Question about Maytag PYE2300AY Electric Dryer
Relaced thermostat and therma fuse, now dryer is tooo hot
Ok, my dryer quit heating last week, read over other similar problems, figured 3 suspects to be thermostat, therma fuse or element. So I checked them with ohm meter, my element read 11 or 12. the therma fuse read 1(which everything I read said it should be continous only) and nothing on thermostat, current was not running though it at all. So I go get replacement kit: thermostat and therma fuse. doubled check to make sure correct part #'s and used the correct therma fuse for a electric dyer. Ok, hooked up and oh ya I have heat now, too much heat. I even turned down to low heat on cool down cycle and within 3 mins. the top cover of lid towards the back was sooo hot almost burned me. I opened the dryer door and could see the element glowing behind cover, so hot it was close to meltdown it seemed. Help, what now or suggestions on what do to do, or check.
Thanks
J. Shofe
    Scholar:
  • 93 Answers
Sound like the thermostat is not working bud first check and double check the thermostat is connected properly and the wires are on correctly (not mixed up)and check the stat probe or bulb is in the correct place to pick up heat(assumeing that the stat is not a energy switch wich has no bulb)If you are not sure where the wires go there should be a diagram on the inside of the back panel or go on line to the manufacturer site and get one from them,
Hope this is of some assistance
Posted on Jan 26, 2009
Electric dryer getting way too hot
3-5 ACCESS TO THE BLOWER WHEEL OR THERMOSTATS
To get to the blower wheel, remove the back of the dryer.
The blower wheel is under the bottom of the lint screen duct to your left, as you look at the back of the dryer.
The operating thermostats are at the blower wheel outlet.
In electric models, the hi-temperature cutout thermostat is mounted to the heat riser.
3-6 TEMPERATURE CONTROLS AND HI-TEMP SAFETIES
These clothes dryer machines use operating thermostats to control the temperature inside the drum, and hi-limit thermostats to prevent overheating of the dryer drum.. Many machines also have extra temperature controls, such as bias thermostats and heaters, hi-temperature cutoffs, and thermal fuses.
Bias thermostats are just like regular operating thermostats, except that they are mounted inside a bias heater. When the bias heater is energized, it generates a small amount of heat, which causes the operating thermostat to open sooner, keeping the dryer drum cooler inside. Thus a bias heater allows a single operating thermostat to act like both a hi-temp and a lo-temp operating thermostat.
A thermal fuse is found on the blower outlet, right next to the operating thermostat(s.) This fuse will blow when too high a temperature is sensed at the outlet; usually when one of the operating thermostats has failed. If it blows, the motor may not start, or you may get no heat (no voltage to the burner.)
A thermal cut-off is mounted on the clothes dryer heater box. It is a back-up for the hi-limit thermostat. Whenever you replace it, you should replace the hi-limit thermostat, too. A high-temperature condition causes it to open, an overheated grounded heat element may also cause it to open.
Dec 01, 2013 | Kenmore Elite HE4 Electric Dryer
Stackable Kenmore model 110.98752. Dryer drum turns but no heat. Vent does not appear plugged since air does flow through to outlet.
With your volt ohm meter (VOM) check for 220 volts at the terminal block the cord attaches to.
If 220 is present, unplug the dryer and remove the rear panel.
With meter set to continuity check the thermostats and fuses on the heater as well as the heater coil. Remember to unplug the wires to each component to check them correctly.
You should read 120 volts from black to white and red to white for a complete circuit.
Look closely at the wires at the terminal for a burned wire.
No burned wire, open the wall outlet and inspect the wires and the female connections.
Read voltage at the wall connection for 220 volts and 120 volts from hot to neutral on both legs.
With the power disconnected you should take at least one wire off each thermostat and limit just to be sure you don't somehow get a false read.
If it runs at all and the heating element is OK then you most likely need a limit kit.
You dryer has a series of safetys. If the control thermostat fails, the filter housing gets blocked with lint, or the vent gets stopped up the heat could cause a fire. The bottom cannister thermostat limit is the lowest temp one 250F, it should shut down first if it fails then the limit mounted at the top of the cannister is set to Blow at 300F When it blows that is an indication of an external vent blockage. If the problem is from within the dryer then the fuse mounted on the blower housing will blow an the dryer won't run. The fuse is rated at 350F and is tied into the door switch. That is why the wires are smaller. They don't carry the heat load. If the duct fuse blows it is the same as if you opened the door. The dryer simply quits running.
