Question about Roper RAS8445KQ Top Load Washer
Cold water fills very slowly
Hot water works fine. Cold water fills slowly.
  • David Wisthoff Jan 02, 2013
    How does the top come off a Roper Machine so I can clean the Fill Valve? I have cleaned the screens. I can hear the Fill Valve buzzing but the cold water is very slow.
  • Roper Master
  • 17,130 Answers
Possible the INPUT FILTER of the COLD water is clogged or the INLET valve is faulty. check the power from the board.
Posted on Jan 02, 2013
5 Suggested Answers
  • 213 Answers
SOURCE: Washer takes forever to fill
sediment gets clogged in the valve that cant be cleaned if you replaced the water valve it will solve the problem
Posted on Nov 25, 2007
heatman101
  • 43501 Answers
SOURCE: will not work with cold water only warm
First check the screens at the cold inlet and make sure they are not plugged. If everything is okay there then it is the solenoid valve on the cold side that is bad... you need to replace the whole unit vlave body, both hot and cold as they come as one unit.
Check out these tips also...
heatman101
http://www.fixya.com/support/r3880845-washing_machine_problems_no_water
http://www.fixya.com/support/r3907570-buy_appliance_parts_online
http://www.fixya.com/support/r3880533-washing_machine_fix_washing_machine_no
http://www.fixya.com/support/r3867591-washer_troubleshooting_water_not
http://www.fixya.com/support/r3864434-washing_machine_door_jammed
http://www.fixya.com/support/r3663122-washer_problems_washer_noise_when
Posted on Mar 26, 2010
jsrock516
  • 5911 Answers
SOURCE: cold water starts and stops during fill and rinse cycle
This problem is commonly caused by a water inlet valve (also known as a mixing valve) that has a defective cold water solenoid. If you live in an area that has hard water, or if you use well water, sediment, rust or calcified deposits can accumulate in the inlet valve and cause it not to close properly. Usually when they start leaking, or not functioning at all, you need to replace them. The following link explains how to access and replace the valve:
http://www.fixya.com/support/r3575881-replacing_water_inlet_valve_on_whirlpool
If the model number is correct, the part number for a replacement valve is 285805. Replacement parts (if required) can be purchased at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
Prices vary between sites, so shop and compare. The first three sites listed also have helpful exploded view parts illustrations to assist you with locating and properly identifying the parts you may need.
If you have any questions, please post back and let me know. I hope this helps you.
Posted on Jul 07, 2010
ercupa190
  • 12223 Answers
SOURCE: hot water fills with hot and cold not strictly hot what is the fix
see the causes: and proceed with common sense. God bless you
Some washing machines allow hot water to enter only during certain cycles. Others intermittently allow hot and cold to enter, to temper the temperature of the water. Consult your owner's manual if you are unsure about whether the machine is acting abnormally. If you're sure the machine isn't working the way it used to--or should--try these tests: Is the hot water turned on? If not, turn it on. Is the washer getting cold water but no hot water? If so, check to see if the control panel settings are correct. Is there hot water coming through the proper hose? If not, check to see if the screen inside the water-inlet valve is clean. (The water-inlet valve is the device on the washing machine that the fill hoses are attached to.) If it's clean, you probably have a defective water-inlet valve. If so, completely replace it.
Some washing machines allow cold water to enter only during certain cycles. Others intermittently allow hot and cold to enter, to temper the temperature of the water. Consult your owner's manual if you are unsure about whether the machine is acting abnormally. If you're sure the machine is not working the way it used to--or should--check the following. Is the cold water turned on? If not, turn it on. Is the washer getting hot water but no cold water? If so, check to see if the control panel settings are correct. Is there cold water coming through the proper hose? If not, check to see if the screen inside the water-inlet valve is clean. (The water-inlet valve is the device on the washing machine that the fill hoses are attached to.) If it's clean, you probably have a defective water-inlet valve. If so, you need to replace the
Posted on Sep 23, 2012
My washer will fill with water during the wash cycle just fine, but during the rinse cycle the water just trickles in. The water lines seem to be fine. What else could be causing my problem?
usually the wash is a mix of hot and cold and the rinse is just cold, that said, it is most likely a problem with the cold water supply. check to make sure the cold water valve is all the way open and the hose isn't kinked. If those are ok turn the water supply off and remove the supply lines on the machine side, you will see a screen inside the washer that may be clogged with sediment. If so, just clean it out and put it back together. You may also want to run a wash cycle on cold only to see if it fills slowly for the wash cycle. If it does fill slowly on cold you have low pressure on the cold side.
Jan 07, 2011 | Whirlpool Ultimate Care II LSQ9549L Top...
My Fisher and Paykel mw511 intermittently will not fill with cold water. The bowl spins slowly as if it should be filling with water and I can hear a pump but no water comes out. I swapped the hoses and...
