent or broken=======Check action of spring
6.Thread jumped off pull off finger===Check threading
7.Needle bent or burred===============new needle
8.Bad cone of thread==================try another cone
TROUBLE;LOWER THREAD KEEPS BREAKING;
1.Bobbin tensionspring to tight=======Loosen tension slightly
2.Bobbin threaded wrong===============check threading
3.Bobbin wound to tight or uneven=====try new bobbin
4.lint or thread on bobbin case=======clean inside case
5.Lint or thread inside hook==========clean inside hook
6.Bobbin case nicked bent or burred===check/change case
TROUBLE;MACHINE STARTED SKIPPING STITCHES;
1.Needle bent or burred===============change
2.Needle set in crooked===============Check
3.Thread jumped off take up spring====check threading
4.Thread jumped off pull off finger===check threading
TROUBLE STITCHES SHOWING LOOPS;
1.Forming loops on top of cloth=======Tighten bobbin tension
======================================or loosen top tension.
2.forming loops on bottom of cloth====Tighten top tension
3.Bobbin placed in case incorrectly===remove and replace
4.Bobbin thread slipped from under====check threading of
tension===============================bobbin case
5.Lint or thread in top tension=======clean between tension discs
Thank you and good luck.
Jun 05, 2011 | Singer Inspiration 4206
Thread keeps breaking, can't seem to get the
1. Maybe you are using the wrong size machine needle or poor quality thread.
2. You must always lift the presser foot before threading the machine to release the tension discs.
3. Maybe you have broken thread stuck in the discs or bobbin race. Give them a clean. Pull a thicker thread by hand through the tension discs when the presser foot is up.
Jun 01, 2011 | White Sewing Sewing Machines
Huskvarna Viking quilters 850 I keep getting
it is a problem your tech can fix, ( should have been done when he had the covers off) but take it back in and tell him to adjust the sensor on the cutter so it doesn't rub and to clean the sensor. this will fix the problem
Oct 20, 2009 | Husqvarna Viking 1
I keep receiving the E-1 error that the thread is
Don't use Singer needles, go to where ever you buy your fabric and get a pack of Shmetz Universal needles, it will cost you $2.50 or something like that.
Also don't use cotton thread for a while, the sensors are very sensative when the machine is "breaking in", so use poly blend threads for the first few projects.
Oct 20, 2009 | Singer Sewing Machines
My thread in the bobbin keeps getting jammed up
Here are some possible solutions:
1) Try a new bobbin, and if you wind your own, make sure it is wound very tightly
2) Take the bobbin case out and make sure there are no stray threads stuck down there, they can wreak havoc! To do this, unscrew your throat plate and lift the bobbin case out. Then use your lint brush that came with the machine, or another small soft brush and give it a thorough cleaning under there.
Hope these help!
Jan 10, 2009 | Singer 2662
Sewing Machines Logo
19 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