Jul 16, 2011 | Kenmore Dryers
The dryer gets hot and then cuts off now it want even turn on I was wondering if it was the therma fuse, thermostat and the heat element that went wrong. E-mail address is mrcal32@hotmail.com
The cycling or operating thermostatis often the problem when a dryer runstoo hot, but there are also other things that can make it run hot also.
Here is a tip that I wrote that gives more details about why a clothes dryer will get too hot.
Clothes Dryergetting too hot
heatman101
Mar 26, 2011 | Maytag PYE2300AY Electric Dryer
I have a WHIRLPOOL LE7000XSW0 dryer. I recently replaced the thermal cutoff because it quit heating. Now it heats but is taking 3 cycles to dry a load. I tested all the elect. components , the heating coil...
If the heater is heating, probably the thermostat is ok. What does the ohmmeter read when you just short the two test leads together? Suspect low air flow through the machine--clean all passages including the outside vent of lint. Remove the lint screen and clean it of fabric softener deposits by washing it in hot water and detergent. Hope this helps!
Dec 28, 2010 | Whirlpool Dryers
NOT ENOUGH HEAT TAKES 3 TIMES THROOUGH TO DRY
i would check the thermostat first then change the igniter
Apr 13, 2010 | Whirlpool LGR8648L Gas Dryer
Hello. I have a Kenmore series 80 dryer approx 7
Sounds like your problem may be with the heating coil.
If you plan to try to repair the problem yourself, then the first thing you want to do is unplug the dryer from the electric.
Remove the back of the machine and try to locate the air duct going from the blower to the drum. Normally inside the air duct you will find the heating coil and the thermostats/thermistor.
Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if not you will need to replace the coil as it is faulty.
If the heating coil is ok, then:
You can check the thermostat/thermistor by removing the two wires and taping them together with electrical tape.
If the coil heats up then replace the thermostat/thermistor.
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST. This could cause a fire, as you have removed the saftey of overheat from the machine.
I will include these two websites for parts and further help:
http://www.partselect.com/
http://www.appliancepartspros.com/index.aspx
Both also have chat assistance 24/7.
Good Luck,
Hope this helps
Oct 19, 2009 | Kenmore Dryers
1 week ago the dry was extremely hot and now this week the dryer is cold and the clothes are wet.
Last week your cycling thermostat went bad. This week you thermal fuse went out. This is how it happened.
You dryer cycles on a thermostat. When it goes out the dryer then cycles on the (high limit) thermal fuse. When it goes out. The dryer stops heating. You will find both after you remove the back of the dryer. They are easy to replace. There are two different thermal fuses but if you order the parts using the model number you will have no problem. These two parts are sold in a kit.
Please rate this solution.
Sep 01, 2009 | Kenmore Dryers
My Whirlpool Dryer gets very hot, even at the air only setting, I have even ran the dryer on the cool down mode and it still get very how. Last week I had to change the heating element, since then the...
The problem that I see is that there should be no heat when running the air only setting. If you did not miswire anything, then I suspect the control board may have failed. You really need to use a multimeter to troubleshoot the machine so that you can see where the problem lies
Aug 03, 2009 | Whirlpool Dryers
Dryer runs but will not heat. Replaced fuse and
your cycling thermostat needs changed too. the thermal fuse is your last safety measure that goes, which means your cycling thermostat is not shutting down the heat element once it detects the right temp hot air in the blower housing so it let the heat element glow until either the high-limit sensor shuts the heat down or the thermal fuse blows. Change the cycling thermostat and good luck
Mar 06, 2009 | Whirlpool LER4634J Electric Dryer
Whirlpool Duet Dryer - Working but no heat
it sounds like your heating element is gone bad. there is no heat if they burn out or get corroded
Jun 28, 2008 | Whirlpool GEW9250 Electric Dryer
Maytag PYE2300AY Electric Dryer Logo
148 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
