Question about Amana ARGS7650SS Gas Kitchen Range
The electric control panel on my Amana ARGS7650SS in pushed in in the lower middle area and will not function properly. The clock works, but the oven will not turn on and the timer doesn't functio
It seems like the panel might just need to be re-attached from the inside, but getting the stove disassembled looks like a lot of work. If I need a new panel, I'd rather have it ready to go, so that I don't end up with a non-functioning stove while I wait for a part. The top burners all work fine. In fact, we had just made a roast, turned of the oven, and then realized it was not quite done, but the oven would not turn on. We waited overnight to let the oven cool completely and tried again, but still nothing.
Buffalo12980
  • 625 Answers
SOURCE: Amana ARGS7650SS problem
try this site - repairclinic dot com. there are some helps about where the screws are to remove the control panel.
Posted on Aug 21, 2007
SOURCE: Amana ARG7300w oven inop
It has a bad oven igniter.
Posted on Aug 27, 2007
  • 10 Answers
SOURCE: AMANA STOVE
you have an electric problem that it can be from lightening or replace the clock. so u must be sure that gas valve working mostly it must be 24 volt . if u haven't electricity on gas valve check the high limit switch if there is a combination u must change valve
Posted on Aug 17, 2008
  • 6 Answers
SOURCE: oven not lighting on Amana model agds902ss
SOUNDS LIKE YOUR ELEMENT CONTACT MODUE IS BAD YOUR AMANA IS MADE BY MAYTAG AND THE PART # FOR THE MODULE IS Y0042123 AS TO WHERE YOU WILL GET ONE TODAY NO IDEA JUST TRY YOUR LOCAL REPAIR DEALERS IS ALL I CAN SUGGEST
Posted on Dec 24, 2008
SOURCE: Amana gas oven not working
SOUNDS LIKE U HAVE A WEAK BAKE IGNITIOR REPLACE THE BAKE IGNITIOR IT WILL SOLVE THIS ISSUE
Posted on Aug 31, 2009
Amana ARGS7650SS Gas oven takes a long time to heat up, and then, in the middle of baking, the digital control panel goes blank and the oven goes off. Eventually, the panel will begin flashing and, with...
This is Amana's fault and is common on several oven models and types.
Your timer and clock control board has some loose solder joints and they can be re-attached by any competent electrical repair shop with soldering skills. TV shops can often be convinced to do this for you for a nominal fee.
Nov 07, 2010 | Amana ARGS7650SS Gas Kitchen Range
Amana EvenAir Convection Plus AOCS 3040: The oven starts to heat up, never quite gets up to temp and then temp drops down. I had an appliance repair man out to look at it and he said that since no error...
Something else you can check while it's preheating: a few drops of cooking oil on the bottom of the oven will tell you if your lower element ("bake") is functioning at all. If it's working, you will get smoke during pre-heat (turn it off!!), if it's not - the problem *can be* in the relay board. Does your "Broil" function work ok.? if it does, then chances are your ERC (electronic range control - the main board that controls all functions) is fine, and the problem is now MOST likely in the relay board. The lower "Bake" element does most of the work in the oven - if the oil trick doesn't give you some smoke, let a tech know that the lower element is not functioning. That will help narrow down the troubleshooting scope.!
Dec 23, 2009 | Amana AOCS3040SS Electric Single Oven
The dial that indicates the temperature setting on the fan oven has come detatched. As you turn the dial it remains still with just the 120 showing. How do I remove the panel to get to the dial, please?
The three controls for the oven and grill just pull off. They have flats on them to ensure they go back on the right way.
There are three screws on the underside of the panel. One at each end and one in the middle. Remove those remembering how they went.
The clock buttons just push fit into the panel and just rest on the clock controls, so you needn't do anything with them.
The panel should now be loose. What you have to do is to raise the lower edge of the panel up to unhook the panel extensions on the top inner edge of the panel that hook into the cooker and then the panel comes off. A word of warning here. Turn the power off before you start and you may have difficulty getting the panel back properly like I did. The hooks by the clock didn't want to play ball, so I left them unhooked.
Best of luck. If you need a copy of the handbook, supply an email address for a copy via my BT Digital Vault.
Nov 30, 2009 | Stoves 720EF Electric Double Oven
The oven will not completely heat
Try a few drops of vegetable oil on the lower pan of the oven, and turn it on. If you do not get smoke during pre-heat, chances are your lower element is not working properly. If you DO get copious amounts of smoke off the pan, the problem could be with the temperature sensor.
If your lower element is not functioning, and if your broil function works just fine, the problem may be isolated to the relay control board. (relay K4 controls half of the 240V required to run the Bake element correctly)
Nov 23, 2009 | Amana AOCS3040SS Electric Single Oven
I have an amana gas stove model ARG7800WW . The cook top works but the display (Clock Timer) doesn't light up and the oven doesn't work.
u need a new clock , or the oven wont work , u can bypass the clock to get the oven going but u need to know which two wire to join
Oct 27, 2009 | Amana ARGS7650SS Gas Kitchen Range
Our digital display says F1 and we cannot set the
This usually means a failure in the control board. We rebuild these at www.fixyourboard.com
Oct 10, 2009 | Amana ARGS7650SS Gas Kitchen Range
Whirpool model# RF385PXGN (electric) error code F2 E0 The failure/error display codes says replace control. What is control ?
F2-E0 - Shorted Touch Pad (Keypad) - Check the connection between the touch pad (keypad) and control board (clock) to make sure it is secure.
Select the 'cancel' function and wait 60 seconds.
If error code reappears then replace the touch pad, or touch pad and control board (clock) if all one assembly.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!!
Jul 28, 2009 | Amana ARGS7650SS Gas Kitchen Range
Amana gas range trouble with starting
not a sensor, but more likely a bad oven ignitor(glow bar) its located under the ovne floor and mounted to the side ofthe bake bar. simple emough to unscrew and unplug, replacethepart yourself
Mar 18, 2009 | Amana ARGS7650SS Gas Kitchen Range
Amana ARGS7650 Keypad has no power
I had the same problem, same model. The electronic panel has to be replaced. This part is ~$215 before tax and shipping. With labor, I was looking at over $400. I bought a 4 yr old used GE gas oven for $75. That was my solution.
I believe the part to replace is labeled Erciii, gas
Part Number: AP4041311 made by WHIRLPOOL
This would have taken at least a week to ship (no one seems to have them in stock).
From now on, I will never own a range in which the oven or stovetop controls are electronic. Knobs and associated mechanics can be replaced MUCH more easily and cheaply!
Dec 01, 2008 | Amana ARGS7650SS Gas Kitchen Range
Aug 21, 2007 | Amana ARGS7650SS Gas Kitchen Range
Amana ARGS7650SS Gas Kitchen Range Logo
164 people viewed this question
Top Amana Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Sal De
Are you an Amana Kitchen Range Expert? Answer questions, earn points and help others
