Question about Toshiba Satellite 4090XDVD Notebook
Update 4090 xcdt
Hi!! I have an old Toshiba Satellite 4090 Xcdt. I'd like upgrade the system, and replace the old 4 Gb (!!) hard disk. I'd also like to install Xp instead the Windows 98. Can I do all that? Thank you so much!!........
  • renzoerman Jan 19, 2009
    Tnank you very much to both of you!!!
  • Anonymous Feb 17, 2009
    I want to update the system which is running under Win 98 to the minimum I guess Win 98 SE to be able to connect a USB wi fi key . What do you suggest is it worth while ?. Best regards
  • 741 Answers
Yes, you can upgrade from Win98 to WinXP. The minimum hard drive requirements for WinXP is 1.5GB and the minimum RAM requirement is 64MB. You will also need a CD ROM for the install. Now those are the minimum requirements so don't expect it to go very fast. If possible I would recommend you upgrade to Win2000. WinXP and Win2000 are almost identical. The minimum hard drive for Win2000 is 650MB and for RAM it is 64MB. So you could still use your 4GB hard drive and have plenty of room. You will need a CD ROM for the Win2000 also.
Good luck if you have anymore questons let me know,
Don't forget to rate this solution before you log off.
Posted on Jan 19, 2009
Am trying to install win 2000,win xp my computer all ways show a blue screen hav change my ram and harddrive same thing help me pls send the solution to my mail pls thanks here is mymail box address:jerrylin_arems@yahoo.com
Posted on Feb 12, 2009
  • 2,229 Answers
I would not recommend you trying to install XP on this machine. The memory maxes out at 192 MB--not near enough to adequately run Windows XP which should have 1GB to run really well. It will function adequately with 512MB. Anything less, the system just drags. Couple this with the fact that you are running at 400 MHz with an Intel Celeron processor and a 66MHz bus speed, you will just be asking for trouble.
Can not find any place or panelon a toshiba satellite pro xcdt
Hi, are you sure you want to do this , replacing the processor is only feasable if its a plugin one and being that this is a pentium2 266mhz processor with edo ram and a very small hard drive , you may well be cheaper ,easier and better off buying a secondhand laptop from ebay or the like .
hope this helps
Jan 21, 2010 | Computers & Internet
Internal Hard Disk Upgrade
Yes, there is. Match the type of drive (Serial ATA or Parallel ATA) you get with what you have. Make sure your Satellite sees the drive in the BIOS. For drives larger than 120 GB, recommend operating systems Windows XP (Service Pack 2 or higher) or Vista. Older OS's have a 137 GB limitation (they only see the first 137 GB of the hard drive despite its size).
Mar 01, 2009 | Toshiba Satellite M45-S359: M45-S359...
Hard disk capacity increase
yeah you need to replace the old hard disk to new IDE 120GB hard disk.
Jan 20, 2009 | Toshiba 100GB Laptop for Satellite 2400,...
Toshiba tecra 730 xcdt
To open the BIOS configuration utility
Power Up the laptop while pressing the F2 key.
If F2 does not work, try again with ESC, or F10
The manual for this archived product does not exist on the support site. Try Toshiba Russia Support. Choose archives maybe you will find it.
Jan 19, 2009 | Toshiba Tecra 730CDT Notebook
Toshiba laptops satellite 4090
Hi, The laptop you purchased is an older model. It will use most any IDE laptop hard drive. The drive you mentioned from your Dell will work in it. You will need to pull the hard drive and put the sliders or hardware off the old one on to the new one. Look here for more info on your laptop. Look under portables.
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp?nav=Download
Nov 30, 2008 | Toshiba Satellite 4090XDVD Notebook
Is there more than one memory slot on a toshiba 4080 xcdt?
check your manual on the maximum amount of memory your motherboard can handle. 192mb is rather very small. check online for your computers specs.
Nov 08, 2008 | Toshiba Tecra 8000 Notebook
Toshiba Satellite 490 x cdt
Try the link . . . www.laptop-problem-solution.com
For find your best solution.
20
Sep 24, 2008 | Toshiba Tecra M1 PC Laptops
SYSTEM SETUP OR BOOT MENU FOR TOSHIBA A40
Restart the computer,
Right after the Toshiba logo appears start tapping the F8 key.
You will get an option to start in Safe Mode.
Select this option and let the computer start in Safe Mode.
If given the option you will want to log in as Administrator.
After you are logged in you will want to go to the Control Panel and then click on the Users link.
Select your account and choose to remove the password.
Reboot the computer and you should be able to access your account.
Jan 03, 2008 | Toshiba SATELLITE A10 A15 A20 A25 A35 A40...
My hard drive shows only 1.5 GB instead of 100
is it correct that you installed XP from an "upgrade" pack?
when you installed XP did you convert the file system to NTFS?
Dec 26, 2007 | Maxtor Hard Drive
Toshiba Satellite 4090XDVD Notebook Logo
310 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
