Question about Anthology Solutions Yellow Machine P400 (250004001) 250 GB Hard Drive Array
Yellow Machine fails to mount - flashing
Purchased in 2006 and working normally until a local power failure. Since that time the front panel indicators show that the file sytem is being rebuilt and restored (e.g both the Ready and Fault light are blinking together 1x/second), however, after 2 weeks it has yet to complete and allow mounting of the drive. Since Anthology is kaput I'm looking for suggestions. Thanks much. C. Fryar Texas
I saw on ebay they had some Brand New Diskless versions and One Used Working one. I know it is not a fix but a lot cheaper than the $1200-$1500 they used to be.
http://search.ebay.com/search/search.dll?from=R40&_trksid=m37&satitle=p400t&category0=
Posted on Mar 25, 2008
SOURCE:
When i turn on my tv it tries to boot, blue mitsubishi home screen come up, i hear fan then it all shuts off while green light blinks.
Try a reset. Start by unplugging for 1 minute, then plug back in & if still won't restart try the following. If none of the following work, you will need a technician.
Initializing the TV in many cases can remedy a problem.
In the 2006 product line Initialization is now a user function.
Pressing the front panel "INPUT' and "FORMAT"
buttons at the same time activates Initialization. When
complete all user settings will have to be set again. The
table in Figure 4-3 list the User Initialization procedures.
Note: Pressing INPUT and FORMAT is the same as
the Initialization in the Option Menu (MENU-2-4-7-0)
Order Name Procedure Results Notes
1 System Reset Press <System Reset>
on Front Panel
Hardware & TV operating
software reset.
POWER/Timer LED flashes for 60
seconds. No customer settings
are changed.
2 User Initialization
Press <INPUT> &
<FORMAT> on Front
Panel at the same time.
All customer Audio &
Video settings are reset to
factory default.
All customer settings will need to
re-configured.
3 Reset System
Defaults
From the remote, press
<MENU> <1-2-3>
<ENTER>
except V-Chip are reset to
factory default.
Netcommand, Channel Memory,
etc., will need to be re-configured.
SERVICER
PROCEDURE 4 Initialization
<MENU> <2-4-7-0>*
select "INITIAL" press
<ENTER>
All customer settings are
reset to factory default.
re-configured.
MITSUBISHI RESET / INITIALIZATION CHART
CUSTOMER
PROCEDURES
Figure 4-3
Figure 4-4
LED Indications
The front panel LEDs, refer to Figure 4-4, also assist in
determining the cause of a symptom. Figure 4-5 illustrates
normal LED operation. Figure 4-6 shows the
LEDs response when a problem is detected and indicates
the possible cause.
Power/Timer
Indicator
Status
Indicator
Lamp
Indicator Condition
Off Off Off Off (standby)
Blinking green
fast Off Off Initialization (10 - 65 seconds)
Off Off Blinking
green fast Lamp runs for 1 min after PTV off
Green Off Off Power On
Blinking green Off Off Power On Timer is set
NORMAL LED INDICATIONS
Power LED Status LED Lamp LED Condition
High Temperature - check ventilation air flow.
(Temperature sensor is disconnected.)
Off Off Blinking yellow Lamp cover is open.
Lamp failure (Lamp fails to turn on)
Off Off Red (Lamp turns off after lighting)
Lamp is broken
Off Blinking Red Off Fan Stop
Off Red. Off Circuit failure. (Run Error Code Check)
Apr 08, 2015 | Mitsubishi WD-65731 65-Inch 1080p DLP HDTV
How to fix vizio tv
The backlight is LED and not likely to fail, it is most likely the main, modular power supply causing the problem.
Look inside for a block assembly with larger components and several connectors that is bolted onto a larger panel.
These are purchased from other sources, not made by Vizio.
Look into the guts of this assembly for cylindrical components with plastic foil and an aluminum top, mostly mounted vertical to the board.
Examine the tops of these for any dome-like appearance; this is a sign of failure since these should be flat.
They are inexpensive (one reason they fail) and this failure can be prevented by spending another dollar or two in the manufacture of them.
Replacements can be had but unless a couple of parts are added (by the maker or a smart tech) the same failure will eventually occur.
Dec 26, 2014 | Vizio M470VSE 47" LED TV 1920x1080, 120...
I have a plasma tv the power button goes on then off in a second does anyone have an answer why
Hey Craig,
I've seen this common problem in several models of flat panel TV's, especially 4 to 5 year old Walmart Black Friday specials. The capacitors in the power supply dry out and fail, causing the power supply to fail. When you try to turn the TV on, the power supply refuses to start and the unit shuts off. This problem that the local (in Phoenix) Fry's Electronics sells a power supply capacitor replacement kit for several models of flat panels. If you are compelled to check it out, the units are typically easy to disassemble, and the power supply PCB (printed circuit board) is normally well marked.The caps are blue and/or yellow cylinders, mounted on end. Defective ones, in this use dry out, overheat, and swell up, causing the top to noticeably bulge out. Without knowing more details I would suggest that this is a most likely failure for your TV. Thanks for using fixya. I hope it helps. Dan
Nov 28, 2014 | Televison & Video
Tv power button lights up then go's off
Hey Craig,
Yellow blinking light . what does it mean
A blinking yellow for this model indicates the TV is too hot, unplug & allow 30-45 min to cool before re-plugging .
OR: lamp not installed or lamp door not closed. there is a lamp door switch that may not be closing, simulating door not closed
LED Indications
The front panel Status LED provides an indication of
the set's operation and the possible cause of a malfunction.
If an abnormal condition is indicated, perform the
Self Diagnostics procedure.
Self Diagnostics
To activate, press the front panel <ACTIVITY> &<CH
??> buttons at the same time and hold for 5 seconds.
