Question about Vizio VX32LHDTV10A 32 in. LCD HDTV
Vizio tv, screen format, picture too large for screen
Picture too large for screen
3 Suggested Answers
SOURCE: i cant get picture to fill the screen
on my remote i have a wide button and it changes it to full screen i hope this helps
Posted on Dec 20, 2008
SOURCE: 55 inch vizio tv has large image and cannot get the right size
HI!!!!!!
Posted on Mar 03, 2012
I need to reduce the size of the picture on my vizio tv screen. The technician made it so large the whole picture is not shown
From the Vizio remote in the menu, find the picture settings and select the size you prefer.
Jan 02, 2018 | Vizio Televison & Video
Youtube on my vizio 470i tv is off centered
CHANGING THE SCREEN ASPECT RATIO: ( From Manual )
The TV can display images in four different modes: Wide, Zoom, Panoramic, and Normal. Each mode displays the picture differently. To change the screen aspect ratio:
1. Press the MENU button on the remote.
2. Use the Arrow buttons to highlight the Wide icon. Press OK.
3. Use the Arrow buttons to highlight your desired screen mode and press OK:
• Normal preserves the content's original aspect ratio. Since the 4:3 aspect ratio is not large enough to fill the TV's screen, black bars are added to the left and right of the display image.
• Wide stretches a 4:3 aspect ratio picture to the edges of the screen. Since the picture is being stretched, the display image may appear distorted. If the program is already formatted for widescreen viewing (1.85:1 or 2.35:1), then black bars will appear on the top and bottom of the display image.
• Zoom expands images with black bars to fit the screen.
• Panoramic expands the display image to fill the screen.
images may appear wider than intended.
If you are watching widescreen (1.85:1 or 2.35:1) content, black bars will still appear on the top and bottom of the display image. This option is only available when the TV is displaying a 480i/480p source.
Apr 25, 2014 | Vizio Televison & Video
Picture doesn't fit the screen
Its a function of the source and the tv picture settings. Go to the source (direct tv, cable, co-ax?) menu , settings and look for screen display sizes.
Your remote has a red dot "wide" button which will also have a screen size effect. You can cycle through the formats
For further info why not read/print out the manual?
http://store.vizio.com/documents/downloads/hdtv/L32/Manual.pdf
Mar 19, 2014 | Vizio L32 32 in. LCD HDTV
I have a large spot on the right side of the LCD screen, it looks like a large water spot does it mean the VIZIO TV is going out? What can I do to make it disappear.
Not possible.Tv have damages to it LCD screen panel by an object or a person have causes by forced or putting pressure to the tv LCD screen panel itself to causing colors picture pixels and it radiation to died to causing this problems.Sorry it time to buy a new tv,because by replacing the tv LCD screen panel itself will cost u the same as a new tv.Tries buy a new tv from the VIZIO tv corporation directly return the damages LCD panel tv to them,u could get a 5 or 10% off of the tv prices.
Jun 05, 2011 | Vizio VU42L 42 in. LCD TV
My Vizio LCD HDTV 32in. doesn't seem to "center" the picture on sports programs so when they have a score box in the upper left corner most of it is cut off and can't be seen. Doesn't matter how I adjust...
This is a common complaint. To be frank I don't have the exact term for your Vizio, but most recent LCD and plasma TVs have the ability to "zoom" or adjust "picture format" (those are two commonly used terms) depending on the signal source and format.
it has to do with the fact that currently there are both classic style format 4:3 signal sources as well as new HD 16:9 signal sources and on top of that it may happen that a 4:3 signal source is distributing adjusted image from a 16:9 or other signal source. Think cinema adjusted to run on classic TV - remember the vertical strip of image with two huge black areas below and above it?
Well the ZOOM or PICTURE FORMAT allows to adjust such an image so that you cut the "void" are by scalling (enlarging) the visible area to fit the whole screen.
A problem then appears when the signal source is normal and showing full screen. Then, because of the enlargement, you start missing some of the picture. Before there was nothing there because it was showing adjusted wide (cinema) format to the TV box format, but when the new TV box format gets enlarged it sure starts missing around the edges.
That's what you're seeing.
More and more TVs do not have the ability to adjust that through the TV itself. Don't ask me why, but they can only do it through the remote.
So if you have an original remote there MUST be a button there that's called ZOOM or FORMAT.
It does the trick.
Hope this helps. If it does do not forget to rate it.
Cheers,
www.coppelltvrepair.com
Oct 18, 2010 | Vizio L32 32 in. LCD HDTV
When we watch a movie on our 37" vizio it's not going into widescreen it's smaller how do you set it up so it fills the screen
You can zoom in on the picture. But you are most likely watching a movie formatted for wide screen. There are different formats of DVD's. Hope it helps.
Aug 09, 2009 | Vizio VOJ370F 37 in. LCD TV
I cant get picture to fill the screen
Dec 20, 2008 | Vizio P2 42 in. HD-Ready Plasma Television
Vizio 37'' TV
This is normal.
Oct 21, 2007 | Vizio L37 Television
Vizio VX32LHDTV10A 32 in. LCD HDTV Logo
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
