Question about NetGear CG814WG 54 MBPS WIRELESS CABLE MODEM GATEWAY Router
Roku will not accept my wireless password
My roku had been accepting my wireless password, now will not accept it. The roku player is running, the remote works, I have tried to reset many times by unplugging the roku. My other wireless devices work. The roku keeps saying error 014
5 Suggested Answers
rwandrew
  • 115 Answers
SOURCE: Resetting WEP Password on Netgear WGT624
If you hold the reset pin in for more than ten seconds(I always count to 15) it will do a Factory reset...this will set all back to factory specs
Then you can set a new wep as well as an admin password
Posted on Jan 27, 2009
anandg27
  • 1272 Answers
SOURCE: will not accept password
Please follow the steps on a computer connected to the router so as to check the network key:
1. Open the browser(Internet Explorer or Mozilla Firefox).
2. Access the router usually http://192.168.1.1 else try http://www.routerlogin.com
3. Login to the router with the Username as admin and password as password (unless you have changed it).
4. Click on Wireless Settings'(under Setup) from the left menu.
5. Check if 'WEP (Wired Equivalent Privacy)' or 'WPA-PSK (Wi-Fi Protected Access Pre-Shared Key)' is selected under 'Security Options'.
6. If WPA-PSK is selected, copy the code entered in the passphrase.
7. If WEP is selected, copy the code entered in the key that has been checked.
This is the code required for connecting the wireless computer to the routers' wireless network.
In some cases, for security reasons the passphrase might show as asterisks. In this case type a new password and click apply. You will then have to use the same password for all the wireless devices connecting to the network.
IF the computer has windows Vista then perform the steps below:
1. Click START, Click Control Panel then click classic view in left hand side menu.
2. In the main screen, open up NETWORK AND SHARING CENTER.
3. In the left hand side menu open up MANAGE WIRELESS NETWORKS.
4. If you see any name in the list, please select the name and click remove.
5. Once the list is empty, click on ADD, select the first option, ADD A NETWORK THAT IS IN RANGE OF THE COMPUTER.
6. Click on your network name SSID and click on connect. If you have a password setup on the router enter the security key.
7. This should setup the wireless network.
For XP perform the steps below:
1. Right click on My Computer icon and go to Manage.
2. Go to Services then go to Service and Applications.
3. Double click on Wireless Zero Configuration.
4. Change the Start Up Type to Automatic and click on Apply
5. Click on Start and press OK to close the window.
6. Go to 'Control Panel', Click on Classic View in the left hand side menu and then open 'Network Connections'.
7. Right-click on the wireless Network Connection icon and select 'Properties'.
8. Go to the 'Wireless Networks' tab .
9. Check the option 'Use Windows to Configure this Wireless Connection' and click 'OK'.
Now please perform the following instructions to connect to the wireless network:
1. Go to 'Control Panel', Click on Classic View in the left hand side menu and then open 'Network Connections'.
2. Right-click on the wireless Network Connection icon and select 'Properties'.
3. Click on the 'wireless network' tab.
4. Under Preferred networks if you see any name in the list then highlight the name and click remove. Click OK.
5. Right-click on the wireless Network Connection icon and select 'View Available Networks'.
6. Look for the SSID (aka Network Name) of the Wireless router or access point.
4. Highlight thee SSID from the list that you want to connect to.
5. Type the security Key here and click on the 'Connect' button.
6. You should have successfully established a wireless network connection.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. If you cannot rate this post with the highest rating, then please comment to this post and I will try to help you further.
Regards
Anand
Posted on Sep 24, 2009
  • 62 Answers
SOURCE: netgear wireless-G router was working fine. now it is locked
1)The Default password for wireless-g is admin and the password itself is the word password both being lower case.
2)If the default password is not working or it is locked then the password might have change the password to something else.
3)To get the default access to the router web interface we have to hard reset the device but if we reset the device to the default setting's the internet connection will be terminated and the all the setting's has to be done from the beginning.
4)Following procedure will help you in hard resetting the device:-
a)You will find the very small/tiny circular pin hole on the rear panel of the device very close to the power.
b)Use the paper clip or a pin to reset the device and keep holding the reset button for at least 30-35s.
c)Then , While holding the paper clip take the power cable out from the device , wait for 10-15s and then plug the power cable back to the device while holding the paper clip.
d)Wait for another 10-15s and then release the paper clip.
e)Once we have all the lights back on to the device then take the power chord out and plug it back within 30s.
5)Once we follow the instructions the router will be reset to the default setting's and the internet connection will be terminated.
6)Open the IE page and in the address bar type the url:-http://www.routerlogin.com and then press enter key.
7)A small window will prompt up which will ask you to type the user name and password which will be
user name:-admin
password:-password
and then left click on log-in.
8)Once you will left click on log-in it will navigate you to the router's administrator page which will be netgear smart wizard page from where you can configure the router's setting's.
Posted on Nov 18, 2009
  • 1121 Answers
SOURCE: Wireless computers lose signal
try reset wireless settings
or reset to defaults and use a wpa2 Encript security.
Posted on Jan 15, 2010
Testimonial: "That worked.Thanks a lot"
My roku can not play on my tv
Does it connect to the INTERNET ? You need to set up your router to accept the roku. . Go to settings on on the roku screen and select wired or wireless connection however yours is connected and follow the instructions there. You will see the information the router needs to connect.
