Question about Dryers
Electrolux tumble dryer T4250 E15 error code - Dryers
3 Suggested Answers
protek480
  • 1723 Answers
SOURCE: Electrolux tumble dryer
Power it down and then restart. Turn breaker off
Posted on Aug 27, 2009
protek480
  • 1723 Answers
SOURCE: Electrolux dryer error code e61
There is a 'tech sheet' in the back pf the dryer. Unplug machine, Remove the access panel on the back to get to it. Reach in and it should be there. It will tell you how to do a button check. You have to enter a test mode through the buttons.
The E 61 is a stuck button.
Enter function test mode and perform key
stuck closed (active). (button) test to determine which button is at
fault. Carefully free the and perform the test
again. If button is free but the key struck code
still exists, replace electronic control.
Posted on Sep 25, 2009
How to fix an error E 15 code on electrolux induction range
Thank you for your inquiry, Carol!
From what you have described your Electrolux range is displaying an error code of E15. I see you have reset your breaker and continue to receive the error code. The error code E15 means that your ESEC (Electronic Surface Element Control) test failed this could be a problem with your relay board or UIB (User Interface Board). When you reset your breaker did you leave it off for at least ten minutes? That is the best way to reset your range. You may need to seek assistance from a professional technician for proper diagnosis and repair. This will help you to avoid any unnecessary part purchases. Hopefully this information is helpful. -Matt
Aug 31, 2015 | Electrolux Kitchen Ranges
Fix e 15 error code on electrolux induction range model ew 30is6cjs have turned off barker to allow for reset. still get error code
Good Morning friend, thanks for your post!
I see your Electrolux range is displaying "E15" error code and you have reset your appliance but continue to receive the message. An "E15" error code stands for ESEC (Electronic Surface Element Control) self-test failed which could be a possible issue with your relay board or UIB (User Interface Board). I suggest seeking assistance from a technician to properly diagnose and repair your appliance to avoid any unnecessary part purchases. -Matt
Sep 26, 2014 | Electrolux Kitchen Ranges
What e54 error code mean on an electrolux dryer
You have not specified Tumble dryer model so I can not say for certain that my answer is correct. Fault codes can sometimes vary depending on the platforms appliances because today some manufacturers release new models twice a year and thay have the absolutlly right to make changes and improve the efficiency of new appliances (also change fault codes).
E54 - means the motor is inoperational.
Could be:
  • Excessive wash load.
  • Voltage too low.
  • Motor/transmission system inoperative.
Dado
Aug 09, 2014 | Electrolux Dryers
E64 error code electrolux dryer
E64 - Heater thermostat
  • Thermostat faulty (replace heater unit)
  • Heater unit faulty
  • Wiring faulty
  • Electronic board faulty.
Dado
Electrolux dryer t 3650
Error code E15
When the error code is displayed this can be due to the user having overfilled the dryer.
Remove some of the clothes, close the door, and press the start button
Aug 19, 2013 | Dryers
I HAVE A ELECTROLUX T3650 TUMBLE DRYER SHOWING E 08 FAULT
Hi - Typically error code E08 on Electrolux models indicates that it is recommended for a professional to check the mist value on the motor. Try resetting the unit by unplugging it or flipping the breaker to the household circuit breaker. Wait approximately ten minutes and turn on the dryer. If the error code does not clear and it is ineffective, contact a professional to move forward accurately.
Oct 12, 2012 | Electrolux Dryers
Dryers Logo
643 people viewed this question
Top Dryers Experts
