I have an older 27" zenith new horizons tv and am trying to hook up a Magnavox MDV3300 to it. I have tried channel 3 and channel 4, but i get nothing but white noise. I have verified the audio to audio and video to video (RCA) are correct.
2 Suggested Answers
  • 46 Answers
SOURCE: RCA TV - Trying to hookup new dvd/vcr player to old tv with only antenna input
The input on your television is probably coaxial (for cable or an antenna) which means it needs an RF modulated signal. You can find one of those at your local department or electronics stores. Just look for an "RF Modulator" or "video-RF convertor." They're most commonly used to hook video games up to older televisions.
Now, if you've got an old VCR handy, that has an external input, it already has the RF modulator built-in.
Posted on Nov 08, 2007
Zenith C27A24T 27" TV does
Greetings - You need to have you DVD player hooked up to the video inputs - See below. Don't mind the mouse scratch out lines. The Device on the right represents your DVD player.
You then have to choose video as your source on the TV (not channel 3 or 4) using your remote - see below.
You should be good to go.
Enjoy your movies,
Mikeywaf
May 22, 2011 | Zenith C27A24T 27" TV
I can't seem to change the channel from Channel 2 to 3 or 4. I don't have the remote. I am trying to hook it up to the VCR, but the VCR requires channel 3 or 4. Please help.
I have a Sony 27" TV. I tried the same thing on mine. I couldn't change the channel either. You will have to buy a cheap universal remote that will have a code on it for your TV.
Jul 23, 2010 | Zenith SY2765S TV
My magnavox 27 in TV will not let me select channels after I went to auto channel select. How do i reset it?
Be sure you have a signal connected to the RF [antenna jack] Connector! You may also have a corrupted EEprom. This is a common problem for this TV. But try the programming and be sure your menu says you are programming for Cable or Over the Air signals. And if you have a satellite or cablebox you shoud be on channel 3 or AV 1 or 2...in this case you need to do nothing..as the channels you select come from your satillite or cable box.
Jan 14, 2010 | Philips Magnavox 27MS343S 27" TV
Channel tuning 1994 Magnavox 27'' TV
U the remote to turn to the channel 3.
Nov 18, 2009 | Philips Magnavox 27MS343S 27" TV
Change to channel 3 rather than 2 on Zenith 27" withot a remote
You can use the menu button on the front to autoprogram the unit. Make sure the direct tv is on so the tuner will pick it up. After that, you can program the direct tv remote to operate the tv. The reason the channels won't change is there are none in the memory
Dec 19, 2008 | Zenith C27A24T 27" TV
DTV converter Box and Zenith system 3
I have the same problem.... On the back of the tv, there are three coax spots. One is for Cable, one is antenna decoder, and another is a loop. I have had zero luck getting any of those to receive the signal. Instead i have ran my digital signal to a vcr, then ran rca cables from it to my tv. I then put my tv in vcr mode, or aux depending on where you hooked it up. You can watch tv through your vcr this way.
Oct 10, 2008 | Zenith C27A24T 27" TV
Missing Channels
you may have a bad tuner that is the part that changes the channels. If there is the input jacks you can use them to input a VCR or cable box and use them as a tuner
Jul 24, 2008 | Zenith C27A24T 27" TV
Cannot get 27" magnavox closed caption
I called the Magnavox tech support - put the TV on channel 2,
hit the cc button repeatedly and problem solved.
thanks for contacting me.
Jun 25, 2008 | Philips Magnavox 27MS343S 27" TV
Programminng Channels
try hitting channel 00 , on older zeniths that will take you to input mode. hope this helps
Sep 15, 2007 | Zenith C27A24T 27" TV
Magnavox hdtv
The Magnavox 27MS343S is a standard analog 27" TV. It is not high definition and therefore cannot generate a posterized or pixelated picture. I will bet you are using a digital cable box or satellite reveiver and the problem is in that box, not the TV. Hook up a regular VCR to the TV, set the TV to channel 3, put in a good pre-recorded tape and hit PLAY. If the tape plays nice and clear on the TV, the problem is in your digital box.
Sep 07, 2007 | Philips Magnavox 27MS343S 27" TV
Televison & Video Logo
Top Televison & Video Experts
