I have a pmx300IC genie garage door opener. when i programmed my audi in car opener to the garage opener; the other two genie garage door remotes stopped working (no longer opened the door) only the audi did. so i cleared the code in the audi and pushed the learn code button on the garage door opener thinking i'd reset all three to the door opener; now none of them work. i need instructions to program the remotes.
When programming a genie remote press the learn button Then you will have to press the genie remote at least three times before it stores the code older genie models 5 times genie i
I bought a new keypad and 2 VISOR remote (30498). As to programming garage door opener, I did like here: programming garage door opener
- it tooks me 20 minutes and works great
Take the opener apart and see if there are about 4 numbers that can be set. If you have an older remote take it apart and match the numbers, then program it.
On some of the remotes you will find a toggle switch to change frequencies, this might help. Note all new openers are operating on a different frequency than slightly older ones due to military interference. Even though both might be intellicode they might not work together on the same remote. Sometimes some openers are harder to program than others. So lets try to program the harder one. You need to find and press the learn button on the motor head. Then press the button on the remote once. The led light by the learn button should not flash. If so try it over. The light should either stay lit or go out after the first press. If it does press it again and then a third time. If it ever flashes during the program process try again. The third or fourth time the motor should operate. If not you either have a bad remote or more than likely a bed logic board. Thanks BB
The other opener has to be a genie, compatible genie to be exact. An older one will not work with new devices. If it will not program it will be the openers fault not the remote. Thanks BB
Homelink Garage Door Opener Programming Procedure:
The procedure described below was successfully applied to a 2005 Jaguar S-Type.
To begin with, several attempts were made using the programming instructions contained in my Jaguar’s owner’s manual.Though the procedure described in the owner’s manual was straight-forward and understandable, I was unsuccessful in getting the vehicle’s remote to make my garage door opener function.The particular garage door openers I have are both made by Genie.Both openers utilize the “Rolling Code” feature.
To begin with, be sure to clear previous codes on your Jaguar’s garage door opener by first turning (rotating) the ignition key to the “I” position (first notch).Next, simultaneously hold button 1 (left most button) and button 3 (right most button) down until the middle button’s red light changes from continuous on to a rapid flash.This process takes approximately 20-25 seconds.What follows is a two part process.In the first part, get your Genie portable remote and hold it near (approximately 3 inches away from) your Jaguar’s garage door opener console buttons.Choose which button on your Jaguar’s remote you wish to dedicate to your Genie door opener and simultaneously press and hold your Genie opener button and your Jaguar’s opener button.The red light on your Jaguar’s center button (button #2) will light up and within 1-2 seconds will begin to flash rapidly.You have just completed part 1 of the two part process.
Part two:Now it is time to utilize the “Learn” function on your Genie garage door opener.Press the “Learn” button on your Genie garage door opener.The red LED adjacent to the “Learn” button will begin to flash.You now have 30 seconds in which to program your Jaguar’s opener button.Using the same button you just used in the “part 1” procedure, press and hold the same button for several seconds.As before, your Jaguar’s red light in the middle button will light up and within 1-2 seconds, it will flash rapidly.Release the button you are programming.Now, here is the key piece of information!Once again, press and hold that same button.Once again, the center button’s red light will flash rapidly.Release your newly programmed button.This procedure proved successful in my application.Here is what has just happened.The first time you pressed your Jaguar’s remote button tells the Genie opener that it exists and that it is a viable candidate for making your life easier (opening the damn door).The second time you press your Jaguar’s remote button confirms to the Genie’s rolling code that your Jaguar’s signal is legitimate and is to be trusted from then on.
