Question about Whirlpool 30" Self-Cleaning Freestanding Electric Range - White-on-White
I have a Whirlpool Stove, model SF367PEYQ3. When we turn the oven to 'BAKE', it takes 1-2 minutes to light. When it does light, it lights with a small explosion and we can smell gas. I took up the oven floor and flame spreader and the ignitor glowed bright orange. I turned it off before it light and while it was on, there was no gas smell nor was there any sparking. What should I replace to get the oven working safely again? (The broiler works fine.)
  • Official Brand Answer
  • 362 Answers
We're sorry to hear about your Range. Can you please email your address, phone number, the model and serial number, the website you were contacted on, Fixya, your review ID, and date of purchase to Whirlpool_Digital@whirlpool.com so we may look into this?
Posted on Jun 16, 2017
3 Suggested Answers
  • 117 Answers
SOURCE: My stove works and so does my broiler. I replaced
If you use a multimeter, you can test the gas valve where the white and yellow wires connect is where your terminals for bake on that valve are. If you have continuity there, then check to make sure that igniter is wired ok.
http://tclaundryrepair.com/home
Posted on Feb 19, 2009
Macmarkus
  • 2605 Answers
SOURCE: Gas oven won't light and the broiler won't light
Hello, welcome to FixYa.
I've read your previous post's and can see a couple of scenarios have been thrown out there, so this may just add fuel to the fire...no pun intended.
It sounds to me like a tripped hi-limit safety thermostat is the culprit, hence neither ignitor so much as glows. I'll explain. If the valve where faulty the ignitors woul;d still glow as it is the ignitors which allow the valves to open not the other way around.
Further to that, if the ignitor where faulty, it is unlikely it would be both at the same time, however if a hi-limit safety tripped it shuts down power to both the broil and bake ignitors thus no oven function at all...that is it's function "safety".
The hi-limit safety on your range is on the back wall so you need to slide the oven out (if you haven't done so by now) to inspect it. To do so is pretty easy, one of two ways.
You can jump across it to see if it allows the oven to operate or you can ohm it out with a meter. it should simply be a closed circuit if good, open if not. It is the non-reset type unfortunately so you'll need to replace it.
example
It is part number 8300802 and available at "repairclinic.com" or "searspartsdirect.com" to name just a couple.
Let me know what you find and I'll be glad to help you moving forward from there. Good luck.
Regards,
Macmarkus :)
Posted on May 31, 2011
I hav whirlpool accubake.oven wont stay lit.it ignites then flame goes right back out
Whirlpool oven won't light - Appliance Repair Forum
forum.appliancepartspros.com/oven.../225907-whirlpool-oven-wont-lig...
May 19, 2011 - 10 posts - ‎2 authors
I have a Whirlpool Accubake oven (SF362LXSS0) that doesn't seem to be consistently turning on, and the problem's getting worse. ... If I try to turn it on to bake, I hear several clicks, but not that "gas oven turning on" sound and no heat comes out (but a slight smell of gas is ... Whirlpool Gas Oven won't stay lit
1 post
Oct 25, 2012
whirlpool oven won't stay on
1 post
Aug 13, 2012
Whirlpool Gas Oven Will Not Stay Lit
Jun 20, 2012
whirlpool accubake oven will not stay lit
1 post
Nov 9, 2009
More results from forum.appliancepartspros.com
Whirlpool Accubake Model # GW395LEGQ4 - Oven won't Start ...
Dec 12, 2015 | Stoves Ovens
Frigidaire Self-Cleaning Oven Model FEF353BFW and F1 Error Code.
I just had the same problem! If I ever see that f9 again and hear that annoying constant beep....I will pick up and dispose of that oven on the front lawn. Lol. Took a pair of pliers and turned the lock clock wise till the light went out. Silence!
May 02, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
Whirlpool gas oven will not heat
most likely you have a bad ignitor,pull out the racks and remove the floor to the stove,turn on the bake,if the ignitor glows but it takes more than 40 seconds for the flame to light you have a bad ignitor even though it glows and if it doesn't glow at all the ignitor is bad,also if the broil lights on top and the bake doesn't change out the ignitor.next time send the model number and i can look up your machine to help you better.
Nov 15, 2011 | Whirlpool Ovens
Whirlpool M# SF330PEWW3 ignitor comes on, but there is no gas for the oven to light. Stove top works fine.
The problem beleive it or not is that the bake ignitor is weak ,and it is not drawing the proper amprage to open the gas valve.If you have a amp meter access the wires to the bake ignitor(usually behind the storage drawer) and check for 3.3-3.6 amps when set to bake ignitor by clamping the meter around ONE wire wire of ignitor make sure only one wire,either one and not both.
if amp draw less than that replace bake ignitor. If you dont have amp meter take my word for it since in my 30 years appliance repair career i have seen when the ignitor comes on, that it's weak and found it to be the problem 100% of the time
Jul 31, 2011 | Ovens
I have a Whirlpool GS773LXSS gas range. You press bake, it clicks once and doesn't heat up at all. Press Broil, clicks twice and doesn't heat up.
