Question about Plumbing
Low hot water pressure on delta lewiston kitchen faucet
arealplumber
  • 33 Answers
SOURCE: low pressure and flow on hot water side of single handle faucet
It could be one of two problems, one simple, one serious.
  • Easy fix
  1. Turn off hot water angle stop under sink to faucet.
  2. Remove supply line from hot angle stop.
  3. Place end of supply line in a small bucket to catch some water.
  4. Turn on cold water for a couple of seconds and backflush debris from faucet.
  5. Reconnect supply line.
  6. Turn on angle stop and test
  • Complex fix
If you have steel pipes you may be experiencing reduced flow due to corrosion in your pipes. Reduced hot water pressure in the kitchen faucet is usually the first sign since this is the faucet that is most used in the home.
Repiping is a job for a professional. Another symptom you may need a repipe is orange colored or rusty water.
Posted on Dec 05, 2008
arealplumber
  • 33 Answers
SOURCE: DELTA MODEL 470-WH LOW WATER FLOW AT KITCHEN FAUCET
This could be a couple of things.
  1. First remove the aerator from the wand and make sure you have plenty of flow with it off.
  2. If there is flow clean or replace the aerator.
  3. Remove the wand and look between the hose connection and the wand there should be a screen between them. Remove the screen and clean or replace.
  4. Make sure hose is kinking under the sink.
If you need a diagram of the faucet with part numbers here is the link:
Delta 470
Hope this helps!
smokenic
  • 49 Answers
SOURCE: Low hot water pressure on newly installed kitchen faucet
it souns like a factory flaw in the piping or whoever hooked it up, over bent or kinked the line
Posted on Sep 20, 2009
  • 115 Answers
SOURCE: Low water pressure while the rest of the faucets
lume build up. pull handle out and unscrew there should be filter inside take out and soak in a cup of lime away overnite rinse well and reinstall
Posted on Dec 17, 2009
  • 349 Answers
SOURCE: Poor hot water pressure form Delta single lever faucet
it can be adjust take handle off and remove locking collar first turn water off,
it has a metal or plastic ball with a shaft for the handle it may have spun or a washer may be bad under it,
you can get a replacement at lowes or Home depot to replace it if this is the problem .
Posted on May 05, 2010
We have a Delta 172 single handle faucet. We had our hot water heater replaced. Now it takes longer for hot water to get to the faucet. Could debris (calcium build up, etc.) from the replacement get in...
Yes, debris from water heater replacements often breaks lose and gets stuck. The problem could potentially be anywhere between water heater and the faucet. The faucets shut off valves or the Delta faucet cartridge itself. Turn the hot and cold water valves off under the sink and disconnect the water supply lines from the faucet. aim the water supply lines into a bucket and turn the valves on one at a time. If there is a significant reduction in the water pressure and volume on the hot water side, you need to replace the shut off valve. If there is no reduction in water pressure, you need to clean and/or replace the Delta faucet cartridge. Contact Delta to receive free replacement parts.
Dec 11, 2010 | Delta Faucet Delta 172-SSWF Waterfall...
Low pressure hot water only delta 470ddt
there is likely sediment under the spring and washer on the hot water side of the faucet under the handle. If you shut off the valves to the faucet, it is very easy to dismantle. There is an allen screw on the front of the handle to remove the handle. Under the handle there is a nut. Once you unscrew this nut there is either a ball or a cartridge )depending on the year of the faucet) that can be removed If it is the ball, then you will see two rubber washers in the base. Use your allen wrench or needle nose pliers to remove the washers and remove any sediment.
Nov 28, 2010 | Delta Faucet 470-DST Signature Diamond...
Hello, I replaced the seats and springs in my faucet Delta Leland 2578 and now my water pressure is low. So I thought it was the stem unit assembly because it had a lot of deposits on it so I replaced...
it would only be aerator if hot and cold were low..what happened is when u shut angle stop off on hot water to replace assmbly..the washer on angle stop separated and is blocking the supply
Nov 21, 2010 | Delta Faucet 2578-278 Leland Series...
Apr 25, 2010 | Delta Model 172: Waterfall Single Handle...
Dec 17, 2009 | Delta Faucet Delta 474 Waterfall Single...
I installed a new Delta shower valve. When I turn the handle to mix the warm and hot water it vibrates like a jack hammer. Is the water presure to high or is the valve bad.
It is due to the water pressure. You may need to install
a pressure relief valve at your main cold water line, so
you can set the water pressure and prevent your valve from vibrating, that is it it is annoying you,.Otherwise,
just let it be..
Nov 10, 2009 | Delta Lewiston Tub & Shower Faucet
After a recent water main break, our Delta Model 473 kitchen faucet now has very low water pressure. It also continues to flow for a few seconds after turning it off. I tried unscrewing the screen and...
Check the screen at the hose connection under the sink. Check the hoses for any large debris in them. Verify that the water pressure coming from the water outlets under the sink is good. There is obviously a restriction somewhere...you just need to locate it.
Sep 26, 2009 | Delta Model 473: Saxony Kitchen...
Low pressure and flow on hot water side of single handle faucet
  • Easy fix
  • Complex fix
Nov 14, 2008 | Delta Faucet Plumbing
Plumbing Logo
81 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
