Question about Bosch Dishwashers
Bosch SHE55C dishwasher/Upper rack doesn't always spin
  • 641 Answers
SOURCE: dishwasher leaves residue in top rack only
Most cleaning problems are caused by the dishwasher not getting enough water. It could be cause of the switch level, which control water level in the tub. The switch level is usually a diaphragm device with a small clear tube attached between the switch and the bottom of the washer's outer tub. I am not familiar with your machine, but if you will open the rear panel you will find it easily. Be aware you should discoonect the power cable !!! Clear the tube (attached between the switch and the bottom of the washer's outer tub) from any obstruction.In case it will not solve the problem, you should replace the switch. Good luck !
Posted on Jun 01, 2006
SOURCE: Bosch SHX46A dishwasher
I have a Bosch SHX46B05UC/14 and it stopped functioning right. It filled, it ran, it drained, it sounded okay, but I finally determined there wasn't enough circulation pump pressure to swing the spray arms. Turns out the problem was a pump pressure adjustment screw, accessible under the kick plate, had backed off--now if I can only figure out how to set it properly, low enough to clean the glassware, high enough not to break the pots and pans--or is it the other way around. I also found some beans in the drain sump (easy to remove cover plate from inside with a torx driver, large object trap not locked down properly and a riser for the upper spray arms not press fit sufficiently into pump outlet (I wonder if I blew the line while setting pump pressure. I AM looking for guidance on how to properly set the pump pressure, for the moment, I simply turned it into its spring loaded range and cranked it down a few turns.
Posted on Dec 02, 2007
aborcass
  • 2651 Answers
SOURCE: Upper Rack not cleaning
id try removing hte lower filter plate . 5 torx 15 screws will gain oyou acess to lower sump and 2 more torx screws that will acess you the chopper assy, prhaps filled with debris not allowing good water flow,
Posted on Mar 25, 2008
SOURCE: Not cleaning upper rack
You'll need to clean the food chopper in the base. Make sure you've got a torx screwdriver.
http://forum.appliancepartspros.com/dishwasher-repair/8174-kitchen-aid-dishwasher-wont-clean-top-rack-items.html
Posted on Nov 06, 2008
SOURCE: middle arm of dishwasher not spinning
I'm the one that reported the same problem in November as "Guest". I fixed mine finally. I removed the middle arm again and noticed that the holes that spray a jet ot water causing the arm to turn aren't the ones on top. On the bottom of the arm there's a small hole at each end. I looked and one of the holes had a small piece of crud in it. I had to use the tip of an ice pick to dislodge it back into the arm. I then ran water into the arm several times hoping to get the item completely removed. I never did see anything come out but I then ran water through the arm holding it so the water could run out one end. The piece didn't show up in the hole again so I tried washing it to the other end. It still didn't show up so I guess it must have washed out the first time. It's been 3 or 4 weeks now and the arm is still functioning perfectly. Hard to believe that one little piece of trash can cause so much irritation. Good luck on this being the problem for others.
Posted on Jan 08, 2009
My bosch dishwasher (SHX46A05UC) has 2 problems:
there is not a manual for that kind of troubles,,,about the propeller is atached to the upper rack wout tools,,remove the plastic frame is in the lower of the upper rack and assembled backusing only your hands...theouter handle ...inside around the door have scrws remove thoes,you can see the loose srews of the handle,,
Feb 06, 2013 | Bosch 24 in. SHX36L05UC Stainless Steel...
Upper spray arm on my Kitchen Aid dishwasher (8573025) doesn't work.
Arm operates(turns) by water pressure. If it does not turn no water is going to the top spray arm. make sure the setting washer is on does not preclude the top spray arm from operating(read manual). If not check arm by spinning by hand to make sure it is free. If arm is free and it still does not turn when DW is running than there is a restriction in the tubing to the upper spray arm or the check ball or solenoid are not operating correctly.
Mar 01, 2012 | Dishwashers
The top spray arm of my Bosch SHE6AP05UC seems to have fallen off during a cycle and I cannot reattach it. It doesn't seem to snap or clip in like it looks.
