Question about SanDisk 2GB microSD Memory Card
I have a 2g micro sd card and I don't know how to format it from my blackberry?
    Problem Solver:
  • 15 Answers
It can be formatted only by the computer or any other phones. i too have a blackberry but my sister has nokia so i can format it.
Posted on Oct 14, 2011
How I format micro sd card if MSDC write sector error?
Do this click my computer>right click icon of your micro sd card>choose format (don't check quick format) need full format to recovered bad sector. if finish formating, right click icon of your micro sd card >properties>choose tools>choose error checking and click check now.
To fix your micro sd card.
Also try to scan using anti-virus sometimes virus became write sector error.
Jul 15, 2011 | Computers & Internet
I have an 8GB micro sd card for my blackberry storm when i put it in. It says media card has inserted contains errors. to correct the errors use a disk error-checking utility on a computer. what do i need...
The chances on any micro sd card showing errors can be either the files stored in it are corrupted or the card is simply bad already. You may try to identify the problem by performing the following steps.
1· Access micro sd card through a card reader. May it be built-in in a computer or an accessory that needs to be plugged-in to a computer.
2· Wait for a few seconds for the computer to read the micro sd card.
a· If it asked you to "open the folder to view files", do so then copy all contents in a new folder on your desktop. This is to make a backup copy of your files. Then, format the micro sd card with FAT32 format. Copy all files back to your micro sd card.
b· If it asked you to format the micro sd card, most likely all files are corrupted. Try to format the card for re-use. If not successful, your micro sd card is bad already and needs replacement.
I hope this works for you. Good Luck!
Mongkey
"Understanding explains better..."
Jan 30, 2011 | SanDisk 2GB microSD Memory Card
I-mate JASJAM won't recognize micro sd card
format it and then try.else soft reset.or there mite b dust in ur sd card slot!
Mar 01, 2010 | i-mate K-jam Smartphone
Motorola V320 doesn't play music from 2G or 1G Micro SD
depending on downloaded muisc usually mp3 check manual to see what type it plays on phone it could be mp4
Aug 05, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Format 8gb sandisk micro sd problem
Often times, these jump drives have a tiny, nearly invisible read-only switch on them. Check to see that it isn't set to read only, which will inhibit formatting, among other things.
Jun 14, 2009 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
My blackberry stopped working after i put a micro sd card in
did you format the card first... this might help. It could be too much memory. I put an old SD card in from a former phone and it was doing the same thing...powering on and off repeatedly.
Apr 12, 2009 | RIM BlackBerry Pearl 8100
Format sd memory card 2g for blackberry usage
Dear,
Just format the card using PC. It is very simple. Right click on drive(card) and select format. It is ready to use.
Regards,
Rakesh Kumar
Apr 01, 2009 | SanDisk 2GB microSD Memory Card
8 gig micro sd unable to format
you should download memory retriever it fixes your memory card and retrieves your data. i had the same memory card and i thought it was from the memory card acting up so i got a new one. but it was kind of from both the phone and memory card but i downloaded the program and = ] my new memory card wasn't formatted so now am all good! both of them working because my san disk memory card wasn't working and it deleted all my data. so now it retrieved and now is working! give it a try! and tell me what happens
Mar 21, 2009 | Electronics - Others
The 2g kingston micro sd card fails to format in samsung muse phone. It start and then say format failed. I can put it in my computer and transfer information and then retrive it but my phone says nothing...
I have the same problem to beginning with. The new 2GB SD Micro card/with adapter didn't work at all. It didn't see it by window explorer. Others older once did work properly. Make sure you update your SD card reader driver to the latest version. It should be work. My did after updated the card reader driver.
Or update your all in once card reader if you have one.
Good Luck
Flyfox........
Feb 28, 2009 | Samsung Cell Phones
Memory card micro sd cannot format
Definitely your Micro SD Card has a problem. might be ita a virus problem.
Try to format it by your Computer not by your Phone. If you have a AntiVirus scan your Card and then try to format it.
if you are not successful in one chance Don't afraid at all, try it three or four times by removing and then inserting the Card again in the Computer........
Mar 19, 2008 | RIM BlackBerry Pearl 8100
SanDisk 2GB microSD Memory Card Logo
53 people viewed this question
Top SanDisk Electronics - Others Experts
Piyal Perera
Piyal Perera
Are you a SanDisk Electronics - Other Expert? Answer questions, earn points and help others
