Question about Sony VAIO VGN-SZ460N/C Notebook
No screen and no sound power and battery indicator is on but hard drive indicator is off
Hi after initial start up suddenly my laptop got hung. then again it started and i ve uninstall one game from it and while unistalling i ve deleted one .dll file. and after that after power switch put on it show blank screen and no sound only battery and power indicator is on but hard drive indicator is off. does that is a cause or some hardware problem?
  • 432 Answers
Unplug the power adapter and take the battery out. After a minute, plug them back in and push the power button.
Posted on Jun 25, 2007
I was in facebook playing farmville, when suddenly the screen of my new laptop(toshiba satellite A660/07R)hung.i have no choice rather to power it off. when i switch back on,the screen flashes different...
With an extensive use of the notebook,
some times notebook would store some static charges which
indeed will stop the notebook from powering up or charging
the battery. The procedure to remove this static charges from
the notebook is known as power drain. Performing a power
drain procedure will not effect any personal data or delete
any pictures from the hard drive on your notebook.
I recommend you use Power Drain procedure by following these
steps:
1. Disconnect the AC Adapter.
2. Remove the Battery.
3. Hold the Power button down for 30 seconds to 1 minute.
4. Reconnect the AC adapter.
5. Turn on the Notebook power.
Dec 12, 2010 | Computers & Internet
While using my laptop, the machine started making a sudden clicking noise so I closed the notebook. Then when I opened it again the blue lights indicated that it was on but nothing showed up on the screen....
Try booting the computer with the hard drive removed. You can remove the drive from the bottom of the laptop, you'll see a hard drive icon with two screws on a panel.
What happens when you boot with the drive out?
Oct 15, 2010 | HP Pavilion dv6000z Notebook
Notebook won't start/lcd is blank but the power is on
You could have a faulty motherboard or RAM.
First remove the main battery and boot up the laptop without the main battery connected, if it boots up insert the battery, no need to power down. If that doesn't work, switch off/disconnect the adapter and insert the battery, then reseat the RAM modules and boot up.
If nothing works then you have a piece of junk. You can salvage the hard disk and put it into an USB hard drive adapter case and use it as an external USB hard drive.
Apr 12, 2009 | ASUS M51Sn-A1 PC Notebook
HP dv6000 screen is blank
Video chip failure on the main board join the hundreds with the same problem need a new mother \Board and it may still happen again to that one
Dec 09, 2008 | HP Pavilion dv6000z Notebook
Acer aspire 3000
Could be a bad memory chip or a hard drive crash. Can you hear the hard drive engage? If so, is there any clicking or dull thunking sounds? Both of these are indicators of a hard drive failure.
Jun 21, 2008 | Acer Aspire 3000 Notebook
Compaq armada 1580DMT
Sound's like you've had a hsrd drive crash. The message 32768 kb ok is a memory test, this indicates that something went wrong with the operating system the last time it was shut down. It should, after the memory test, either correct the system problem or give an error code. Since it does nothing, this indicates that the hard drive has failed and, unfortunately, needs to be replaced.
Jun 20, 2008 | Compaq Armada 1590DMT Notebook
Acer laptop stuck on Acer welcome screen.
Remove the hard drive and try it again, if no change also remove the DVD rom drive.
The computer is trying to access the drives, but failing and will just sit there and keep trying until it either succeeds or eventually fails & then will report it.
The fact it has hung like this would indicate the hard drive controller board has failed though and is no longer reporting back to the bios when it is queried.
If this gets you past that point, then before you take a hammer to the drive, reseat it back into the slot firmly and try it again.
Apr 29, 2008 | Acer Aspire 5610-4648 Notebook
Packard Bell Easynote M5255 - Will not boot up
option f2, go into bios setup and see if the hard drive is listed or detected. Auto detect hard drive save and exit. System will reboot if the same error occurs then the hard drive master boot record is probably corrupt or the hard drive has totally failed.
Apr 19, 2008 | Computers & Internet
Fter power switch put on it show blank screen and no sound only battery and power indicator is on but hard drive indicator is off. does that is a cause or some hardware problem?
it's possibly a hardware problem but you should make sure it isn't a software problem by putting in your system restore cd and restoring the DLL that you deleted, it could be an important system file. If it is a hardware problem, the first thing to try is taking out your memory and sticking it back in place, make sure it's clean and put it in there tight.
Jun 25, 2007 | Sony VAIO VGN-SZ460N/C Notebook
Sony VAIO VGN-SZ460N/C Notebook Logo
130 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Steve Allison
Steve Allison
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