The STATUS LED will then flash denoting a two digit
code.
• The number of flashes indicates the value of the
MSD (tens digit) of the Error Code.
• The flashing then pauses for approximately 1/2
second.
• The LED then flashes indicating the value of the
(ones digit) of the Error Code.
• The Error Code is repeated a total of 5 times.
Example: If the Error Code is "23", the LED
will flash two times, pause, and then flash three
times.
Table 2-2: LED Indications
Error Codes, descriiptions and the most likely cause of
the error are listed in Table 2-3.
Note: The TV must be in "Shut Down." The LED
will probably be indicating an abnormal
condition. If the TV is switched Off, AC is
removed, or a System Reset is performed, the
code automatically resets to "12" No Error.
See the Error Code Log to retrieve a history of
errors.
Note: Use the front panel buttons, not the remote
control.
Note: If there is no response, the front panel may be
locked by a V-Chip setting. To unlock, press
and hold <ACTIVITY> on the front panel for
8 seconds.
LED Indication Condition
Off Off (standby)
Green Power On
Slow Blink Green Power Off with Timer Set
Fast Blink Green (80 seconds) > Off Power Off (Cooling fan still working, 80 sec)
Red Lamp Failure
Yellow TV Too Hot
Slow Blink Red TV May Require Service
Slow Blink Yellow Lamp Door Open or No Lamp Installed
NORMAL INDICATIONS
ABNORMAL INDICATIONS (For details perform Self Diagnostics Procedure.)
Jul 07, 2014 | Mitsubishi WD 65837 65 in. HDTV
My HP D530C does not power on. The power LED flashes 4 times. What is the fault? Pls let me know asap. Thanks.
HP xw6200 Workstation - Diagnostic LED Code: Four Flashes ISSUE: When the workstation is powered on, the front LED might flash red four times, once per second, followed by a two second pause. SOLUTION: The front LED flashing four times is a sign of a power failure. To fix this issue, complete the following steps:
  1. Open the access panel, and check to see if the four-wire power supply cable is properly connected to the system board.
  2. There may be a faulty device. Locate it by removing all devices and then reinstalling them one at a time until the workstation fails. Replace the device causing the failure. Continue adding devices to ensure all are functioning properly.
  3. Verify the power supply functionality, as follows:
    1. Disconnect AC power.
    2. Remove all internal power supply cables from the system board.
    3. Plug in AC power.
      • If the power supply fan spins, and the BIST LED illuminates, then the power supply is good. Replace the system board.
      • If the power supply fan does not spin, or the BIST LED does not illuminate, replace the power supply.
Dec 13, 2011 | HP Compaq d530c PC Desktop
Don't starts yellow light flasing
If the power button on the tower is flashing Amber, the fault is the power supply. Replace the power supply and they system should work.
If the power supply doesn't resolve then the 2nd most likely failure is the Front IO panel (Circuit card behind the power button)
Nov 22, 2009 | Dell XPS 400 PC Desktop
My refrigerator is not getting/staying cold but the freezer is working normally
Good day,
1. There is a modulating thermostat that is located in the top rear of food compartment. It is controlled to open more or less depending on the owners choice, by a knob which is located near the front of the compartment and controls the opening with a small notched belt.
On a good day it is a bear to access.
However, if that control fails it could be denied cold air from the freezer, where it gets it's cold air.
2. The defrost system may have failed. Frost on the rear panel of the freezer compartment will be your first clue.
The defrost system is made up of 3 parts.
A. The timer, which is located in the top of the fresh food section just behind the knob that controls the temperature. Using a very small screw driver, you can turn the shaft clockwise until the compressor shuts off. Leave it that way with the machine left on, and wait 45 minutes. If the machine starts back up, the timer is O.K.
B. Behind the rear panel of the freezer, is the main heater, mounted to the evaporator coils. (Looks a lot like a bake element in an electric range). It can be checked with an ohm meter, but rarely fails.
C. The defrost thermostat. A small round disk mounted on the top of the evaporator. Accounts for most defrost failures.
P.S. Yes, it is a difficult and time consuming machine to work on.
Nov 08, 2009 | Amana DRB1901C Bottom Freezer Refrigerator
HP Photosmart c7180: "Ink System Failure" error code Oxc18a0306
I get the ink system failure message on my hp c7180 as well as an error code of oxc18a0306.
Aug 24, 2008 | HP Photosmart D7160 InkJet Printer
Flashing "F" on front of drive slot
The front panel display contains seven (7) lights which provide the following information: ? Power-On - Steady green glow indicates that power is being supplied to the Data Silo chassis. ? Temperature Warning - Flashing red indicates that internal operating temperature has reached 43? C (109° F). ? Blower 1 or 2 Failure - Flashing red indicates a blower has failed. ? Power Supply 2 Failure - Flashing red indicates second power supply has failed. ? Power Supply 1 Failure - Flashing red indicates first power supply has failed. ? Mute - When switch is depressed, a steady yellow glow indicates the audible warning sounds have been disabled. Depress switch again to enable sounds. ? Reset - Depress switch to reset chassis and clear any error conditions. The specs on the DS550 do not say anything about an F at all? Did you put the correct model number?
Aug 29, 2007 | StorCase 9 Bays Data Silo DS550 Storage...
Open Questions:
See all Anthology Solutions Yellow Machine P400 Questions
Anthology Solutions Yellow Machine  P400 (250004001) 250 GB Hard Drive Array Logo
264 people viewed this question
Top Anthology Solutions Computers & Internet Experts
Ekse
Alun Cox
Are you an Anthology Solutions Computer and Internet Expert? Answer questions, earn points and help others
