Question about Gaggia Brera Coffee Maker
Gaggia Brera slow flow
The flow of espresso is slow then drips
EsWorld
  • 1618 Answers
SOURCE: Gaggia classic espresso machine has stopped giving
Either the shower is blocked or the grind on the coffee is too fine.
Posted on Oct 21, 2009
SOURCE: Gaggia Classic Espresso Machine - will not pump water
Hi, this is so easy to fix. Firtsly unplug the machine. Then remove the two screws in the top plate so that you can have access to the internals of the machine. You will see the red pump to the left hand side at the back. Remove the two screws that hold the pump in place (use a magnetic screwdriver so that you can pull the screws out). Pull the pump up towards you and then unscrew the thin plastic pipe at the top of the pump . It is the pump that has the scale build up problem. If you the put the water tubes into the water tank and hold a cup to the top of the pump to catch the water you then have to switch the pump on. You will then start to see lots of scale come out of it and the pump will pump more water than you are expecting so be careful. Be sure to cover the internals of the machine whilst you are doing this as you don't want to get water on the electrics and electricute yourself!!! Then rebuild it! Just svaed yourself £100 in having it serviced :-)
Posted on Nov 01, 2009
  • 3 Answers
SOURCE: Gaggia Platinum Vogue Built in Grinder
Just use the whole bean. Using pre ground coffee through your grinder will screw the blades completely.
However if you have a decaff option that allows you to put coffee directly into the brewer that would be ok........just dont put it into your hopper that feeds the grinder.
Posted on Mar 09, 2010
EsWorld
  • 1618 Answers
SOURCE: espresso sprays out side of filter
The head gasket needs to be replaced.
Posted on Jul 02, 2010
SOURCE: Gaggia brera, coffee beans compartment is full of
I have the same problem. Not a solution, but you can still take the ground beans and brew coffee, using the pre-ground compartment.
Posted on Apr 11, 2011
My Gaggia Brera made really nice foam really fast for a while. Now it stopped foaming at all. Does anybody know how to return the foam?
There is a small hole at the top of the steam wand. It is likely blocked preventing air from entering the wand. Poke out any dried milk with a needle and wash thoroughly.
Mar 18, 2015 | Gaggia Coffee Makers & Espresso Machines
My Gaggia Brera has all four warning lights blinking simultaneously. And won't make any coffee. Ideas?
hi,when you have the warning lights blinking it may you have a faulty micro switches you have one for the brewer one for the door and one for the basket or faulty boiler not heating up
Oct 13, 2014 | Gaggia Brera Coffee Maker
Gaggia brera descale stays on
try to hold the steam/hotwater button for 5-6 seconds.
Aug 15, 2014 | Gaggia Brera Coffee Maker
Gaggia brera brew group wont go back in
If you close the machine without the brew unit inside, the gears aren't aligned anymore. I tried to put the machine off and then back on. You can hear the gears turn. After a couple of repeats, I was able to put the brew unit back inside.
May 13, 2012 | Gaggia Brera Coffee Maker
Brera: coffee grounds inside + internal leak
finer grind setting and non oily beans did the trick for me.......
Apr 17, 2012 | Gaggia Brera Coffee Maker
We have a five year old Gaggia Titanium regularly descaled. In recent weeks the flow of coffee has considerably slowed to a drip and we now get a message saying 'Brew Unit Missing'. The machine also now...
Remove the brew unit, find the 2 screws above the top shower the connects the discharge tube to spout. Remove screws and carefully remove spring and ball some have a plastic seat at end of spring. Clean tube make sure there is no coffee grounds blocking tube, reassemble and test.
Aug 23, 2010 | Gaggia Titanium Espresso Machine
? Am I trying to use coffee ground TOO FINE
On my Gaggia Machine I use an Gaggia MDF Grinder on 8 or 9 setting for the best flow. I only use as low as 4 with my Presso Manual Machine
Nov 05, 2008 | Gaggia Classic Espresso Machine
Gaggia Brera Coffee Maker Logo
150 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
