Question about Maytag MTW5700TQ Top Load Washer
NOISY TUB BEARINGS - Maytag MTW5700TQ Top Load Washer
  • Maytag Master
  • 17,130 Answers
It is so common that the washing machine can make terrible noise in many ways and is a common fault. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that machine is vibrating when it is running then the motor /drum suspension has to be inspected. Since these fittings are located on the underside of the machine it is important that you look for the noise with a good inspection lamp. Manually turn the motor and drum and listen for the noise, if so the motor bearings, the drum agitator shaft and fittings must be checked. Also the suspensions which include the shock absorbers and springs, the body clamps must be checked to be in correct alignment and not changed in position. Tightening of the mounting is also very important. Finally in most cases a drop of OIL or smear of grease on the moving parts cane solve most issues.
Check this link :
http://www.espares.co.uk/advice/washing-machines/a/7/1210/wobbly-washing-machine-or-tumble-dryer.html
For replacement of bearings check for tips on this visual link: http://www.espares.co.uk/advice/washing-machines/a/7/1401/how-to-replace-the-bearings-on-a-washing-mach.html
Posted on Jan 02, 2013
  • davidgj98823
    davidgj98823 Jan 04, 2013
    There is an error on the model number, It is a MTW6600TQ.
Simpson 7.5kg EZISet750 machine is noisy (loud) whilst Rinse and drain spin - but clothes are well rinsed. your advise please.
Needs new bearings. Machine has to be dismantled to get at and replace the tub seal and two bearings.
Jan 10, 2018 | Simpson Washing Machines
What causes a hotpoint ultima wmd960 noisy spin ?
Tub seal leaking letting water get to tub bearings need shaft and bearings replaced.
Aug 31, 2014 | Washing Machines
What can cause noisy spin on wd960 hotpoint
tub seal leaking need to replace shaft and bearings
this takes special tools.
What can cause noisy spin on wd960 hotpoint ?
bad bearings, seal leak let water in bearings
Tub seal leaking letting water get to tub bearings need shaft and bearings replaced. takes special tools
Aug 31, 2014 | Hotpoint Washing Machines
How to fix noisy and rotating washing machine
switch off at wall turn tub by hand and see if it rotates ok without any noise or sticking as this would mean replacing the bearings at the back of the tub.
May 25, 2014 | AEG Washing Machines
Bearings realy noisy on drum can i buy and fit the bearing my self
Bearing is part of rear tub//tub has two pieces frount and back .Need more info to tell you how that part would be sold///sometimes outter tub comes as complete unit with inner basket ..........If I helped you please vote need more help please ask....good luck
Feb 04, 2011 | Washing Machines
WASHING MACHINE IS NOISY , SOUNDS LIKE GRUMBLING NOISE.
the tub bearings have worn out you can fit new bearings but its not going to be a cheap job to do,,,ask yourself how old is your washer,,would it be better in the long term to buy a new washer?,,,
Aug 28, 2010 | Microwave Ovens
Machine noiser than it use to be when tub spins
From the front of the washer, spin drum by hand, and if it feels rough or is noisy, then the main drum bearings are probably worn.
Another possibility is the motor bearings noisy, or a worn armature.
If the noise is gradually getting worse, then I think it is safe to say it is the main bearings.
Jan 26, 2010 | Hotpoint WMA40 Front Load Washer
Noisy Spin Cycle
If the bearings are out, you don't have to replace the entire outer tub. You can replace just the bearings. I have done this on a few machines already, and they work without flaw now. Cost of replacing the bearings, parts and labor is going to be $250 to $300 depending on where you are and barring any other problems such as a perforated boot. I do this in the D/FW area.
Sep 03, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag MTW5700TQ Top Load Washer Logo
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