Cold water valve problems with F&P machines are common. Replacing the cold valve is the most likely remedy.
It's not good policy to use the hot valve on the cold inlet because (we are told) they are different in their tolerance of high water pressure. (don't shoot the messenger!!)
As you've changed the valves, you've already seen that the problem can be removed...
Good luck.....Nomess
Aug 06, 2010 | Washing Machines
Brand new roper washing machine model # RTW4440VQ2 the cold water is very slow filling hot is fine
This model of washer has something called an Automatic Temperature Control. This means the washer puts water into the tub at specific tempreatures instead of just 100% cold, or 100% hot. Be sure and check that the hot and cold fill hoses are connected to the proper places on the back of the washer. It's possible that the ATC (mentioned above) is causing the washer to fill slowly on the cold setting.
May 20, 2010 | Washing Machines
MAchine fills slowly. Have cleaned the screens.
Check the solenoid. You can swap the hot and cold water hoses and set the wash for hot but cold will come out. Then you can see if the flow is better. If it is the cold valve isn't opening all the way.
Mar 11, 2010 | Washing Machines
My new estate washer with 4 water selections actually only has 2, hot and cold. The warm water setting fills with lukewarm water for a while then shoots in cold water for a while and back and forth. In the...
Yes, this is normal. All newer washer have auto temp control fills. This is to meet energy saving requirements. The less hot water used the more energy saved. Most hot settings on washers give out basically lukewarm water. The detergent made today is made to work well with cooler temperature water, so things will still come out clean.
Feb 01, 2010 | Whirlpool Estate TAWS750PQ 27-Inch Washer
Maytag Performa wont fill hot water
The water fill valve - The water fill valve is a mechanical and electrical part, the coils on the valve need electricity to mechanically open the valve to allow the water to flow into the washer....myth....the washer pumps water into itself...no, it does not. The fill valve opens and the house water pressure pushes the water into the washing machine.
No cold water or no hot water - The fill valve has two coils, one for the hot water and one for the cold water. It is possible that one of the coils can fail and you loose that filling ability. If the cold water coil quits, the hot will still work and during warm fill you will get hot water only and during a cold fill you will get no water at all. If the hot coils quits, you will still have cold water fill, cold water only on a warm setting and no water on a hot fill setting. You can No cold water or no hot water - The fill valve has two coils, one for the hot water and one for the cold water. It is possible that one of the coils can fail and you loose that filling ability. If the cold water coil quits, the hot will still work and during warm fill you will get hot water only and during a cold fill you will get no water at all. If the hot coils quits, you will still have cold water fill, cold water only on a warm setting and no water on a hot fill setting. You can test a fill valve live for 120 volts, power to a fill valve coil and no fill = a bad fill valve. You can also test the coils for continuity, no continuity = a bad fill valve. Some Maytag washers have a fuse in the fill valve circuit, if this fuse let go the washer will not fill. Fill valves can also from time to time stick open and not stop filling. If you have to shut off the fill valves to stop the water from filling in the washer, you have a bad fill valve and you will have to replace it.
Nov 27, 2009 | Maytag Performa PAV2200
Why did my LSE7806ACE WASHER STOP FILLING
Hi…
If I get you correct, the hot water is not coming into the machine or it is not working at all.
Let me know
Thanks
Smith
Aug 13, 2009 | Maytag LSE7806A Top Load Stacked...
Slow Cold Water Fill
There is possibly a filter screen in the hoses as well as the water valve.Check the hoses for screens.Occasionally the water valve will deteriorate inside and must be replaced.
I am on a water well and have the same problem. This weekend I installed a inline filter purchased from Lowes. It has stopped the sand and silt problem. You will have to buy one extra water hose to do this yourself.
Jul 16, 2009 | Kenmore 22422 Top Load Washer
My GWL10 fills really slowly. It starts fine with the hot water, then slows to a trickle when it switches to cold but it doesn't seem to affect it if I change the temperature selection. I normally leave it...
sounds like you have a restriction on the cold water water pipe kinked or a blockage turn off cold water and remove pipe from cold tap then turn tap on and see if water is coming through fast enough if it is then the restriction is in the hose or valve on washing machine if not then the restriction is in the cold water tap
Jul 14, 2009 | Fisher and Paykel GWL11 Top Load Washer
Bosch washing machine
You have a sticking water inlet valve, which is slowly letting water enter m/c.
If it is a hot and cold fill m/c, what you need to do is turn either the hot or cold tap off to the m/c, and see if the problem continues, if say you turn the hot off and it still comes into the washer, then you have sticking cold valve, replace with new one. if after turning cold off, and it still fills, then you need new hot valve fitting.
If it is a cold fill m/c only, then simply replace the cold inlet valve.
Problem solved.
Plz rate my solution.
Thanks.
Dec 21, 2008 | Washing Machines
Roper RAS8445KQ Top Load Washer Logo
80 people viewed this question
Top Roper Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
