Question about HP iPAQ rx1950 Pocket PC
My hp rx1950 won't turn on after a while
My hp rx1950 wont turn on after a few hours. I then have to pull out the battery, restart the whole device. After that, the PDA works 100% fine. I can even turn on and off the device. The battery is 100% too. As i think that the device is alright, I put it back into my bag. After a period of time(maybe over an hour) , when i want to switch on the device to check my timetable. It wont turn on again. I have to pull out the battery for the second time. Then it will work fine, but later the same thing happens. This dead loop has gone on for the whole day already.
  • 84 Answers
There could be a piece of software running that is locking up the device. You might want to check for updates to your PDA and any software you have installed on it. If that doesn't work try doing a hard reset, which will erase everything, then reinstall one application per day to see if the problem pops up after one of the applications is installed. If that doesn't work, it could be hardware issue, if there is an extra storage device in it pull it out and see what it does. You will have to troubleshoot. Try different things and see what the result is, eventually you'll be able to narrow it down.
Posted on Jun 25, 2007
Won't start ~ rode a few hours then parked it ~ turned on key no lights came on ~ i checked the starter connections ~ all fine there nothing ~ ran great before
there is a high possibility the battery is dead. or maybe the bike isnot charging the battery. i suggest push starting it then ride it a few blocks and shut it off pull the key and then start it again...it might be the attery wont hold a charge...if thats the case then replace it but do that before messing with the stator. hope this helps good luck!
Jun 03, 2011 | 2006 Honda VTX 1300 S
Have had a HP ipaq rx1950 for about 2 years and last month it has stopped charging the battery. I bought 3 batteries and each one does not charge. I put these batteries in another person's ipaq and...
its just 3 things.
1; battery
2: charge regulator on the device.
3: power pack
one is bad.
so its not battery, now its #2 or #3
seen the regulator is toasted
very common
why not buy as used spark same device, and mix part to get good
or ditch it and upgrade,
Mar 12, 2017 | HP iPAQ rx1950 Pocket PC
Pavilion dv9308nr PC Notebook: hp dv9308nr wont power on all the time... works if...
Due to regular use of the notebook, some static charges tend to stay in the computer, and sometimes results in not allowing the computer to function properly.
Please follow the power drain procedure to confirm the same:
1. Disconnect the AC Adapter.
2. Remove the Battery.
3. Hold the Power button down for 30seconds to 1 minute.
4. Put the Battery in.
5. Reconnect the AC adapter.
6. Turn on the Notebook power.
7. Restart the Notebook.
If the Notebook boots up you may fix the battery back. Try restarting the computer only with the AC power, without the battery & vice-versa. If the issue still persists then I request you to reset the memory modules, as sometimes the memory module connection get loose.
May 17, 2010 | HP Pavilion dv9308nr Notebook
Will not connect to the wifi conecction point
try to check the web key of the wifi if it will match on your hp.
I’m happy to assist further over the phone at https://www.6ya.com/expert/ramy_d9e7ebea3891f482
Jun 09, 2009 | HP iPAQ rx1950 Pocket PC
Needs to press soft reset to wake it up
there are some suggestions here:
http://forums12.itrc.hp.com/service/forums/bizsupport/questionanswer.do?admit=109447627+1219422830354+28353475&threadId=1000428
i'm trying the activesync fix.
Jul 05, 2008 | HP iPAQ rx1950 Pocket PC
Hp rx1950 battery life.
I have the same problem, after I did the hard reset and installed no programs, this power problem disappeared. But once i installed any programs, PDA battery life became no longer than 2 days, which is strange.
Jan 06, 2008 | HP iPAQ rx1950 Pocket PC
Flashing Light
I have had a HP Photosmart 945 for a few years now. A few days ago was the first time I saw my camera experience the problem described above. I thought something is wrong with the on-bard logic.
Replacing my batteries (4x2300mAh NiMH AAs) with four other freshly charged batteries of the same kind didn't fix it. The camera's LCD kept flashing on and off for almost an hour until my family got tired of it and turned it off by removing the batteries.
I just replaced the rechargeable batteries with four regular alkaline batteries and now suddenly it works. Go figure.
The moral is that changing the batteries sometimes helps. When it works, it will get your camera going for a while. The problem, however, doesn't seem to be battery-related or I would have seen it a long time ago with smaller-capacity batteries like alkaline AAs. Something is very wrong with the camera itself, that much is clear.
Best-case scenario now is that I have an unreliable camera that can give out at any moment. For example today it died in mid-shot and almost spoiled a family event. For me the solution was "get a non-HP camera".
I hope this helps someone out there.
Dec 19, 2007 | HP Photosmart 945 Digital Camera
I can send it to you. Where can i find english rom image?
Nov 29, 2007 | HP iPAQ rx1950 Pocket PC
HP iPAQ rx1950 Pocket PC Logo
146 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
