Question about Hdc Homer Hdc 2 Hp, 4 Gallon Pancake Air Compressor
Compressor seems to be seized up - Hdc Homer Hdc 2 Hp, 4 Gallon Pancake Air Compressor
Air compressor won't start
does the motor just buzz when you switch it on? if so renew the start caacitor
Mar 09, 2014 | Mi T M Mi-T-M AC1-PE15-20M Electric...
Samsung RSA1NTPE not cooling in either the fridge or freezer. Seems like the compressor is not running although it is hot too the touch.
the compressor is seized and wont pump and the motor keeps trying
to work and thats why its hot,sorry to tell you but you need a new
compressor
Aug 21, 2012 | Samsung Refrigerators
No Cold Air
it sounds as though the compressor is stalled or seized. if its seized a new will be required! If its stalled it may be down to a failed capacitor, if you have a voltmeter test for voltage at the compressor.
When shutting off leave it off for a good 24 hrs
All the best
Jul 05, 2010 | Danby DAC5071M Thru-Wall/Window Air...
Clutch seems seized, after short trip was smoking from front of compressor, clutch area.
it would be cheaper to pick one up at a salvage yard or Autozone, not to many people rebuilt compressors any more
Jan 19, 2010 | 1999 Chevrolet Astro
Serpintine belt broke . seems to have seized part on the bottom of the belt(the part that the belt tensioner sits on). need to replace belt.
your a/c compressor is probably seized up. have to replace or route belt around (but your a/c will not work.)
Dec 31, 2009 | 1996 Pontiac Grand Am
My air compressor seems to have frozen up
its seized buddy did you oil it try and turn it on the fan if its stiff new compressor im afraid bud
Nov 03, 2009 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Air Compressor stalls when it reaches @ 40psi. Have a
You need to find an amp probe from someone and use it to monitor the amps as the compressor is building up pressure. If the amps start increasing dramatically as it nears the stall point it would seem that you have a seizing problem or electrical motor problem. This answer only applies to the exact statement that you gave. ( Air Compressor stalls when it ). Mike micmor68@gmail.com
Oct 25, 2009 | Air Tools & Compressors
Compressor seized
the bearings are seized need to replace ac compressor
Aug 17, 2009 | 1996 Oldsmobile Aurora
Seized engine???
first thing i would make sure is to remove the belt from the engine and see if it turns then. possible siezed accessory pulley could stop engine. if still doesnt turn over with belt off, maybe remove spark plugs to see if will turn over then
Dec 10, 2008 | 2003 Hyundai Santa Fe
Hdc Homer Hdc 2 Hp, 4 Gallon Pancake Air Compressor Logo
22 people viewed this question
Top Hdc Homer Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you a Hdc Homer Air Tool and Compressor Expert? Answer questions, earn points and help others