Aug 21, 2016 | Roku Televison & Video
Why doesn,t my roku accept my win or pass key when i type it in
First, you may have to input the password for your Router. Which you can get from your service provider. Call them to make sure you have the right password. The Roku itself will give you a different password. This is why it is important to write everything down for your devices.
Feb 11, 2015 | Roku Televison & Video
How can I enter password in roku 3 I don't know how it connect and not work
I have created this document that will step you through the setup and also enter your password for your network. Hope this helps you.
Follow these steps to setup your Roku player 1. Connect to your TV
  • Use a HDMI cable. Connect one end to the HDMI port of the Roku player, and the other end to an available HDMI input on your TV.
  • Make note of the TV input used.
2. Power up key components
  • Open the battery compartment and carefully insert the provided batteries into the slots, following the correct battery orientation.
  • Power up the Roku player by connecting the provided power adapter to the Roku player and to an available wall outlet.
  • Turn on your TV and select the correct TV input.
3. Connect to your network
  • If you are using a wireless network, select "Wireless" as your network connection:
  • Select your network from the list of available networks.
  • Enter your wireless network password when prompted. (Note: passwords are case-sensitive)
  • If you are using an Ethernet wired connection, select "Wired (Ethernet)" as your network connection.
4. Complete guided setup
  • Get the latest software
  • Your Roku player will let you know if there is a software update available, and will restart after the update
    is complete.
  • Link your Roku player from any Internet browser
  • A link code should be displayed on the TV screen after restart
  • Using an Internet browser, follow the instructions to link your Roku player to a new or an existing Roku account.
Help for common setup mistakes and solutions
Symptom
Possible causes
Try these!
I don't see any picture on the TV
TV is OFF
Cable loose
Roku is OFF
Wrong TV input
Ensure TV is ON (it's more common than you think)
Check all connectors are snugly in place
Check power adapter is snugly connected, and wall outlet is working
Select the correct TV input
I can not connect to wireless network
Weak wireless signal
Wrong wireless name
Wrong wireless password Wireless name hidden
Move Roku player location (even a few inches may help)
Ensure correct network name selected
Ensure correct password entered
SSID can be hidden, use "Add Network" from wireless network screen
My remote does not work
Not in line of site
Batteries weak
Get closer and ensure there are no obstacles between your remote and the Roku player
Try a fresh set of batteries
Resolving wireless connectivity
If your Roku player isn't connecting to your wireless network, try the following:
Description
Do this
Tips
Repeat guided setup • •
Go to Settings>Network>Wireless•
If "Update connection" is available, select it to refresh your connection
If not, just select your wireless network from the list, enter your wireless password when prompted
If you were previously and just lost connection, you may not need to enter your password again
Passwords are case-sensitive
Restart the Roku player and • your wireless network
Unplug the power connector from • the back of the Roku player
Unplug the power connector from the back of your wireless router
Unplug the power connector from the back of your modem
Plug the power connector back into modem (wait a couple of minutes for it to fully boot)
Plug the power connector back into the wireless router (wait a couple of minutes for it to fully boot)
Plug the power connector back into your Roku player, and wait for the image on your TV
Follow repeat guided instructions above
Your wireless router and modem may be combined as one device
Factory reset the Roku player
From the Roku home screen, sele•ct Settings>Factory reset and follow the instructions
Note: You can also reset the Roku• player using the reset button. Find the reset button on your Roku player, press and hold for 15-20 seconds ( the front LED will rapidly blink a few times)
Factory reset should be used as the last resort, if all other steps failed to recover functionality
After a reset, you will need to relink your Roku player to your Roku account, and setup subscribed channels with username and password, if applicable
If you forgot your password, you can recover it here at this URL:
Forgot Password
A new password will be sent to the email account listed in your account. If you do not see the email, be sure to check your spam filter.
Sep 12, 2014 | Computers & Internet
I just purchaset a ruko 2 . when setting it up it recognizes the my network,when I put in the correct password it will not accept it , what do I do,it picks up wireless network but will not connect to...
Roku only connects to the wireless network. In the wireless section of your router setup use MAC filtering. Enter the mac address of the roku and enable mac filtering on the router. Save the selections and that should solve the connection problem.
Mar 17, 2014 | Sharp Aquos Televison & Video
Can't find roku.com/link to enter code
I CAN NOT GET INTO MY ACCOUNT IT WANT ACCEPT MY PASSWORD
Aug 23, 2012 | Roku 2 HD
I AM TRYING TO INSTALL ROKU FROM MY PC TO A TV IN ANOTHER ROOM. I HAVE DONE EVERYTHING EXCEPT GET THE CODE IN THE ROKU ACCT. BUT CANNOT GET ROKU TO ACCEPT IT.
I need some info first.
1) Are you connecting by wireless connection to your roku device?
2) are you trying to input the roku code on their website, or are you trying to connect to a wireless access point with your device?
Oct 06, 2011 | Roku XD Streaming Player 1080P Wireless-N...
NetGear CG814WG 54 MBPS WIRELESS CABLE MODEM GATEWAY Router Logo
869 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
