Question about Motorola Mobility SLVR L7 Cellular Phone
Power loss All of a sudden my phone seems to be using a lot of power. I have brought a new battery but this has made no difference. From a full charge it now drops a bar in 12 hours just sitting on stand by. can anyone help ?
  • Piers Carter
    Piers Carter Apr 27, 2008
    Hi we found a solution in the end, we purchased a new sim card and that sorted it out. We first tested the old sim in another phone and that to used excessive power as well. It was all very strange but a new sim from orange with the same number etc. sorted it out. Thanks to everyone who tried to solve it.
Hello sir tell me how i can downloand theme aur tones
Posted on Nov 05, 2008
  • 55 Answers
Some things that can impact you battery standby time.
  • Location (Basements and areas with poor reception will drain your battery quick)
  • Settings (If you have changed the settings to extend the timeouts on your backlights, or set the phone to vibrate and are recieving text reminders while in standby/overnight will drain your battery)
You can try defaulting your phone's settings.
If this improves your standby time it was a setting.
Posted on Apr 25, 2008
  • RaeYa
    RaeYa Apr 25, 2008
    Another thing that can drain you battery is leaving your Blue Tooth transmitter on when you are not using it.
    I suggest turning it off on you connections manager.
    Novelist:
  • 114 Answers
I WOULD CHECK YOUR CHARGER THAT PLUGS INTO THE WALL FOR PROPER VOLTAGE AMD m/A ... IT WILL BE MARKED. YOUR LOCAL CELL STORE WILL CHECK IT FOR YOU
Posted on Jun 25, 2007
Sudden loss of power
Are you sure the battery is being drained during this process? That would be a major draw from something, but then you said "...suddenly full power again,". It sounds more like a connection or a terminal working loose at times, not able to pass normal voltage. You sure need a voltmeter, my friend.
I think I would want to have that new alternator tested again, just to make sure it is not defective. A lot of aftermarket parts are turning up like that. Did you replace the alternator and battery because this condition was present? Do you know your battery cables and ground points are all good and secure, and corrosion free? You might want to double check all the grounds you can find- the battery negative cable, the engine to body strap, or cable, maybe an engine and computer harness ground point-look around the top of the engine for a ground wire coming out of the engine wire harness and going to ground at a nearby bolt. Also check all alternator connections.
If you have to keep looking, look at the power side of the power distribution scheme. From the battery, power goes to the Power Distribution Center, maybe called a junction box or junction block...it is where the fuse and relay block under the hood receives power, both from the battery and the tie-in from the alternator, and then distributes it to the major circuits for the car. With all your symptoms, it sounds like the problem is not far from the battery in the power distribution. Sayeth Dr. monte. Good luck.
Sep 14, 2014 | 1994 Hyundai Excel
Hi there, I have a MiproACT-707 TM, which i use while teaching aerobics classes. After working perfectly for about 10-15 minutes - it stops working completely. This happens with brand new fully charged...
Hi, I would first ask if you are using a Ni-cad rechargeable battery system, these are not optimum performers for such a high drain microphone as probably the one you're using. Especially if the mic. takes a single 9 volt battery ( the average ni-cad 9 volt is about 200 milliamp hours, not a lot. If so-try switching to nickel metal hydride ( Ni-Mh ) these are better for high drain devices and do not develope a " MEMORY " effect ( which will cause rather sudden power loss ) memory effect can happen to almost brand new batteries as well, all it take to incur this is to charge a Ni-cad before it is totally dead. good luck, and thanks for choosing FixYa-Prodzilla
Apr 20, 2011 | Mipro Audio Players & Recorders
Battery doesnt last long on full recharge and its a new battery and new charger
What are you using your phone for? The amount of power the phone consumes differs dramatically depending on how often you use it and if you play games / browse the internet a lot. etc. Try using the phone only for sms' and calls and see if there is a difference.
If the battery is losing power quickly even while the phone isn't being used often / at all, it could be a problem with your phone - and not the battery/charger. I recommend taking it to a repair center / technician to have both the phone and the battery checked out.
It has happened in the past that two batteries in a row are a dud - so it is best to have both checked.
Good luck,
-LL
Feb 23, 2010 | Motorola Mobility MOTORAZR2 V9 Cellular...
Battery goes flat very quickly
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} If you use a car charger, use a wall plug instead and replace the battery; because a lot of car chargers can harm battery life…especially if that is all you’ve ever used. Also check the settings on the phone, if you have disabled power saving features that dim the screen after so many seconds then the backlight will drain the battery very quickly. Use name brand batteries and not the ones that come with the phone. If you have not tried to buy a new battery yet, the ones that come with the phone can often ****. Finally, make sure that you do not have a short in your wall charger and that the first time you use a new battery you charge it fully to begin with and don’t charge it again until it is completely depleted. Supposedly newer batteries do not have to be primed, but I find it is a good practice anyway.
Oct 02, 2009 | LG KU990 Viewty
My Sony Vaio PCG-z1wa suddenly shuts off if the battery is not attached. In other words, I have to be constantly charging the battery or it would shut off all of the sudden. It obviously seem like it is an...
there are a lot of cuase on auto shut off the laptops..
posseble if..
1. if the battery not inserted on laptop... it means you using the charger when you disconnect or loss the connection, auto shut off.
2.if the battery inserted and full of charge.. then make auto shuto off.. this problem,, sometime overheating,, A. fun not working properly..B. shortage of cheps.
try to check the charger and battery,,, use another charger to test observe atlest 30minuts.. the problem the sam auto shut off.. check the cpu fan.. or processor
note" if under warranty don't open it. bring to warranty..
May 31, 2009 | Sony VAIO PCG-Z1WAMP1 Notebook
Htc p3400i windows mobile....Battery Charging Problam!
I am also facing the same problem with my O2 XDA mini. It seems to be the problem with the battery/charger. Are you using genuine battery/chargers that came with the phone? I am using a local battery so assume that it has to do something with the battery itself.
May 12, 2009 | Cell Phones
Sudden Battery drainage - from full charge within 14 hours
turn off bluetooth if its on because bluetooth wastes battery life on any phone.
go to Tools > Settings > Personal > Display > and change the light settings. if its on the highest light setting then that would be a major factor on why your battery is draining quickly.
hold the menu button and check if any applications are still open, close any that you don't need open.
Apr 20, 2009 | Nokia N95 Smartphone
Motorola V3 battery suddenly empty
You really need to Upgrade to a New Phone. My RAZR did the Same thing for over a Year and a Half until the Flip screen went Completely Blank.
Jan 04, 2009 | Motorola Mobility RAZR V3
Charge
hi your battery has created a memory because you didn't follow simple battery guidelines:
For a new phone with a new battery;
1)Use the phone the first time until the battery dies,
2)Do a full charge - 6-8hours for the first time
3)Use the phone until it dies the second time
4)recharge the battery for 3-5 hours
then your battery should be good, but now your battery needs to be changed, as it already has memory and can only be restored if completely discharged by a battery conditioner
Jan 30, 2008 | Motorola Mobility RAZR V3
Motorola Mobility SLVR L7 Cellular Phone Logo
59 people viewed this question
Top Motorola Mobility Cell Phones Experts
vince
D. E. Hev
Mark Magill
Mark Magill
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
