Question about Smeg 18 in. DWF410SS Slim-Line Free-standing Dishwasher
It's stuck on Bio...
I inherited a smeg dishwasher when I bought my own flat. When my dish washer finishes its cycle, it sticks on the bio setting and the final 3 lights are lit. I can't seem to make it reset to the start. It takes an awful amount of nudging and turning the on off switch to get it to reset. what am I doing wrong?
  • Anonymous Dec 27, 2007
    all lights are on as if it has finished cycle but i cant reset it
    this is my product
  • 944 Answers
Here is the link to the user manual, hopefully this solves your problem else please ask again; http://www.smegtech.com/site/smeg/pdf_libretti/19590097802-GB.pdf Hope this helps :)
Posted on Jun 25, 2007
Why is my dishwasher is stuck in the drain cycle
What kind of dish washer. It sounds like the switch is stuck try giving the dish washer a through cleaning.
I’m happy to help further over the phone at https://www.6ya.com/expert/joshua_ac64e182ed26f66d
Aug 13, 2014 | Samsung DMT400RHS Builtin Dishwasher
My dish washer wont fill with water
there is a float, usually at front left side inside dishwasher, that may be stuck..possibly an utility holding it up, or the fill valve is stuck. When dishwasher calls for water, it fills until this float rises to proper level and shuts the valve off at proper level. If it sticks, water will shut off at improper level.
May 01, 2014 | Zanussi FS1255S Front Load Washer
Hi my classique dish washer won't open,it is full with dishes ,how can i get in.thanks
f your Dishwasher is stuck in a cycle check the following
Float Switch
The float switch may be hung up and this can cause the dishwasher to be stuck in a cycle. see the diagram attached.God bless you
Timer / Control
If your dishwasher gets stuck in a cycle first try shutting off the breaker for at least 5 minutes if this does not correct the problem you will need to replace timer/electronic control board.
Apr 05, 2013 | Dishwashers
Dishwasher says dishes are clean but is still stuck in cycle. tried resetting the breaker but no luck. the green light that goes on when clean is constantly flashing but dishwasher is non-responsive. any...
Some dishwashers have some sort of float switch. They can stick , try rocking dish washer if stuck mid cycle, I would make sure the food collect grid at bottom is clear, try flushing machine through with an empty load now and then, you can buy stuff for cleaning dishwasher insides too.
pete
Nov 08, 2010 | Kenmore Dishwashers
My dishes are still wet after the cycle has finished why?
Hi.
Ensure that there is no water at the bottom of the tub. If there is water, check drain well and drain hose, then test pressure switch in the drain system.
If there is no water, the the thermostat (or the dryness) sensor must be replaced.
In that case, cintact Smeg at the number listed on the owners manual.
Regards.
May 02, 2010 | Smeg 18 in. STX45-1 Stainless Steel...
Smeg Dishwasher ST 663 sometimes won't work
My dish washer stops after i5 minutes, don't know what the problem is, water is going in but just suddenly stops, i changed the hose but still the same. Any help welcome
Feb 22, 2009 | Smeg 24 in. DWD1SSE-1 Built-in Dishwasher
My Smeg dishwasher DWF 64 SSE won't go onto rinse or dry
Easy one first try this to see if it helps
Water pre-heating
Your dishwasher may pre-heat the water. If so, and if the water entering the dishwasher is cool, the heater may take up to half an hour to heat the water.
To avoid the wait, increase the incoming water temperature before turning on the dishwasher. Do that by running the kitchen sink faucet until the water runs hot. Or increase the temperature of the hot water to the entire house at the hot water heater.
Warning! To lessen the risk of scalding, don't set the hot water heater temperature higher than 120 degrees Fahrenheit.
Jan 29, 2008 | Smeg 24 in. DWF612WH Free-standing...
Smeg dishwasher
Hi, You can download SMEG dishwasher manuals from here: http://www.smegtech.com/site/smeg/myapp/libretti/index.php?lang=EN Al.
Feb 02, 2007 | Smeg CSU2001 Built-in Dishwasher
Smeg 18 in. DWF410SS Slim-Line Free-standing Dishwasher Logo
729 people viewed this question
Top Smeg Dishwashers Experts
Starnley Johnwells
Starnley Johnwells
Marvin
Marvin
Are you a Smeg Dishwasher Expert? Answer questions, earn points and help others