Hello, welcome to FixYa.
If you align the spray arm to the section of the upper rack which it fastens to, as shown here...
Then place it against the holder and turn, it should grab the holder, unless something else has broken...but it should be that simple, i.e.
This is the official explanation from Bosch below...
Hopefully that will help you move forward and answer you question. Let me know if you need any further assistance, otherwise good luck.
Thanks for visiting FixYa.
Regards,
Macmarkus :)
Aug 13, 2011 | Bosch SHE6AP05UC 24 in Builtin Dishwasher
Tablet keeps coming out of the dispenser on my hotpoint fdl 570 dishwasher on all cycles and falls on to the floor, result is that the crockery isn't always clean on the top tray. Machine is still...
Hi Jeanette,
Maybe I misunderstood your question, but the tablet is supposed to come out of the dispenser and fall into the bottom of the dishwasher. It needs to fall into the hot water in the bottom of the washer to dissolve. The dispenser releases the tablet at different points in the cycle depending on which wash cycle is selected. On a shorter cycle it will be released soon after starting. On longer cycles, there is usually a rinse first, so the tablet will be released a little later. There would only be a problem if the tablet wasn't being released, or wasn't dissolving completely.
There are a number of reasons for poor cleaning on the top rack. The most common are the upper spray-arm not spinning, incorrect stacking or overloading. If the upper spray-arm isn't spinning, there may be caused by a blockage in the spray-arm or the water delivery system, but, as the dishwasher is new and it's not happening every time, it's possible that the dishwasher isn't levelled correctly. The spray-arms aren't motorised, they use water pressure to spin, but they wont spin if they aren't balanced, i.e. the dishwasher isn't level.
You can check whether the spray arm/s are spinning by pointing them front-to-back, or left-to-right (so you can remember the position) and allow the dishwasher to run for a few minutes. Then open the door and check the position of the spray arms. They should continue to rotate slowly for a short while after opening the door, but if they're in the same place and static, they're not spinning. I'd suggest repeating this a couple of times to eliminate the possibility of them having stopped in the exact same place you left them.
If the spray arms are spinning, test the dishwasher with only a small load in the top rack. If the top rack comes out clean with a small load, you may be overloading it or stacking it incorrectly some of the time. There should be a correct stacking guide in your user manual.
Hope this helps. If you need further assistance, check whether the arms are spinning then post back.
Regards,
BElectric
Jul 03, 2011 | Dishwashers
Both upper and lower water dispensing devices are not spinning
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
When my wife started complaining about her dishwasher not getting the top rack clean this is what I found and I wrote a tip about it...
Dishwasher Spray Arms not Spinning
heatman101
Sep 01, 2010 | Bosch 24 in. SHX46A02 / SHX46A06 Built-in...
Bosch SHU 8805 upper arm is getting no water.
replace the upper water arm conduit and wash arm hub as they leak under years of pressure and the o-rings leak water and then it can't hold pressure and supply the upper arm with full pressure water,also replace the center arm conduit if it has one as this will wear out too
Mar 23, 2010 | Bosch 23 in. SHU 8805 Built-in Dishwasher
I have a bosch dishwasher, SHU535E05UC/14. The
the spray arms are not rotating check they spin freely if they do remove them and clean any residue food deposits blocking holes for water spray.
Jan 15, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
there is a new product out that actually filters the water going into your dishwasher. I use to have ugly,white and cloudy looking glasses until i installed this product. after the first load my glasses looked fantastic!!!! its affordable and you can get it at dishwasherfilter.com.
Apr 01, 2008 | Bosch 24 in. SHE56C05UC Stainless Steel...
Upper Rack
Contact Bosch and ask if there are any other rack configurations for this model. From memory I think there might be 1. I also remember that they made an insert to go into this particular top draw...check on that also Regards
Jul 13, 2007 | Bosch 23 in. SHU33A Built-In Dishwasher
Dishwashers Logo
19 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
