Question about Delphi MyFi Satellite Radio Receiver
Delphi MyFi XM2GO won't turn on
Should my Delphi function normally with the adapter plugged in, even if it has a bad battery? When I try to charge it, it goes from "charging", to "charged" almost immediately. But when I unplug the charger, it shuts down dead. This made me think the battery might be bad, but even when it's plugged in, it won't let me beyond the "charged" screen. I picked this up used, and will replace the battery, if that's the problem, but I've heard this device sometimes stops working, for some reason, and cannot be repaired. If that's the case with mine, obviously, I don't want to spend any more money on it. Thanks guys!
3 Suggested Answers
SOURCE: delphi myfi xm2go
I have the same problem. I finally was able to get Delphi Tech Service and found out that these units have a flaw. they have been going out after about 14-18 months and there is no known repair... neither does Delphi offer a repair service for this problem.
Posted on Jan 30, 2008
TOLhamRadio
  • 509 Answers
SOURCE: My delphi myfi xm2go will not recharge. What do I
New battery - make sure it's WHITE and not a black one as the black ones were recalled.
Posted on Jan 26, 2010
The radio will not turn on ,not manually and not with remote
power suplay Transformer dies...
Try to find another suitable transformer and try running it
Nov 24, 2013 | Delphi Myfi Xm2go Portable Satellite Radio...
MYFI XM2GO WILL NOT TURN ON. ALSO WHEN I PUT IN CRADLE WILL NOT SHOW CHARGING
I had the same problem. This procedure from the "Technical Questions" section of http://shopdelphi.com/consumers/support/faqs/myfi/ worked for me:
"My MyFi won't power up, how do I reset it?
To reset your MyFi, start by turning the receiver off and removing it from its (car, home, audio system) cradle. Then remove the back cover and battery. Using a small paperclip, press the reset button located on the top left corner of the battery compartment. Now plug the AC power adapter into a wall outlet and plug the power port directly into the bottom of the MyFi (battery stays removed). Wait 10 seconds and listen for a beep. After you hear the beep the message "insert battery" will appear. Cycle the MyFi to ensure it powers up and powers down. If the power cycle is normal, then turn off the MyFi, unplug the power adapter, and reinstall the battery. Re-plug the AC power adapter directly into the bottom of the MyFi. Wait 10 seconds and listen for a beep. After the beep you will see the message "battery charging". Leave the MyFi plugged in until it's fully charged. You will see the message "charging complete" displayed. After the MyFi is fully charged, turn it on and reset to the factory defaults. Unplug the MyFi from the AC power adapter and using the battery power leave it on until it fully discharges (approximately 2-5 hours). Plug the MyFi in using the AC power adapter to recharge the unit and resume normal use. If you need help at any point during this process contact us at 1-877-463-3574 for technical support."
I hope it works for you too.
Sep 27, 2010 | Delphi MyFi SA10113 XM Radio Receiver with...
I can't get my delphi myfi sm radio to work even when I use the AC adapter on the cradle. For a while, it would work and then go off by itself. Now, it won't even go on. What's the problem?
You should: Insert your MyFi into its home stand and plug the AC adapter into the wall to charge the battery.But if its really not charging a battery replacement is already needed for this unit and you can get the battery from a authorize service center.
Sep 11, 2010 | Delphi MyFi SA10113 XM Radio Receiver with...
My Delphi XM2GO MyFi has stopped transmitting to an FM station on a house radio. Is it repairable? If so, is there a facility in the Cleveland, OH area where I can take it?
IF you take it out of the home dock and run it on batteries, I'll bet you it works again. The newer home docks TURN OFF the FM transmitter. Try a car dock, or try it with just the power plug plugged into the bottom of the MyFi, without the home dock and see if you can now get the FM transmitter to work. Let me know. Thanks and good luck.
Aug 09, 2010 | Delphi MyFi SA10113 XM Radio Receiver with...
My mifi XM2go radio will not turn on. I have
Sounds like a bad battery. Try plugging DC adapter directly into the bottom of the unit and turn it on - does it still act-up? If so, bad radio; if it works with adapter only, then battery and charging issue.
Dec 20, 2009 | Delphi MyFi SA10113 XM Radio Receiver with...
Nov 21, 2009 | Delphi MyFi SA10113 XM Radio Receiver with...
Delphi myfi xm2go
Replace the battery. Your Myfi will not work without it -- even if it is plugged into the charger.
Mar 03, 2009 | Delphi MyFi SA10113 XM Radio Receiver with...
XM2GO remote doesn't work
hi i have same radio try turning the radio off and taking the battery out for a minute or so and putting it back and turning it back on worked for me
Nov 27, 2008 | Delphi MyFi SA10113 XM Radio Receiver with...
MYFI does not powerup
You may not be getting power through the base because of a bad physical connection between the base pins and the receiver, and it won't power up because it has no battery charge. Try plugging the AC power adapter directly into the bottom of the receiver (not through the cradle). Push the adapter plug toward the back of the receiver to see if the + sign on the battery on the top right of the screen shows that it is now receiving power and charging. Alternatively, with the receiver in the base, try pulling the top of the reciever toward you to tilt the receiver forward on the pins to see if it starts charging.
Sep 04, 2008 | Delphi MyFi SA10113 XM Radio Receiver with...
Delphi myfi xm2go
Dec 17, 2007 | Delphi MyFi SA10113 XM Radio Receiver with...
181 people viewed this question
Top Delphi Audio Players & Recorders Experts
John
John
Darrell
xxxxxx xxx
Are you a Delphi Audio Player and Recorder Expert? Answer questions, earn points and help others
