RunCo VX1000c RS-232 communication codes
I just got this from a friend and there is no remote. i need the rs-232 comm codes to power this thing on. and how to connect it to a PFP
  • 3 Answers
Hi Kevin,
The manual for the RuCo VX1000c is available at http://www.aboutprojectors.com/pdf/runco-vx-1000ci-manual.pdf
The RS232 codes and protocols are towards the back of the manual. According to the manual, the PFP connects to the projector using a CAT5 cable.
HTH.
Posted on Jan 03, 2013
3 Suggested Answers
SOURCE: RS 232 control
..did you ever solve this? i am trying to write some code to do the same thing with no luck at all. and the manual does not seem to help much besides letting me know that I have to use 'PON' and pad it with a start bit and an end bit. i find nothing online as well.
Posted on Jun 28, 2010
  • 146 Answers
SOURCE: How do you use the
you will need to get an RS232 compatable remote and wire it together
usually this will only control power on and off and not much more
this is usually done only in commercial set ups are you using it at home or work?
you would be best off getting a pro to install and load/ write code for you
Posted on Apr 15, 2011
I´m looking for a typical
For connecting a RS-232 port with a RS-485 port you need a signal level adapter since they work with different voltage and signal types, RS-232 uses unbalanced signals and RS-485 uses balanced signals, if you want to build your own adapter please check the following schematic as a reference:
Feb 21, 2011 | Computers & Internet
Tip
Options for Adding Serial Ports The serial port is prevalent on PC's ...
The serial port is prevalent on PC's as well as scores of industrial, scientific and consumer devices, making it a convenient starting point for communications. Since RS-232 itself is only suited to short connections (50 ft. max.) many applications require that it be adapted to fit requirements. RS-422, typically used for extending RS-232 communications, provides full duplex communications between two devices. It can also provide one way communications from one master to several slaves. RS-485 communications standard allows cable lengths up to 4000 feet. It also provides very high noise immunity. Multidrop connections up to 32 different nodes can be made over a single twisted pair cable along with a signal ground connection.
This article summarizes the choices a system designer has when adding a serial (RS-232, RS-422, or RS-485) communications device. There are many different ways to add additional serial ports to your Desktop PC, Palm, or Laptop PC. USB, PCMCIA, PCI and ISA are some of the methods that will be discussed.
The Universal Serial Bus (USB) provides a high data rate and Hot Swap connection for PCs, providing an easy connection to a wide variety of multimedia and network USB devices. Generally considered to be for home or office use, USB is finding its way into Industrial applications.
PCMCIA Serial Ports are yet another way to add serial ports to a PC that has PCMCIA Slots available. Most Laptops today offer only one (if any at all) DB9 type serial ports. A PCMCIA Serial Card is a good way to add a serial port (or ports) to any laptop that is low on available serial ports (RS-232, RS-422 or RS-485).
PCI Cards are becoming more popular as a way to add serial ports to desktop PC's. PCI type slots are becoming the "norm" in standard PC's today, and PCI Serial Cards are an excellent way to add serial ports. The standard Desktop PC may only come with one serial port standard (if any serial ports at all). PCI Serial Cards use Software Drivers to address the ports to the PC.
ISA Cards are yet another way to add serial ports to the older desktop PC's. ISA type slots are becoming scarce in standard PC's today, but are still an excellent way to add serial ports. The ISA Cards are typically addressed using dip switches and shunts or jumpers to set IRQ's for each port. No Software Drivers are required with ISA style serial cards.
Palm OS PDA's may be connected to RS-422 or RS-485 data circuits using Palm adapters. These adapters offer total portability for collecting data and field service chores. The Palm device and the adapter will usually slip into a shirt pocket. Some models use the PDA's connecting cable, some include a cable and some are cradles that allow the PDA to nest in place and connect directly to the Palm base socket. PalmTerm Freeware allows you to transmit and receive data from the Palm serial port.
on Sep 12, 2010 | Computers & Internet
Heena has only rs 2 and rs 5 coins,in her purse. if in all she has 80 coins in her purse amounting to rs 232. find the number of rs 5 coin.
Is this a maths school problem?
You need to use algebra -
2x + 5y = 232 (heena has a number of 2 and 5 coins in her purse which add up to 232)
x + y = 80 (heena has x number of 2 and y number of 5 coins which tally to 80)
therefore, x = 80 - y
so going back to first equation, 2(80 - y) + 5y = 232
160 - 2y + 5y = 232
3y = 72
y = 24
and going back to x, x = 80 - y
x = 80 - 24
x = 56
so heena has 56 rs 2, and 24 rs 5. So the answer is 24.
Jan 26, 2011 | Computers & Internet
Can ADAM 4051 module can be connected to LAN Net . If so please give me the connectivity Diagram.
Seems not possible directly. ADAM-4561 is basically an USB to RS-232 converter, so you need a RS-232 ( Serial) to Ethernet converter again.
Dec 03, 2010 | Advantech ADAM-4561 (ADAM-4561-A) Serial...
Rs-232 set up codes for the sharp xg-c335x
you can fined rs232 commands on the CDROM that comes with the projector.
Nov 05, 2009 | Sharp Televison & Video
Need configuration and reset barcodes for Symbol LT1820-I100A
Hi, the LT1820 is strictly an RS-232 device. The Product Reference Guide can be found at the link below and the Set Defaults barcode is on Adobe page 47 of 105.
http://support.symbol.com/support/search.do?cmd=displayKC&docType=kc&externalId=0804302bpdf&sliceId=&dialogID=14395378&stateId=0%200%2014391883
This scanner's default RS-232 settings are 9600 baud, Even parity, Two stop bits, 7 data bits, and no hardware or software handshaking. Standard RS-232 is normally 9600, 1 stop bit, 8 data bits, no parity, no hardware or software handshaking. I hope this information helps.
Oct 10, 2009 | Motorola Computers & Internet
Want to connect to my computer
What connector/interface does your PC has
9-pin or 25-pin connector
If it has 9-pin connector: use the following:
DB-9 RS-232 Serial Connection
or
DB-25 RS-232 Serial Connection
If it has 25-pin connector: use the following:
DB-25 Serial Connection
or
If you are configuring the computer to use an RS-422A serial port, you need a special cable. Contact the computer or printer network manufacturer to see if an RS-422A cable is available. If no cable is available, contact your computer manufacturer for your computer pin assignments and have a cable constructed.
The default configuration for the serial port on the printer is for RS-232C serial communication. To set the printer to use RS-422A serial communication, change the control panel Serial Menu’s SERIAL setting to SERIAL=RS-422.
Oct 29, 2008 | HP LaserJet 4 plus Printer
Rs 232 port in the HP 48GX
Try http://www.fixthatcalc.com/. A friend of a friend sent his HP 48 in for repairs. You may want to check into them.
Sep 22, 2008 | HP 48gx Calculator
Rs 232
try unplugging and uninstalling the rs232 and reboot then turn off then plug the cable back in and turn on. it should detect and install.
Oct 28, 2007 | HP (158800-001) for Compaq Presario 1246,...
PSC QuickScan GP5385-104342 RS-232 / DOESN'T WORK!
I think the problem you all are having is that this model of scanner requires a "decoder" to work correctly. It is another box which goes in-line between the scanner and the RS-232 port or ps/2 port of the pc. I'm not 100% positive about this, but I am pretty sure this is the problem. You need to look on e-bay for a psc barcode decoder.
Dec 15, 2006 | PSC Quickscan GP5385 Handheld
78 people viewed this question
jasbo
jasbo
