Question about Maxtor Hard Drive
Jumper placement how do I determine the correct jumper placement?
  • 4 more comments
  • Lisa Lf Jan 22, 2009
    i want slave jumper settings
  • vstupid1 Jan 22, 2009
    Please provide a short description/explanation of each jumber setting. Thanks
  • Anonymous Jan 25, 2009
    I have a 40GB hard drive by Maxtor. The drive doesn't tell me how to set the pin for a slave drive. Any idea on this?
    GH misterpcus@yahoo.com
  • rbelleci Apr 30, 2009
    Maxtor model: 5T020H2, HDA: 22A, PCBA: 05A, Unique: 33A code: TAH71DP0, Jumper: J48, Cable Select: ON. Pins >>> : : : . : <<<<< Which ones or one (if any) gets covered vertical. ??? Want to make this drive a slave.
    email: rbelleci@att.net
  • edgardaviles May 03, 2009
    53073H6 I wan to set it as master
  • polecat286 May 16, 2009
    maxtor 94610u6
    want to slave it or cable select
    need jumper sittings
    President:
  • 948 Answers
Look at the chart printed on the drive itself. If there is no chart, post what drive model it is and whether you want master or slave position. You do have an IDE drive, don't you?
Posted on Jan 19, 2009
Epson sd-621l jumper settings
drive is determined by placement on the cable, not jumpers.
Mar 29, 2014 | Epson SD-621L 1.2mb Internal Floppy Drive...
Bios pins where is correct placement on DELL 4400
Hello here is the homepage:
http://www.dell.com/support/drivers/us/en/04/Product/dimension-4400
To clear the CMOS values
1.Turn OFF the computer and unplug the Power cord.
2. If your motherboard uses jumpers move the jumper from pins 1-2(default) to pins 2-3. Keep the cap in this position for about 10-15 seconds, then move the cap back to its original position.
If you motherboard has only two pins for CMOS reset , then you may use use a metallic object like a wire to create a contact between the two pins for 10-15 seconds.
3.Plug the power cord and turn ON the computer .
The bios can also be set to reset, by removing the cmos battery.
Hope this will help you.
Feb 03, 2013 | Dell Dimension 8400 PC Desktop
What is the jumper pin placement to make a slave of a DiamondMax Plus 9, 80GB hard drive?
The manual is linked below and section 3.3.1 covers jumper settings.
The slave setting shows the park position so you have a jumper on the drive so you can reconfigure it later.
A quick answer is that the slave setting is no jumper at all on the jumper pins.
DiamondMax Plus 9 Manual - DiamondMaxPlus 9.book
Feb 12, 2011 | Maxtor Hard Drive
Where is the correct spot to put the magnet on the spoke for the v12 mini
The only placement requirement for the magnet is that it pass exactly next to the sending unit you mount on the fork (there is usually a mark on the unit). So, really the placement of the sending unit determines the "correct" placement of the magnet on the spoke.
May 09, 2010 | Topeak Panoram V12 Mini 12 Function Cycle...
What are the jumper pins on my Maxtor 6l200m0 and 6l200s0 sata drives for?
To control how the computer separates and assigns the drive's working order and placement.
The most basic positions are:
Master - By default the motherboard will boot to this drive first, therefore it's the "master"
Slave- What it sounds like. It's under the "Master" and isn't booted by default.
Cable Select (CS) - What it sounds like as well. The cable that goes from the motherboard to the hard drives. There are TWO positions at which the cable connects to the drives based on their placement. That placement determines which drive is master and which is slave. The advantage of this mode is it's ease of use. (Use only when you've got two hard drives)
That's the basics of the basics. There is A LOT more to those jumpers...but you won't ever need to know what so don't ask ;)
Let me know if you have any other questions.
Nov 22, 2009 | Maxtor Hard Drive
1987 MSD Distributor Cap Sparkplug Placement Help
First you need to determin witch one is #1 on cap Witch usely is the one directly behind carb. or throutle body. than its perty strate forward from there rotor runs clockwise. Cap only goes on one way. Food for thought when you chg. cap or wires one at a time is the rule even for a seasoned mechanic.
May 04, 2009 | 1987 Chevrolet Camaro
What are the jumper settings for a maxtor 90650u2 hard drive to use as master
Check out this site that has a diagram. With Maxtor being acquired by Seagate, it could be found here:
http://www.seagate.com/images/support/en/us/mxo_ata_jumpers.gif
May 01, 2008 | Computers & Internet
Using master, slave or cable select jumper
89c8602.gif SETTINGS:
A - Cable Select Mode
B - Slave Drive Mode
C - Mater Drive Mode
Enjoy!
Mar 01, 2008 | Lite On (LTN486S) Internal 48x CD-ROM...
Maxtor Hard Drive Logo
905 people viewed this question
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
terminalcon
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
