Question about HP Photosmart 3210 Printer
Photosmart 3210 won't scan
When I hit scan, the window says "NO scan options. Refer to device documentation to troubleshoot." Any ideas where that came from? Thanks, everybody.
  • Anonymous Dec 03, 2007
    my printer will not scan it says pick a computer from list but theres no list . i have it connected to a router by a cable and using windows xp
  • Jerroldlk Jan 12, 2008
    when i press scan i get the message "no scan options"
  • 432 Answers
Try this: Uninstall all software and drivers for printer. Unplug the USB cable from computer. Reboot the computer twice with the printer still unplugged. After the second boot, Reinstall the software/drivers. Don't plug the printer in just yet, the software install will tell you when. After the printer and software/drivers are all in. Reboot the computer once more. Hopefully this will clear things up. Let me know, I like to keep track of my solutions so I can serve people better with there problems.
Posted on Jun 25, 2007
I could not get my scanner to work either. i called HP and they said i had a bad printer and suggested I get a new one (BS!) so I toyed around alittle and figured out how to get it to scan. I opened up explorer and typed in http://(ip adress of the printer) and it works fine like that. I don't know how to get it to reconize my computer. I have uninstalled and installed over and over again and it still doesnt reconize my computer (XP not Vista).
hope that helps
Posted on Dec 07, 2007
HP 3210 NO SCAN OPTIONS : http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01385451&cc=us&lc=en&dlc=en&product Solution two: Populate the destination list worked for me
Posted on Feb 11, 2009
I had/have a similar problem - the scanner doesn't work from the printer panel, but does work when requested from HP Image Zone software.  Thanks for that clue.
However, I cannot scan 35 mm slides.  The scanner whirs for a few moments then locks up totally.  It gives an error - "Cancelling..."  I can't even shut the machine off; I have to unplug it.
Any ideas?
[email protected]
Posted on Jan 15, 2008
Don't use the registryfix ad that is on the righthand side of this page, it ruined my pc. the error message is a pain in the arse and i have it right now.....i uninstalled months ago due to it and here it is again.... i can scan thru the computer and the pc says the hp scanner is fine, no solution yet for this girl, who knows how much real living has been lost to computers and their b.s., God will be chiding us in Heaven i bet.
Posted on Oct 06, 2007
I scanned through the computer (versus the on-printer control panel) and it worked fine. I.e. go to HP Image Zone software on the computer and select scan. It worked fine.
Posted on Oct 02, 2007
If VISTA is in the mix, the problem is that you cannot set a scan destination. To fix, I climbed onto Photoshop (any image editor should work) and PULLED a scan from the HP printer which caused the printer to set the SCAN directory destination and now it works fine (i.e. normally). LOTS of apps have such bizarre first time use problems in Vista where you have to go to extraordinary lengths to configure something teh first time. Example" Sony Acid Pro, Soundforge, and CD Architect.
Posted on Aug 31, 2007
You forgot about the one handed hand stand with your back to the north/north west on a Tuesday after work! I'm here because I get the same error message "sometimes" and it is certainly not going to help to undo everything and redo them. That's may be a simple formula to hand out to people if you don't understand anything about TCP/IP and client/server functions but it's a huge hassle and rather unlikely to make things more stable. I'll keep looking, but I won't be uninstalling the entire software package unless I know exactly how to install it better the next time around.
Posted on Jul 26, 2007
SOURCE:
Scanning is not working when I hit the scan button on the printer/scanner the screen says No Scan Options, refer to device documentation to trouble-shoot. I have used this feature before with same laptop...
Open the solution center and click on settings. Take the pointer on scan settings and click on scan to setup.
A new destination list will open and take all the entries, one by one, to right, and click on update the device. If it is already on right, please take it to left and click on update the device and again take it to right and click on update the device.
Then restart the printer and the issue will be fixed.
Apr 19, 2010 | HP Photosmart 3210 Printer
I have an HP Photosmart 2575 All-In_One Printer, Scanner, Copier, but when I try to scan a document it says No Scan Options and below that refer to device documentation to troubleshoot. I have no...
if it is XP, then click on start , then run , in run type wiaacmgr.exe and hit enter, try to scan.
In vista and windows 7 , replace run with start search box.
Apr 09, 2010 | HP Photosmart 2575 All-In-One Printer,...
When I put something in to scan, it said No Scan Options, refer to device documentation to troubleshoot
You may have to reinstall your printer on your computer. Then do your set up the scanner seems not to be installed or activated for your printer. That is why your are having trouble.
Dec 16, 2009 | HP Photosmart 3210 Printer
Will not Scan. Gets message..
Is it installed in windows as a scanner? Dont use scan button on machine try using scanners or document imaging software that needs to be in place on your computer, ie Document imaging in office or scanners and camera in windows, one sends scan signal from the PC, can use the scan button on scanner only when configued to do such. Scanner has software as does the printer both can found at HP web
Nov 07, 2009 | HP Photosmart 3210 Printer
HP Photosmart 3210 Printer will not scan any
I had the same problem and this is what I did to fix it.
Go to control panel
choose printers
look to left and find scanners and cameras
click scanner
a pop up should direct you to scanning options and will lead your scanner to scan the item
hope this helps
Mar 04, 2009 | HP Photosmart 3210 Printer
Scanning
just use paint to scan your pic or doc.Click on startmenu>Go to program>accessories>paint>file>scan from scanner or camera
Jul 31, 2008 | HP Photosmart 3210 All-In-One InkJet...
HP Photosmart 3210xi Scanning Issue
no scan options refer to device documentation to troubleshoot
Jul 12, 2008 | HP Photosmart 3210 All-In-One InkJet...
Printer Won't Scan
I cant scan it says refer to documentation to troubleshoot. How do I fix this. Ishala
Mar 29, 2008 | HP Photosmart 3210 Printer
HP Photosmart 3210 Printer Logo
1,375 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
