Question about Mr. Heater (F274825)
MH 18 B wont stay lit
Will lite and burn for about 20 minutes then go out. Will relite later and burn again for about 20 min. ???
    Novelist:
  • 88 Answers
Sounds like you have a limit safety issue, the unit is over heating and kicking out on high limit, or the limit is weak, either way you should look into replacing the limit, hope that helps
Posted on Jan 20, 2009
Majestic gas fireplace mmodel majestic fireplace 36CDVXTRN will not stay lite after 20 minutes.
If you are able to , open the burner box , the igniter has a thermocouple ( might look like a thick wire that would be in the flame if it were on). If it gets corroded or junked up it will not register the flames presence and will shut off the gas). Take an emory cloth and polish it. Hope it helps.
Feb 05, 2014 | Heating & Cooling
Gas fire wont stay lit
The thermostat probably reached the set temp, but maybe the pilot lite blew out. Or the control needs to be replaced.
Nov 25, 2013 | Kitchen Appliances - Others
I bought from a private party a used Wolf range Challenger Model CHR-4-29-HB11, oven worked fine. First I was baking and heard stove making a phfttt, phftt, noise. Then took food out and noticed oven...
Pilot lights go out because the Thermocoupler is either bad or not getting hot enough. It will be a copper tube that should touch the pilot light flame. these are replaceable and usually any appliance repair supplier can get you one. Some units reuire changing out the entire gas control
Oct 17, 2013 | Wolf Range CHR-10-229-FT11 Kitchen Range
Pilot lite won't stay lit
Thermostat flame sensor. Do you see a little rod next to the pilot? That is what tells the main gas valve that the pilot is lit and it is safe to give gas. Easy swap, and you can usually just pick up a generic one.
Apr 14, 2013 | Heating & Cooling
My Kozy heater turns off after a few minutes, I then have to re light it and when it kicks on again after a few mins it turns off again. It will stay lite if I turn it down but when it goes on agin it will...
If you have a standing pilot that wont stay lit and you have to keep relighting it, it can only be a couple of things that will do this.
1. Try tighting the thermocouple at the gas valve. (this is a thin copper line that goes from the gas valve and goes to the pilot light.)
2. Make sure that the tip of the thermocouple is in the pilot light flame.
3. Make sure that the thermocouple is clean.
Mar 22, 2011 | The Companion Group Kozy World Portable...
Pilot light wont stay onfor outside pool heater. Gas co made a service call & relit the pilot light it went out again 4 days later.
There is a thermo couple that keeps the gas on. The pilot light bracket has a small screen where the gas comes through that can get clogged and cause the pilot light to burn away from the thermo couple which would cause it to think the flame has went out and shut the gas off. Or the thermo couple has went bad itself. If you try cleaning the screen use canned air and gently blow it through the orfice once you have taken it off. If you don't know what a thermo couple is or looks like here's a picture of a generic one that will give you an idea. Usually there's a bracket that holds this in place. f1b528a.jpg
May 09, 2010 | Pool & Spa
Pilot lites; but, as soon as I turn on gas flame
sounds like your thermacouplar is going out and needs replaced. Sometimes these will act like they are working fine , but when the pilot stays on for awhile and later goes out it is a sure sign that it is bad
Nov 08, 2009 | Procom ML300TBA Heater
My universal lp forced air heater model 30 fsa wont stay lit
if its lit by a pilot your thermocouple is bad the purpose of the thermocouple it to keep the gas valve open
Oct 24, 2009 | Reddy HEATER RLP30 30,000-BTU PORTABLE LP...
Stays lit for 25 minutes and shuts off
How large and sealed of an area are you using it in? I ask because those units have a low oxygen sensor which will shut it down if there is not enough oxygen in the space.(kinda prevents that pesky suffocation thing). Otherwise if using it in larger cold spaces, the issue is can be from the smaller tanks. As mentioned above, a larger tank can solve this, because these units have a fairly good input rate, which will cause the smaller tanks to freeze, and lower the propane temperature and evaporation rate, basically runs out of gas until the tank warms back up.
Jan 19, 2009 | Mr. Heater (F274825)
Mr. Heater (F274825) Logo
319 people viewed this question
Top Mr. Heater Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Mack Baxter
Are you a Mr. Heater Heating and Cooling Expert? Answer questions, earn points and help others