Is the gas turned on to the stove? Is the pilot light lit?
Any special circumstances surrounding this incident? like this stove is new or old. Or you are new to gas stoves etc.
Apr 09, 2010 | Tecnik TKC195/3 Electric Single Oven
The oven will not light on my Whirlpool gas oven Mod SF368LEPQ 2. The stove top burners still light.
Sounds like you need an bake element ignitor if the bake doesn't work but if the broil also doesn't work, it could be the electronic clock/timer control. the part number for the bake ignitor is 8054129 .Best off to call a reliable service company such as Sears.
Jan 31, 2010 | Whirlpool Ovens
My oven broiler does not seem to be working-I turned it on broil for about 15 minutes - no heat, nothing. On normal bake, it takes about a half hour to heat the oven to 350 degrees - my old stove took...
check the bake (lower) element, mine just went out. It was easy to spot the problem once I pulled the element out, the wire had burnt off the end. Please remember to turn the power off first.
Nov 28, 2009 | Whirlpool RBS275PD Electric Single Oven
I have a whirlpool gas stove, the bake or broil will not light.
Check to see if the electric ignitors are connected at the ignition module, located under the top surface panel. It is possible that the wire(s) that go to the oven ignitors has burned off or become disconnected from the main spark module,
It is also possible that the electrodes have failed and need to be replaced. These are the two (2) devices that produce the spark (and make the clicking sound) inside the oven compartment.
If those are OK, then check the thermostat, as it could be faulty and preventing the oven from functioning.
If you can smell gas when attempting to turn the oven (bake or broil) then the valves are good, if you don't smell any gas, the gas supply valves (one for each bake and broil tubes) need to be checked.
You might also try lighting the oven manually with a long match or grill lighter to rule out faulty gas supply valves or a faulty thermostat, which if you can manually light the oven, it would prove that the ignitors must have failed.
Here's the exploded line drawings for your stove along with the parts list, just click on each section to see the parts. You can order replacement parts from them as well.
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?pop=true&modelNumber=gw395lepb02&pop=flush
Hope you find this Very Helpful and best regards!
Aug 28, 2009 | Ovens
Bake and Broil not working
Product manuals
Product manuals are available for most in-stock items.
Order a product manual by calling 1-800-366-PART (1-800-366-7278). Or download a free product manual at ManageMyHome.com.
Aug 01, 2008 | Kenmore 33169 Gas Single Oven
Faulty bake or broil element
The solution to this problem depends on whether the oven is electric or gas. Electric oven. If your electric oven's bake or broil element isn't working properly, either it isn't receiving electric power or the element or the oven control may need to be replaced. In many cases, the wiring to the elements can be burnt or broken. 1) Be sure the controls are set on the proper setting. 2) Be sure the stove is plugged in and/or check the circuit breaker or fuse that serves that circuit. 3) Call an appliance repairperson or replace the element yourself as follows. 4) Unplug the oven and let any hot parts cool. 5) Unscrew the mounting screws that secure the element bracket to the oven and pull out the element far enough to access its terminals. Note which wires are attached to each of the terminals, then disconnect the wires (pull off the wire clips or unscrew the wires). 6) Take the element to a parts dealer, along with your oven's model and serial number, and buy a replacement (preferably the manufacturer's suggested replacement part). 7) Reverse the process to reinstall. Gas oven. When a gas oven doesn't get hot, it generally means that it isn't receiving gas, the gas valve isn't distributing gas to the oven burner, or the ignition system -- either an electronic ignition or pilot light -- isn't working properly. A common problem with ovens that have a pilot light is that the pilot light has gone out. NOTE: Gas ranges younger than 10 years old have a sophisticated fault code system that governs their ignition. Always call an approved warranty service provider to handle problems with these ranges. Here's how to troubleshoot your range: 1) Be sure the controls are set on the proper setting. 2) Be sure the stove is plugged in and/or check the circuit breaker or fuse that serves that circuit. 3) Check the gas valve to be sure the gas supply is turned on (also make sure the house's main gas valve is turned on). 4) On a stove with a pilot light, make sure the pilot light is burning. If it isn't, re-light as discussed HERE, or in your owner's manual. 5) Adjust the pilot flame (older stoves only). 6) Turn off the gas and unplug the stove (or turn off its circuit at the electrical panel). 7) Clean out the oven burner ports, using a stiff wire. 8) Plug in the stove (or turn on its circuit) and turn the gas back on. Re-light the pilot (if it has one). 9) If the oven still doesn't work, call an appliance repairperson.
Jan 18, 2006 | Jenn-Air JJW8530C Expressions Collection...
Whirlpool 30" Self-Cleaning Freestanding Electric Range - White-on-White Logo
47 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
ashburton
Sal DeAngelo
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
