Question about Panasonic DVD-LS90 Portable DVD Player
My dvd ls855 panasonic player only displays 1/3 of the screen. The rest is just whiteout.
    New Friend:
  • 62 Answers
Check to make sure the wires are making a good connection and restart the system.
Download Panasonic DVD LS855 Manual
Posted on Mar 18, 2015
4 Suggested Answers
Danmart
  • 291 Answers
SOURCE: Dropped PANSONIC DVD-LS855 and screen displays garbage HELP
Do you want a changellage? Do you know how to solder? With a pencil thin soldering gun ? open the equipment(dvd) and carefully look for a cracked board. If anything, RESOLDER every large 'bump' of solder on the circuit board. they are usually ground or return paths for electricity and the "DROP" could have loosen the solder connection.
lots of luck
Posted on Nov 07, 2008
Danmart
  • 291 Answers
SOURCE: Panasonic DVD-LS855 wont play to LCD TV
Did you turn on the input of the tv to receive 'external' input.? Did you plug the DVD into the right input?
  • 78 Answers
SOURCE: Panasonic DVD-LS855 This player suddenly stopped
It could just need a good cleaning. Get a lens/head cleaner...they are around $6 at Target. Try that....if that doesn't work then is probably is a hardware issue and should just be replaced. It's not worth it to get it repaired as it would probably cost more to repair it then buying a new one straight out. Especially since you can find DVD players for as little as $20 now-a-days.
Posted on Nov 30, 2010
On my Panasonic blu-Ray DMP-BD871 the screen says set 1 when I press the remote... Why is this happening I can get on to use my blu-Ray at all
Your DVD recorder remote control can be programmed (with different codes), so it can be used with multiple Panasonic DVD players.
When you press a button and the display shows [ CHK REMOTE # ] or [ RC# ] or [ SET# ] it means that the DVD recorder and the remote control are not set to the same code.
To set the remote control code to that of the DVD recorder, press and hold [ ENTER ] as well as the corresponding code number on the display (1, 2 or 3) at the same time for more than 2 seconds.
May 24, 2014 | Televison & Video
NO sound on portable DVD player after plugging headphone
One of two situations: Plugged in headsets connect to contacts inside of the female port on the player. If any of the internal connections within the female port are shorted the player switching component will not disconnect and thus the player speakers will not function. Could be dirt, metal particles from the surface of the head phone pins, or just a defective female jack. You may try to insert a small round probe (like a tooth pic etc.) saturated with rubbing alcohol and twirl the probe around to collect any deposits off of the integral connectors. Be careful Not to break the probe off inside of the port. If after this attempt the same problems exist; only a qualified technician can observe the interior of the player for electrical disfunction.
Dec 22, 2013 | Panasonic portable dvd player DVD-LS855...
PANSONIC DVD-LS855 screen cracked
You could always try to replace the screen by trying to find one on eBay or some other used market that is broken, but has a good screen. Then simply swap screens.
Dec 20, 2012 | Panasonic DVD-LS90 Portable DVD Player
Panasonic DVD-LS855 This player suddenly stopped reading disks. The "Carriage" clicks repeatedly and a message on the screen says that it cannot read the disk. Is this a simple fix? Is it...
Nov 30, 2010 | Panasonic DVD-LS855 Player
Remote won't work
According to page 15 of the manual, you should "Press and hold [ENTER] and the indicated number button at the same time for more than 2 seconds" This will work for SET 1, SET 2, etc. If you have lost the manual for the DVR/Remote you can download a copy at http://service.us.panasonic.com/OPERMANPDF/DMRES15-MULTI.pdf
Jan 02, 2010 | Panasonic DMRES15 DVD Recorder
lots of luck
Nov 07, 2008 | Panasonic DVD-LS90 Portable DVD Player
Jun 18, 2008 | Panasonic DVD-LS90 Portable DVD Player
Help w/ panasonic burner
I own one and it is a pain to work. Put in the disc and vhs tape and hit the bottom right button, I believe it says DVD and above it says dubbing. Hold it for a few seconds and the screen will come up and the system will do the rest recording from your VHS tape to the disc. You MUST finalize the disc after you are finished if you want to watch it in another DVD players if not it will only work on the Panasonic. Hope this helps. If not here is the site for the owners matual http://www.panasonic.com.au/support/downloads/file_type_results.cfm?fileTypeID=2&productCategoryID=54
Dec 06, 2007 | Panasonic DMR-E75V DVD Player/VCR
Panasonic DVD-RV32
dvd wil not function and screen display f498 i need help
Dec 01, 2007 | Panasonic DVD-RV32 DVD Player
Digital optical from DVD player produces no audio
Hi, It sounds like your receiver is still looking for audio on the coaxial connection, rather than the optical.
1. Make sure the optical connection is between your DVD player and the LD/DVD Optical In on the back of your receiver.
2. If you have a monitor connected to the receiver to show the on-screen display, click Setup from the main menu, click Input Mode, then, next to LD/DVD choose Optical. It may be set to coaxial, analog or auto.
Alternatively, choose the input source on the front of your receiver (LD/DVD), then press Input Mode button (bottom right, near the input selector) till it displays Digital Optical.
If all else fails, reset the receiver by:
1. Turn off the receiver
2. Hold down DISPLAY and PANEL UP/DOWN buttons and press power.
3. All Clear should appear on the screen.
Use caution, however, as this will erase all the settings in your receiver.
Nov 28, 2007 | Sony STR-DA90ESG
Panasonic DVD-LS90 Portable DVD Player Logo
55 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
