Question about Motorola Mobility RAZR V3
Motorola Razr - Keypad Doesn't Work
Hello, I own a Motorola Razr V3 and the only key that works is the on off button. I have never dropped it, it was working fine for a year and one day it just stopped working. The screen still works and I can answer phone calls by opening the flip part, but I can't call anyone or text or anything that requires pushing a button unless it is to turn it on or off. Can anyone help me?
  • 8 more comments
  • Salih yar Jun 26, 2007
    I tried, but didn't work...Any further suggestions??
  • Salih yar Jul 17, 2007
    Thanks Marisha. Somehow, the phone suddenly started working properly before I read yours. May be I pressed the keys unintentionally :))
  • bf66stang Jun 18, 2008
    my keypad wont work i was just using it and then i closed it to get off the phone and i picked it up and the key pad stopped working what do i do?
  • Anonymous Jul 02, 2008
    Key pad went dead. On-Off keys work, but all other key non responsive.
    Hasn't been wet or dropped.
  • mandiluwho Jul 03, 2008
    is this a common problem with the razrs? i have the smae problem. it will work fine one day and then the next it won't then all of a sudden it works again.
  • Anonymous Aug 01, 2008
    I too have the same problem. What did you do to make it work???
  • pizzatony1 Aug 01, 2008
    exact same problem please contact me for more info [email protected] .ca
    Yes, I have same problem with Motorola RAZR V3 when the keys stopepd working (froze) and if I pushed them the browser would come up. The problem was solved by blowing hot air from a portable heater tothe phone (remove battery and SIM card first), and then blowing the back and front of the phone with moisture free air. Prior to failure the phone was exposed to humid atmosphere.
  • Anonymous Oct 26, 2008
    Yes, I have the same problem. I had it in my pocket today, but then it rained pretty hard and got a little wet...not soaked, but wet. I have a feeling some of the water seeped into the internal parts.
  • Journye Apr 12, 2009
    I come home from work and my keypad doesn't respond at all cept the end (on/off) button but it lights up
My phone developed the same trouble............ Removed battery and SIM and blew dry air into anyhole I could find, put it back together and has worked ever since.
Thanks for the tip
Posted on Sep 10, 2008
    Problem Solver:
Hi i too had the same problem with my brand new phone , just clean the flex cable connections with alcohol , dry it and try using it , it actually worked for me .
Posted on Jul 19, 2007
    New Friend:
    Problem Solver:
  • 8 Answers
My did the same thing and theres not much you can do about it. I had 2 get a new phone and i lost all my pictures!
Posted on Aug 15, 2008
My Motorola v3 the keypad has no lighting how do i enable this
Posted on Jul 03, 2008
U will have 2 change keypad plate.some moisture might have gone inside of ur phone.first try to clean the key pads carbon n key pad jumper
Posted on Jun 25, 2007
    Problem Solver:
  • 8 Answers
The phone is locked. It should let you press the unlock code. Default is 1234 but some companies use the last 4 digits of your phone number. If you can't figure it out there are outfits on the internet that will unlock for $7.50.
Posted on Jul 10, 2007
SOURCE:
Motorola v3 problem
looks like you need a clean of the unit and replace the keypad.
refer to here for intructions
http://thydzik.com/motorola-razr-v3-repair-and-housing-change-guide/
Jul 21, 2009 | Motorola Mobility RAZR V3
Razor v3 keypad on/off button works but none of the other keys..
Take the battery out and let it reset... It hasn't been exposed to any magnets or anything like that?
Jun 01, 2009 | Motorola Mobility RAZR V3
V3 unresponsive Keyboard
TRY TO CLEAN THE KEYPAD MEMBRANE OF YOUR UNIT..ASK A TECHNICIAN TO DO IT...THEY USE SPECIAL SOLUTION CLEANING THE KEYPAD & THE MEMBRANE...
Jan 27, 2009 | Motorola Mobility RAZR V3
Razr keypad
its a simple problem and i dnt tink u will b able to do it.the main bord is connected 2 da key pad wichs also conects to da lcd.so basicly ur ribon is damaged.it cost about 150rand to repair.
Jul 28, 2008 | Motorola Mobility RAZR V3
Power button works..
if the only red buttons is working,
maybe your phone keypad flex ribbon is already damage.
or if you drop your phone and after that
the erd buttons is only function key keypad crystal is the prob.
Jan 16, 2008 | Motorola Mobility RAZR V3
Motorola razr freezing
your phone problem is the keypad flex of your phone'
you can fix it by replacing the keypad flex'
motorola dealer has the keypad flex'
ask for a skilled cellular technician to re-place your keypad fle..
i hope it will helf to your prob...
Jan 07, 2008 | Motorola Mobility RAZR V3
Motorola razr v3 keypad problem!!
Press all of the buttons and keys on the phone one by one with it powered off and the battery out. Make sure they all feel normal to the touch and when pressed. Check the buttons on either side of the main display carefully, as these tend to get stuck more than others.
Dec 15, 2007 | Motorola Mobility RAZR V3
Key pad doesn't work
Try disconnecting the battery.
Oct 06, 2007 | Motorola Mobility RAZR V3
Keyboard only partly working
Um check and make sure that behind your keypad and see if there not blocked by dirt or something with your connection although your need tabs to check and see to get of your keypad but be carefull if you dont know what your doing and aint got insurance dont do it, i also think there is a solved problem about opening the keypad up. Hope that helps.
Feb 11, 2007 | Motorola Mobility RAZR V3
My razr presses buttons on its own
Open&Clean keypad and keypad mat.
Dec 17, 2006 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
2,951 people viewed this question
Top Motorola Mobility Cell Phones Experts
vince
D. E. Hev
Mark Magill
Mark Magill
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
