Fisher and paykel c370 wiring diagram - Washing Machines
4 Suggested Answers
  • 353 Answers
SOURCE: i think a green and yellow wire has come off my
green and yellow stripe is the earth wire
Posted on Dec 15, 2009
  • 14 Answers
SOURCE: Diagram for FisherPaykelGWL15 pump removal
just press the tab in and twist the pump couter clock wise it will come out .make sure the display still havd power most of the time the water leaking from the water pump killed the pump and dammaged control board too.good luck
Posted on Feb 11, 2010
  • 30 Answers
SOURCE: Fisher Paykel Intuitive Eco Washer - IWL15: what is error code 136 on a fisher & paykel IW...
fault code 136 is a hard one possible causes are faulty rotor speed sensor on motor,siezed bearings or rotor,motor windings ,or motor control module, would suggest you get a tech for this one to diagonse correctty ,without proper tools to test eg: rss tester you could cot yourself more money... hope this was some help....:)
Posted on Jun 08, 2010
Fisher & paykel c370 fridge, is leaking water and collects in a puddle under the veggie crisper. How do I fix.
a common,locate and check drain hole it is probably blocked i use a peice of curtain wire to clear the bock should be fne after that, also make sure unit lens backwards slightly by adjusting front feet if neccessary
Feb 09, 2018 | Fisher Refrigerators
Fisher paykel wiring diagram
From my dealings with Fisher Paykel they do not produce wiring diagrams as all components lead into the main PCB
Apr 08, 2014 | Refrigerators
I have a Fisher & Paykel model C370 fridge which is constantly icing up at the bottom of the rear condenser panel, causing puddles in bottom of fridge and on floor.
Sounds like either your defroster heater motor or your defrost timer has gone bad. Generally not user serviceable. Call an appliance repairman and have them fix it for you.
Feb 16, 2013 | Refrigerators
Fisher and paykel washing machine model GW709AU wont complete spin cycle. Seems to run at slow speed but cuts in and out on medium .
see this causes:
1) cold water there are NOT fix it
2) Timer defective, repair or change see the diagram, clean contacts, wires loose, broken, or burn. God bless you
Jun 21, 2012 | Fisher and Paykel Washing Machines
Fisher paykel wont power on
see the diagram and proceed according:
1) test the timer dirty contact, loose wires, burn and repair or replace
2) lid switch defective will not start the machine
3) c.breaker tripped or blown fuse
4)motor faulty.
God bless you
Jun 19, 2012 | Fisher and Paykel GWL11 Top Load Washer
Looking for a wiring diagram for a Fisher and Paykel 920 Dishwasher control panel
You can get one from the link below they will have to email it to you but they have them on file,
http://www.appliancerepairlesson.com/
Mar 08, 2011 | Fisher and Paykel Dishwashers
I have a model C370 Fridge and has water accumulating at the bottom of the fridge. When I looked at the drain at the back of the fridge it is all iced up.
Happens.....,syringe it out with clorine bleach to clear out any "growth".then dry out the fridge,try to cover all wet food with cling film, to cut down on condensation.drain should be cleaned monthly.....
Sep 24, 2010 | Fisher and Paykel Active Smart E522B...
Washing Machines Logo
Top Washing Machines Experts
