Question about Sharp Aquos LC-32G4U 32 in. HD-Ready LCD Television
How to use a sharp aquos as a monitor with my laptop
Can you tell me what setting my tv should be on?
  • Anonymous Jan 29, 2009
    46sb54u is the model of my sharp LCD TV. i have an HDMI cable running from my laptop to my TV but the computer will not recognize the TV. what can i do to fix this. I am running on Vista.
  • 30 Answers
Hi. You haven't said how you have connected your laptop to your TV so I'll give you a couple of options:
1. VGA to VGA (This cable is a 15-pin cable like the one you would use to connect a computer monitor to the back of the computer box itself). The Sharp has a VGA connection at the back.
2. DVI to HDMI. If your computer has a DVI output, this would be the best connection.
On your remote, press menu.
Use the left/right arrows to select option
Then use the arrow up and down to select input source.
Depending on the TV you have, you will either see the actual name of the connection (ie. HDMI, DVI, VGA) or you may need to select Input 1, Input 2, etc... depending on which connection you used. The input number may be labelled on the back of your TV.
If none of this works, please let me know your model numbers and I can provide you with instructions specific to your models.
Posted on Jan 19, 2009
  • rcorbett007
    rcorbett007 Dec 18, 2012
    hello there ive got an aqous 60 smart lcd tv
Single is not compatible with this input
Posted on Dec 08, 2009
4 Suggested Answers
ginko
  • 19396 Answers
SOURCE: LC-37AF3X Sharp Aquos KCD TV
If the TV goes in standby, then it is in protection mode.
Ensure also that the fault is not coming from a faulty receiver box sending
bad signal, check if you get same problem on DVD with no receiver box
connected.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible causes.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , starting the flashing light.
If you are in situation one, then the TV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
If you want to DIY you find parts here,
All: Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
LCD/Plasma Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
On LCD Pay particular attention at inverter and power board, power board can be inspected looking for bulged or leaking capacitors, then tested with a multimeter. The inverter is more difficult to test , there is need to read voltages, should be done by a tech. Also the LCD controller board can cause same problem
On Plasma, test Sustain (Ysus/Zsus) / Buffer boards , cables to plasma, digital board and power board.
On Rear Projection : check lamp, lamp ballast, power board, and convergence.
On CRT TVs, check ballast , flyback transformer, CRT, Tuner, Convergence.
Posted on May 05, 2009
SOURCE: Sharp Aquos 30" monitor only
The monitor will not work without the AVC box.
Do you still have the monitor? Is it in good condition? Would you be willing to sell it? If so, please email me at info@btwconcepts.com
Posted on Jun 10, 2011
gopakumarg43
  • 72670 Answers
SOURCE: Need user manual for 42"sharp aquos lcd tv
Hello
Get into this link. You can download the user manual for your device absolutely free.
www.retrevo.com > Sharp Manuals > Sharp TV Manuals
OK.
Posted on Jul 09, 2011
My TV will connect to the network but is not connected to the internet.
Check the videos to understand how set up the network connection on sharp tv . Hope it would help you to set up your tv. If you go for manual connection the you have to have some information . you can get those information from your internet provider comcast.
http://electro-medical.blogspot.com/
Easy Sharp Aquos TV Setup wifi internet network connection for Netflix apps
Wireless setup for Sharp AQUOS TVs HSN How Setup WiFi On The Sharp Aquos 60 Smart TV
Nov 13, 2015 | Sharp Aquos Televison & Video
How do I display PC screen onto Sharp TV LC26SB24? I've lost TV user manual
Depending on your OS on most computers you need to either add a second monitor output or change the settings to tell the PC to redirect the video output to and external device instead of the PC's screen. Check your OS settings.
Jan 01, 2015 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
How to reset a sharp aquos?
Hold VOLUME UP and CHANNEL UP buttons in while plugging set into power.
TV comes up in service mode.
Press CHAN + or CHAN - to select an adjustment that you want to change
Press VOL+ or VOL- to adjust
Jul 22, 2014 | Sharp AQUOS 65" 1080P Roku Ready LED 120Hz...
How do I connect my Toshiba Laptop to my Sharp Aquos to watch Netflix?
you need to see if you have a pc in (vga )on your tv and then you need to see if your laptop has a VGA out then you need a VGA Video Monitor Cable HD 15 Male to Male cable bettween the lap top and the TV.
then you need to go to control settings on your laptop (depending on what operating system you are running) then display settings-settings and set it to go to your tv .
Jan 07, 2012 | Toshiba Computers & Internet
My sharp aquos 30 inch tv will not come on. what could be the problem
Hello; I have an similar LC30HV2U for sale in my TV repair shop for $350. This is a 2 piece unit. The AV box and the monitor. I am also a Sharp authorized servicer. In the monitor there are 2 inverter boards on the right side that have an 80 % chance of causing this problem. This set counts "lamp errors" due to one or more inverters not working on startup. Once the set accumulates 5 lamp errors, It will not allow the set to come on. The first thing Sharp tells us is to replace both inverter boards. About $90 each. If those don't fix it the cost will go much higher due to a bad power supply board or bad LCD Panel. Hope this helps, John
Jan 02, 2011 | Sharp Aquos LC-30HV4U 30 in. LCD HDTV
How do I get my Sharp Aquos LC-32D43U to work as the monitor for my laptop computer. On key potential issue seems to be that the operating manual suggests pressing the "menu" button, followed by "setup"...
Not sure why u need to go to menu. If you want to connect lapotop to TV attach the cable turn on laptop and monitor and hit FN F5 the laptop screen will then be diusplayed on monitor Fn F9 turns it off
please4rate my help++++Thanks for using FIXYA
May 08, 2010 | Sharp AQUOS LC-32D43U 32 in. LCD...
My sharp aquos not working tv went off and wont
these flashing lights are error codes set by the manufacturer..
Call sharp...they will tell you the problem
Apr 26, 2010 | Sharp Aquos LC-37HV4U 37 in. LCD HDTV
How do i Adjust My 40 inch Sharp Aquos to 1080 p?
You do not adjust the resolution at the TV, the TV will adjust itself to display what you are feeding it. It works the same way as the computer monitor, which is done on the computer's video card to what ever you set it to.
Nov 09, 2009 | Sharp AQUOS LC-40C32U 32 in. LCD TV
Sharp Aquos 32 wont turn on
I called up Sharp, and if you are a part of Sharp AQUOS Advantage Program you get free in home service.
They were very nice about it, and I already have a technician coming to my house on Saturday and I called on Wednesday.
I doubt Sharp's policy alot less now!
Sep 02, 2009 | Sharp AQUOS LC-32D44U 32 in. LCD TV
Show Microsoft Power point on Sharp Aquos hdtv
try to right click the desktop and choose graphics options, you will have to select the correct output for your setup. i.e. laptop to monitor, etc etc see if that works,...sounds like you have a connection, you will have to play with these settings until it pops up. worked with a similar scenario, sometimes you have to do stufff twice and it works on the second time not the first, electronics are weird.
keep changing the settings in the graphics options until it comes up the way you want it.
Nov 13, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sharp Aquos LC-32G4U 32 in. HD-Ready LCD Television Logo
4,436 people viewed this question
Top Sharp Televison & Video Experts
Dave Naylor
Dave Naylor
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
