Question about Philips Magnavox 55P9271 55" Rear Projection Television
"Halo" Effect My Phillips tv is about a 60 inch and is a few years old. Whats going on is that many things on the tv (mainly white colored items) Have a glow or what I call a halo around them and I am not sure how to fix.
  • Philips Master
  • 3,459 Answers
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Posted on Jan 26, 2009
  • Edward
    Edward Feb 12, 2009
    Your TV most likely has one of two possible problems.
    Problem #1: Convergence Chip Failure ( common problem )
    Here are some of the most common symptoms and example photos of a convergence problem
    • Screen looks 3D
    • Colors don't line up
    • One or more colors can't be adjusted when using the convergence menu.
    • Screen is bowed or warped.
    Here is a quick test....
    Using your original remote go-to the tv settings then goto the convergence section.
    Try to adjust the red and then the blue convergence.
    You should be able to move them up, down, left, and right.
    If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
    Solution #1
    You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
    Problem #2 CRT Fluid is Cloudy
    Picture of a set that needs the fluid changed.
    TV set after fluid change
    Solution #2
The color on my Phillips 60 rear projection big
that means that the phone needs to be unlock by the network provider
Mar 13, 2010 | Philips 60PP9202 60" Rear Projection...
I have a Philips 55pw936317f 55 inch tv that has pic problems.
Same problem here, wish I knew how to fix it... I noticed it can be helped a little if you adjust the convergence from the menu using the remote though.
Aug 29, 2009 | Philips Sport Personal CD/MP3 Player
Philips Magnavox Projection T.V
you need to replace a cople of the opticoupers most likely, if you want to repair this and save yourself a lot of dough, contact me at techman32k-at-yahoo dot com
Larry Dillon
Aug 06, 2009 | Televison & Video
60" Projection Tv - Approx 6 yrs old
Your CRT fluid needs to be replaced. After many years the crt cooling fluid gets a ton of alage built up in the tubes.  This will cause the screen to get a halo effect or get darker.
You only need to replace the fluid in the blue and green tubes.
Dec 03, 2008 | Philips Magnavox 9P6034C 60" Rear...
Phillips 50 inch Plasma
Philips 50 inch plasma tv no video but has sound
Sep 28, 2008 | Philips 50PFP5332D 50 in. Plasma...
Magnvox 50 inch rear projection tv
Have you tried cleaning the projectors? I had a halo issue and that resolved it. Good luck
Aug 28, 2008 | Philips Magnavox 9P6034C 60" Rear...
White objects (especially text) on a black background produce a white halo effect around the white lettering. When playing a PS3 game I noticed that the blue color appeared black, as though I had no blue...
Aug 27, 2008 | Philips 9P6040C 60" Rear Projection...
Need tv help
The sympton for contaminated CRT coolant is objects having a halo effect on the effected CRT color. The Blue and green are the CRTs most often contaminated. But to answer the question changing coolant does help. You can look into the crt with it turned on to see if the coolant is congealed. Just be carteful not to touch any components as you look into the CRT lens.
Feb 20, 2008 | Philips Magnavox 9P6034C 60" Rear...
Philips Magnavox 55P9271 55" Rear Projection Television Logo
277 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
