Question about Garmin GPSMAP 295 GPS Receiver
Inaccurate Garmin GPS
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:''Table Normal''; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:''''; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:''Times New Roman''; mso-fareast-font-family:''Times New Roman'';}I have a Garmin GPSMAP 295 mounted in our aircraft with theremote antenna mounted to the inside of the windscreen. It has become inaccurate so when trackingover a user waypoint it can be up to 3 miles out. I have watched it error inflight I have been tracking over a waypoint with this GPS and been 0.2milesfrom the waypoint and it is working correctly as I can see the waypoint below,but then I watched the waypoint on the screen move 2.4 miles out to myleft. This even thou I can see thewaypoint below me and the original GPS track was correct, if I turn off the GPSand then back on it will give me the correct position again. Do you have any ideas what could be theproblem? Regards Barry
    Problem Solver:
  • 15 Answers
Have you enabled the 'WAAS' option?
This improves accuracy greatly
Posted on May 05, 2010
How to set time and date on GPSMAP 295
Set the time zone and daylight savings according to the instructions on page 76 of this manual. The time and date are automatically set from the information received from the GPS satellites.
Jan 28, 2013 | Garmin GPSMAP 295 GPS Receiver
Where do i go to down load update for my gps 295. garmin said thay dont support this unit. thanks joe
Joe,
The Garmin "GPSMap 295" is at, as far as Garmin is concerned anyway, "end of life". This means Garmin will no longer support, repair, etc. this product. C'est la vie.
Garmin's older product lines lack the hardware to decompress the new "NT" (New Technology) maps that Navtek (the map company) is producing now. The NT maps are compressed so that they would fit on smaller capacity memory cards. By doing this, the maps required Garmin to include hardware (special designed circuitry) that could quickly decompress these maps "on the fly" for display. The much of Garmin's older GPSMap & StreetPilot lines predate this hardware requirement.
Our "still-functioning" GPSMap & StreetPilot GPSr will still pinpoint our location on the Earth as always - but lack the latest & greatest maps. You should review the maps that your GPSr can use and choose the one you prefer. I switched mine to display topographical maps. These show many of the road names like the City Navigator maps do, but lack important things like the POIs and routing. If you can do without them, this could be good enough. If you can't, you'll need to decide on whether the last non-NT map version is sufficient or purchase a new GPS that can accept the maps you want to put into it.
I hope this helps and good luck!
Sep 06, 2011 | Garmin GPSMAP 295 GPS Receiver
NO BATTERY POWER,ONLY EXTERNAL SOURCE
check contacts inside the battery compartment are perfectly clean and install NEW batteries (alkaline good quality). If remains the same problesm, needs to be repaired at Garmin´s shop
Mar 17, 2010 | Garmin GPSMAP 295 GPS Receiver
How do I start the Simulator in the Garmin 295 ?
Press the menu button twice than choose from the resulting menu.
The manual is available from garmin.com
Mar 15, 2010 | Garmin GPSMAP 295 GPS Receiver
Tracking storage options GPSMAP 295
Every waypoint in the track has date/time, altitude and position. Second and subsequent waypoints will enable calculation and display of leg length, time, speed and direction between each par of points. The track can be displayed in 3D; in Google Earth for example. As far as I know there is no way to change the interval.
Jul 13, 2009 | Garmin GPSMAP 295 GPS Receiver
Garmin gpsmap 295 will not run from internal battery power
I had the same problem. Reluctantly, I removed the batteries and the 8 phillips screws from the the case back perimeter. Be careful on opening. The unit is designed to open from the top and hinge at he bottom to keep the ribbon cables from being stressed. The unit should open nicely and lie flat on the table with the two bottom halves butted against each other. Get a magnifier and ensure the printed circuit board attached to the bottom half has all 3 screws. (I found one missing that has 2 functions - securing the board and delivering battery power. Mine had wedged against a piece of clear plastic...it was hard to find!!!) I carefully removed the wedged screw and returned to the circuit board left most attach point. Close up the unit and we were back in GPS heaven. Battery power restored!!!! and my $250.00 still in my pocket. Yipppeee.
Jun 30, 2009 | Garmin GPSMAP 295 GPS Receiver
Does Garmin GPS 295 contains Maps for Africa and the Middle East
Hi there -
The GPSMap 295 can only have one region at a time - North America, South America, etc. You can purchase an updated database specifically for Africa and the Middle East - it's about $50 USD. It will erase whatever region you have in there right now (you can't store Africa/MidEast with America, for instance. It's one at a time.)
The Garmin Website:
http://shop.garmin.com/aviation/databases/
lets you download new Jeppesen databases to your GPSMap 295. Select your model, then select which region you want.
***Before you buy:*** You'll have to have the data cable to connect it to your computer. Without that, you will have no way to update the maps and database.
If you do have the data cable, the process is very easy - just follow the instructions carefully, and make sure all the numbers they ask you for are correct. I just did mine today. Good luck!
Mar 24, 2009 | Garmin GPSMAP 295 GPS Receiver
Can't find any satellites
If you don't use it very often it can take time to find its location. Have you tried using the 'set initial location' option? Once it knows roughly where it is and what time it is it can then work out which satellites it should be looking for instead of searching for any/all of them. The manual does say that it will take time if it has no initial clue as to where on the planet it is, and if you're on the move while it's trying to work that out then it may take even longer. Obviously, if it has a poor view of the sky, or if most of the satellites are behind you and you have a tin roofed aircraft then that will probably not help either.
How do you know the antenna is OK?
Do you have the remote antenna to try?
Mar 18, 2009 | Garmin GPSMAP 295 GPS Receiver
Antenna input shorted
contact garmin sounds like a defective unit
Mar 10, 2009 | Garmin GPSMAP 172C GPS Receiver
Street Map Program for Garmin GPSMAP 295
Detailed road map data, with addresses, hotels, gas stations, etc. can be loaded into a data-card/cartridge/memory-card using Garmin's Mapsource software such as Metroguide or City Navigator. This can be changed as needed via a PC.
The 295 does not have driving routing/guidance through the streets as most of today's GPSs have, but it will show you exactly where you are on the street (but it should be switched to Road mode).
Driving routing is possible on the PC using Mapsource, but ithe route doesn't transfer well to the 295 because of the limits on waypoints.
Nov 29, 2007 | Garmin GPSMAP 295 GPS Receiver
Garmin GPSMAP 295 GPS Receiver Logo
104 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
