Question about Philips 60PP9202 60" Rear Projection HDTV-Ready Television
I just replaced the convergence chips cuz I thought they were bad but I still have the screen with an arc at the bottom and the top of the screen...any other ideas???
    Scholar:
  • 87 Answers
There are usally 2 or 4 resistors that have to be changed out after replacing the amps.You can identify them by their discoloration.Should be brownish and burned.They are in the area of the amps.The value is 6.8 ohms.
Posted on Jan 19, 2009
I have a Philips 60 in. rear projection model# 60PP9020/17F made in sept. '04. There is a green arc across the bottom half of the screen. At the top everything lines up. I tried to use the multi point...
As you look from the back the chips are on the board on the far left; black and each mounted side by side on metal plates with fins--this model should use 2 of the STK-392-120 CHIPS.
I buy mine on EBAY---select advanced search, search by seller---sewsales55 is the seller I use. This is Suburban Electronics in Maryland (they also have a online catalog) and a pair of the chips should cost under 15 dollars from them.
If this helped, rate this solution as very helpful as I do this here for free.
SD TECH
See typical convergence problems:
Sep 09, 2010 | Philips 60PP9202 60" Rear Projection...
I HAVE A BLUE ARC AT THE BOTTOM OF MY SCREEN
Your TV most likely has a convergence failure. ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
0667c5f.pngSOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses. Its a fairly easy DIY job or you can call in a pro. If you want to do the repair yourself check the site www.TvRepairKits.com. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
Jun 19, 2009 | Panasonic PT-47X54 47" Rear Projection...
The scroll on the top of the screen is arced
Convergence IC's are bad. You can get the parts over the inernet or you can get a complete kit - parts - instructions - etc from www.TvRepairKits.com
May 05, 2009 | Philips Magnavox 51MP392H Rear Projection...
I just received a Hitachi 50" projection Tv from a friend. He was the original owner and it appears after 8 years the picture quality went bad. After spending some time with the operating manual it appears...
Your TV most likely has one or more possible problems.
Problem #1: Convergence Chip Failure ( common problem )
  • Screen looks 3D
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Apr 23, 2009 | Hitachi 50GX49B 50" Rear Projection...
Arcs at the Top and Bottom of the screen!
You will find small 1/2 or 1watt resistors close to the ic's, you must measure them and they must be exact ohms. I believe you'll find a couple open or have changed in value, I hope the new Ic's haven't been fatigued. That should fix your problem.
Jan 19, 2009 | Philips 60PP9202 60" Rear Projection...
60" TV has an arc in the pic
Check the fuses 1007 & 1405. If they are blown in will cause an Arc.
Note: If the screen shrinks/expands you may need a chip kit from www.repairkits.com
Aug 28, 2008 | Philips Magnavox 9P6034C 60" Rear...
SPEED BUMP OR BOWING
Your convergence chips and convergence resistors are going bad. When they fail the screen colors will look distorted/3d looking. Another symptom is one or more colors can't be converged using the convergence menu. You can purchase the parts over the internet. Just make sure you get Sanyo brand convergence chips and the correct flame proof resistors. You can also check the site www.TvRepairKits.com for a kits.  Just make sure you replace both of the convergence chips and all of the convergence resistors.
Aug 25, 2008 | Philips 60PP9202 60" Rear Projection...
43fdx01b arc at top of screen
Usually this means convergence ic's have to be replaced and possibly a few resistors on small convergence board. Sometimes it requires digital alignment after new parts are soldered in. This repair can cost 175.00-375.00.
Apr 20, 2008 | Hitachi 53FDX01B 53" Rear Projection...
Blue color is out of position
sure sounds like convergance problem
http://www.partstore.com/Part/Samsung/
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
http://www.hdtvoice.com/voice/showthread.php?t=28929
Jan 30, 2008 | Samsung HC-P4752W 47" Rear Projection...
Convergence
Replace both convergence IC's part# STK392-040. Also check for burnt/discolored resistors nearby.
Aug 23, 2007 | Samsung HCL4715W 47" Rear Projection...
Philips 60PP9202 60" Rear Projection HDTV-Ready Television Logo
21 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
