Question about Flotec 1 Hp Deep Well Pump
Motor running but not pumping any water, why?
Flotec, 1hp, deep well pump, f3332 model
  • 1 more comment
  • mark_s_kamin Jan 19, 2009
    this is a brand new motor and is in the water, unclogged in take ports. I can hear the motor running, just no water is pumping up.
    wow, say it is not true, I have had great luck with flotec in the past, this is so sad, but based on all the trouble shooting I have done, the brand new pump is my the only option to replace. sad day for flotec
  • Anonymous Mar 31, 2014
    Motor 1HP suguna make under warranty period.
    President:
  • 1,990 Answers
You very well could have a bunch of Sediment on the Intake for the Water OR The water table has Drpped Below the Pump.
Posted on Jan 19, 2009
  • Travis Humphries
    Travis Humphries Jan 19, 2009
    Got the Same pump on my Well right Now. I had to go through 3 Before I got one that works Correctly.
  • Travis Humphries
    Sorry about that! I hate too tell people bad news!
I hAVE REPLACED MY 1/2 WATER PUMP FROM MADE FROM GE WITH A FLOTEC 3/4 JET PUMP AN DNOW i AM HAVING PROBLEM WITH THE MOTOR. PUMP DOES NOT START, SOUND A MUMMM SOUND. WHAT IS WRONG WITH THIS PUMP?
Hi Anonymous, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? have you tested the power?
Jul 27, 2014 | Flotec 3/4 HP Deep-Well Convertible Jet...
Water pump not running
Hi have you removed the pump from the well and tested if it will run without going via the presure switch. It could be that the pump is blocked. If it is blocked and has been for a while it may well have burnt out the pump. How deep is your well and how far from the bottom of the well is the pump. The pump should be positioned a good distance from the bottom of the well to prevent any silt getting into the pump to block it. I have a 110 meter deep well and the water level is 38 meters below ground. I have the pump at 50 meters below ground. I have only changed the pump once in 10 years.
I hope this helps
Steve
Mar 27, 2014 | Flotec 1 Hp Deep Well Pump
Pentax water pump
If the pump runs manually as you state, then the problem probably has to do with the control for the pump. It could be a bad capacitor in the control , but I'm not sure there are replacement parts for these control units. Possibly you need a new control unit.
Mar 21, 2014 | Flotec 3-Wire Submersible Pump - Fp3332-09...
Flotec pump 1hp motor has become too noisy when running
Is it the pump or motor. Pumps do wear out and need rebuilding or replacement.
Dec 17, 2013 | Plumbing
It could be one of three things, the inlet is plugged, the outlet is plugged or the pump is bad. I am assuming it worked properly until this failure. I am guessing but it has to be one of those three.
Dec 14, 2013 | Flotec Plumbing
When pump runs it is very loud
depending on the noise, it could be cavitating, due to air leaking into the inlet side, or it could have faulty bearings. If its a screechy noise, then probably bearings.
Dec 10, 2013 | Goulds Pumps 1HP J10 Deep Well Cast-Iron...
Flotec pump problem
Thank you for posting your question here on Fixya.com.
No, only a thermal overload. If the unit was hot and has had a chance to cool off it should start. If you have voltage to the motor and it will not even hum or buzz, you need a new motor. The short must have blown the winding open.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Mar 28, 2010 | Flotec Corrosion Resistant Shallow Well...
Schematic for wiring in a Flotec Pump
Remove end casing of Flotec motor housing they have a 115v/220v switch, turn to 220v, see website flowtec water. Flotec parts 1-800-365-6832
Jan 31, 2009 | Flotec Corrosion Resistant Shallow Well...
Low water flow
sounds like air is trapped in the system somewhere. that is why any pump will surge. check the lines going in to make sure it isn't sucking air somewhere along the way and make sure the discharge line is clear so it can pump out fully.
Jan 22, 2009 | Flotec Simer/Flotec/Omni 2105 Swimming...
Flotec 1 Hp Deep Well Pump Logo
745 people viewed this question
Top Flotec Garden Experts
Jay Finke
Jay Finke
Mike Raino
Level 1 Expert
jasbo
jasbo
Are you a Flotec Garden Expert? Answer questions, earn points and help others
