Question about Apex Digital Televison & Video
Where is the optical output connection on my Apex TV
I'm trying to hook up a Yamaha sound bar and it says to connect it to the optical output on the TV.
skotkolr
  • 558 Answers
SOURCE: Trying to connect digital audio output optical terminal to existing analalogue hi-fi amplifier
there should be on the tv out a red and white rca output or a coaxial, your yamaha my be too old to deal with the outputs on the tv. at the jvc website you can download the manual for this tv.
Posted on Apr 27, 2008
SOURCE: Proscan 32LA25Q Audio output
Check the manuals and seen may be something.
Posted on Dec 31, 2008
JollyRoger00
  • 59 Answers
SOURCE: Digital Audio Output Problem
connect the optical line from the DTV box to the audio system directly.
Posted on Sep 24, 2009
SOURCE: HDtv picture and av reciever sound do not match
I have a hdtv hooked up with a virgin v+ box but slight delay Why?
Posted on Dec 16, 2009
satavlad
  • 405 Answers
SOURCE: looking for an output on the tv to hook up sound
Almost every Sharp TV has DIGITAL AUDIO OUTPUT - optical interface.
You will need TOSLINK cable to connect soundbar to the TV.
Posted on Dec 29, 2009
How do you hook up sound bar to a element tv?
That depends on the inputs on the sound bar. Some have both RCA style connectors and others have a fiber optic cable only. If your TV has an optical output connection (may be covered so the red led doesn't shine on a wall) Obtain the cable needed for your particular setup and connect them. In the audio setup section of your TV you have to select external or optical to energize the port you're connected to
Mar 16, 2017 | Element Televison & Video
I have a 42 Insignia TV and a Vizio 3821 sound bar. I also have Dish Network Hopper on this TV. I have tried all sorts of hook ups, but still no sound. Help
Soundbar & TV connection issues...Please Help!! - TV - Audio
www.tomsguide.com/answers/id.../soundbar-connection-issues.html
Aug 5, 2013 - the tv does have an optical output according to the website, it may just look hidden because ... I am trying(without success) to connect a JBL SB100soundbar to a Samsung ... Since your sound bar has an optical in then problem solved. .... a b x TV. August 5, 2013 10:32:42 AM. something like this should do ...
How to Connect a Soundbar to TV audio - YouTube
? 3:19
https://www.youtube.com/watch?v=Z27WtBy4IUs
Nov 22, 2013 - Uploaded by All About Home Electronics.com
The issue is not how to plug the cables in, it's all color coded and easy. ... I have a Sanyo sound bar but it won't connect to my LGtv nor my ps4!
Amazon.com: Sound Bars
Jan 10, 2016 | Vizio Televison & Video
Why doesn't my lg soundbar play sound from the optical cord connected to the TV?
one issue could be power source to the sound bar, another could be that the optical cord is not hooked to the power output source, if you have cable or satelllite then that is your source, not tv
Sep 03, 2014 | LG NB3510A 2.1 Sound Bar with Subwoofer -...
Hook up samsung sound bar to lg smart tv
easiest way would be to connect the optical audio output from the tv to the optical input on the soundbar. You may have to go into the tv's setup menu and enable the audio output jack
May 10, 2014 | Samsung HW-D450 Sound Bar
I just bought a LG blue tooth capable surround sound. The instructions say I need to hook the cord to the optical in connection, but my tv doesn't have it. Is there an adapter I can get?
If your tv does not have an optical audio output you can get an analog to optical adaptor. Radio shack . Ebay , do a google search. Check your sound bar for an analog input. Hope this helps.
May 30, 2013 | Televison & Video
LG blue ray won't play sound from RCA sound bar. HDMI cable is hooked into HDMi slot on TV
the details you provided were very vague, however from my experience when a device is connected to another device via and audio capable hdmi cable, that device renders it audio output to the device its connected to and normally turn off all other audio outputs beside optical- I would assume there is an option in the blue ray player to turn off hdmi audio, which will in turn activate other audio outputs- you may also look for audio out port on your tv, it is ideal to connect the sound bar directly to the tv set audio out ports. To sum this up,
if you plan to use your player via hdmi cable you need to turn off hdmi audio output on the blue ray player and the plug an audio cable from your blue-ray player to your sound bar
you may also as i said connect your sound bar directly to your tv, the issue is most tv sets now a days do not have an audio out port, if you do then everything you play thru your tv will have audio via sound bar
there are several way to go here but unless your sound bar has hdmi av switching capabilities (im sure not) this is one of the most simple--Good Luck.
Jan 29, 2013 | Audio Players & Recorders
Yamaha HTR-6230 receiver set up w/HDMI no sound
BD and DVR hooked up to the receiver and from the receiver to the TV right? If yes: Your receiver set to pass sound trough to the TV, if you want sound from the home theater setting has to be changed.
Nov 28, 2009 | Yamaha RX-V463 Receiver
Problem hooking up my Yamaha RX-V461 to my PS3
When you connect the optical cable to the ps3 you must change the output to optical on the ps3. To do this, startup your ps3 then go to settings then audio output settings and change it to Digital Out (Optical).
Dec 01, 2008 | Yamaha RX-V461 AV Receiver
Optical output, no sound!
Have you selected Optical output from the audio setup screen of the TV? That needs to be selected to transfer TV audio to the optical out of the TV.
Jul 28, 2017 | Sony KDS-60A2000 60" HDTV
Televison & Video Logo
154 people viewed this question
Top Apex Digital Televison & Video Experts
Jaime Hernandez
robert landry
Are you an Apex Digital Televison and Video Expert? Answer questions, earn points and help others
