I have apple ipod and it cannot work and comes tex APPle 30gb ipod connect to your pc use to restoreMy IPOD audio works but vedio does not work. I have a white 30gb IPod. I tried several times the switch to on and off. still the problem is same.
Hmm actualy that is a very easy problem my dear,, your video is ot compatible,, because the file is not supported,, the only way of solution is to convert it into 3gp file,, it is a universal video file format to flash it in any type of unit,, so you can also get a video on youtube and easily convert it on what you want, but make sure you are choose the #GP file,, so what are you waiting for get the video converter now,, here i suggest the best converter of all, its a free download a video get product,, just download it
http://www.soft82.com/download/Windows/VideoGet
noo need to change the chord or to reset it,, because the music is play!!! so i conclude the chord or any wirings is ok, but the problem is the file format of your video,, so convert it in a 3gp format
you must follow my advise,, a 3gp format in order for you to solve that problem!
we trt our best to help you,, but we are not accurate in 1000%,, as long as we try our very best to instruct and provide a solution with you,, hope you understand us..
Im sure you've tried adjusting the video playback settings in the menu, so I suggest downloading a
free video conversion software called Ipod Video Converter.
It serves only one purpose and that is to convert most video files into
apple ipod video format. It supports the most common formats such as
avi, divx, mpg, flv, xvid and so on.
Just add videos that you want to convert to the Ipod video converter
or select youtube videos and click on convert when everything has been
added. The process does not take long and the best feature of this
software is that it works fine with the default settings. No need to
tweak them in any way. Excellent for beginners.
DID YOU TRY THE VIDEO DECODER? I BET THAT IS THE FIX
you will have to upgrade the system or download a video decoder.
Try installing the ipod updater software found here Afterwards turn off ipod and wait a couple minutes before turning it back on.
Good luck
1. You need to restart your iPod before putting it into Diagnostic Mode. Check that your hold switch is off by sliding the switch away from the headphone jack. Toggle it on and off to be safe.
2. Press and hold the following combination of buttons buttons simultaneously for approximately 10 seconds to reset the iPod.
* iPod 1G to 3G: “Menu” and “Play/Pause”
* iPod 4G+ (includes Photo, Nano, Video, and Mini): “Menu” and “Select”
3. The Apple logo will appear and you should feel the hard drive spinning up. Press and hold the following sequence of buttons:
o iPod 1G to 3G: “REW”, “FFW” and “Select”
o iPod 4G+ (includes Photo, Nano, Video, and Mini): “Back” and “Select”
You will hear an audible chirp sound (3G models and higher) and the Apple logo should appear backwards. You are now in Diagnostic Mode.
4. Navigate the list of tests using “REW” and “FFW”. The scroll wheel will not function while in diagnostic mode.
Hi. there might me be some problem in ur video chord.
first try getting the real A/V cable and then if it doesnt work send it back to apple. sure u wil get a replacement
apple switched the ground contact,which is usually bottom on the 3rd party AV cable. if u switch around the cables and move the plug slightly out of the jack,all u wil get is a audio and not video thing.unless u re solder the wires to the corresponding contacts
Try resetting the ipod by holding the menu and center buttons together for about 10-15 seconds while it is on.
Hi
You have to press the center button and the play button till the time apple logo does not appear on the screen. This will reset the settings .
Rylee
It only plays .MP4 format movie files and would not play other format files like MPEG or AVI but will show them in itunes . So if you are unable to play the video convert the files into .MP4 format by using MP4 converter
http://www.mp4-converter.com-video-conve...
If it still doesnt work then you can restore the ipod from the following link :
http://support.apple.com/kb/HT1339?viewl...
This all will surely help
Thanks
Rylee
Then you can restore the ipod
You need to click on the link and restore it , as it is not going to work if you reset it .
Well you need to click on the following link as the link tells you how to restore the ipod :
Hi!
Try restoring the ipod as per the link given to you. It will surely get to work. And, if it still doesn't then i will provide you with a firmware upgrader and then you can surely make it work.
My white Ipod 30gb only plays songs. Vedio does not work for movies even though audio continues. I purchased this item in 2002. I do not have any papers now. Also I have PC with Windows and not apple.
Idid reset the ipod. problem still the same.
I bought an Ipod 30gb in 2002. Till middle of 2008 it worked perfectly. I did not use it for 6 months as I am out of town. Today I recharged the Ipod and switched on. It plays all songs and all audios including movie sound track but the vedio does not come on. I did reset the ipod by holding menu and center button till the apple icon came. still No vedio.
Problem not solved. still no vedio.
There is no cord outside of the ipod. How do I know whether the chord is good or bad?
Is there any person to trouble shoot my vedio problem on Ipod or not? All answers I got sofar did not work.
I have no vedio on my Ipod. I can play music and get audio from movies but no vedio at all. My Ipod is white 30gb ipod bought in 2002.
I followed the suggestions from experts as to reset the Ipod and did it. No change.
I followed the instruction and the ipod chirped but the apple was not shown reverse at all. The problem remains.
I paid for the suggestions. I think I dont have to pay for updates. I think not too many experts have the right suggestion.
