Question about Pride Jazzy Select 6 Indoor Power Wheelchair
Location of model number of jazzy select power wheelchair?
5 Suggested Answers
  • 61 Answers
SOURCE: Somehow I have locked my Jazzy 6 Select Electric
Try This:
To unlock the power chair.
1. Use the on / off button to switch the control system on. The maximum speed / profile indicator will be rippling up and down.
2. Deflect the joystick forward until the control system beeps.
3. Deflect the joystick in reverse until the control system beeps.
4. Release the joystick, there will be a long beep.
5. The power chair should now be unlocked.
Hope it works.
Posted on Mar 29, 2010
  • 177 Answers
SOURCE: Jazzy 1113 ATS Indoor Power Wheelchair: the battery is fully charged but it wont move does...
Hi. Your machine probably has a fault, but I very much doubt that it needs reprogramming.
Are the free-wheel levers in the correct place? Is the machine displaying any fault codes, e.g. flashing LED's and what is the pattern or number of flashes between pauses?
Good luck. Neil.
Posted on Jun 01, 2010
HoverTech
  • 232 Answers
SOURCE: replaced battery in jazzy 600
Make sure that your drive wheels are engaged and the power chair is not in the freehweel position (so it can be pushed).
Posted on Oct 29, 2010
wcdoc1953
  • 280 Answers
SOURCE: Pride Jazzy 1121 power wheelchair has leaked oil
There's not too much you can do about the gearbox leaking oil. The gearbox will usually leak at the top gasket or seals. I suppose you could try to re-torque the bolts holding the top gearbox flange, but the other seals are usually leak due to age or overheating. If you pull it apart to re-torque the bolts, you might as well replace it along with the motor and brake. The gearbox grease stains are hard if not impossible to remove from carpeting and flooring.
If the motor drags you could have a bad brake which indicates you should replace the entire assembly. If the chair veers to the right you might have one motor spinning faster than the other due to age or damage. You can go into the programming menu with a hand held programmer and adjust the steering correct to compensate for the motor difference.
The bottom line is that you are due to replace at least one brake/motor/gearbox very soon. I usually replace them as a pair since the other side will also need replacement soon.
The motor/brake/gearbox assembly will run you about $700 for each side. Labor cost will be about 1 to 1.5 hour per side.
This is an older model Jazzy which was very sturdy, reliable and popular. You should evaluate the condition of the other components when deciding how much to spend on the repair. Replacement for a comparable chair has gone up considerably and I personally don't think the motor quality is as good. Hope this helps.
Posted on Jan 09, 2011
What batteries do I need for a jazzy select6 pride
information and batteries for sale.
info
Jazzy Select 6 - Specifications, Owner's Manual, Features & Benefits
www.pridemobility.com > Jazzy Power Chairs > Models
  1. Cached
  2. Similar
In-line motor technology for increased efficiency, torque and range. Built with ease of service in mind. Easy side access batteries. Tool-less front panel access to ...
[PDF]Jazzy Select Series - Pride Mobility
www.pridemobility.com/pdf/owners_manuals/us_jazzy/us_select_series_om.pdf
  1. Cached
  2. Similar
6 www.pridemobility.com. Jazzy Select Series. II. SAFETY. Do not connect an extension cord to the AC/DC converter or the battery charger. Removal of ... Batteries for Sale
Pride Mobility Jazzy Select 6 Ultra Wheelchair and Mobility Batteries at ...
https://www.batteriesplus.com > Batteries > Wheelchair and Mobility > Pride Mobility
  1. Cached
  2. Similar
If you rely on a Pride Mobility Jazzy Select 6 Ultra powered wheelchair or personal mobility scooter to get around, Batteries Plus Bulbs can help you find the ...
Pride Jazzy Select 6 Power Chair from Pride Mobility ' 1800wheelchair ...
www.1800wheelchair.ca > Brand Showcase > Pride Mobility > Pride Powerchairs
  1. Cached
The Jazzy Select 6 Power Wheelchair from Pride Mobility is the ultimate ... Easy side access batteries; Full-length, flip-up armrests; Solid flat-free tires; Foot ...
24V 3Amp Jazzy Select 6 Ultra Scooter Battery Charger: Amazon.ca ...
https://www.amazon.ca/Jazzy-Select-Scooter-Battery-Charger/dp/B00CIZ1GW6
  1. Cached
24V 3Amp Jazzy Select 6 Ultra Scooter Battery Charger: Amazon.ca: Sports & Outdoors.
Pride Mobility Jazzy Select 6 12V 35Ah Wheelchair Battery
https://www.amazon.com/Mobility-Jazzy-Select-Wheelchair-Battery/dp/B009DKGCC8
  1. Cached
Rating: 5 - ‎1 review Buy Pride Mobility Jazzy Select 6 12V 35Ah Wheelchair Battery - This is an AJC Brand® Replacement on Amazon.com ? FREE SHIPPING on qualified orders.
ALL THE INFO HERE BELOW
Google
Nov 24, 2016 | Pride Health & Beauty
How to stop squeaky wheels
My tires squeak how can i fix the problem and what ... - Fixya
www.fixya.com > ... > Pride > Jazzy Select 6 Indoor Power Wheelchair
Apr 14, 2012 - my tires squeak how can i fix the problem and what can i use - PrideJazzy ... Question about Pride Jazzy Select 6 Indoor Power Wheelchair ... I have a mpv 5 hoveround wheel chair and I now have a flat on the front left tire.
[PDF]Jazzy Select Series Owners Manual - Pride Mobility Products
www.pridemobility.com/...jazzy/us_select_series_om.pdf
Pride MobilityJazzy Select 6 with Power Seat. JAZZY. SELECT SERIES. Including Models: Jazzy Select, Jazzy Select 6, and .... Battery charger for indoor use only. .... Take wide swings with your power chair's front wheels around any tight corners. ... desired, allow it to come to a complete stop by releasing the joystick, then push the ...
[PDF]Jazzy Select Series - Pride Mobility Products
Dec 28, 2015 | Pride Jazzy Select 6 Indoor Power...
What is the model number for the jazzy select power chair?
Would say it is Jazzy Select 14. But to make sure please check if it is the same as the one in this user manual.
http://www.pridemobility.com.au/default/assets/pdf/Owners_Manuals/AU_Select14_om.pdf
But if you are looking at the US models then it might be different.
see this manual.
http://www.pridemobility.com/pdf/Owners_Manuals/US_Jazzy/US_Select_Series_om.pdf
Aug 21, 2014 | Health & Beauty
Why does my jazzy select six lights blink but wont go
The number of flashes indicate the problem. Go to Pride's website to download the service manual. It will tell you what the flashes mean and how to fix it.
Jul 20, 2014 | Pride Jazzy Select 6 Indoor Power...
Locating fuse in charger for jazzy select 6
The Main Circuit Breaker is located on the front base cover near the left drive wheel. I am not aware of a fuse on this model.
Apr 07, 2013 | Pride Jazzy Select 6 Indoor Power...
Where is the freewheel lever located on the jazzy 1113?
Original Jazzy Select has push-down levers on each side behind powered wheels. These manually disengage the brakes on each motor individually. They are about 6 inches long and push down an inch or so. I don;t know about other more current models, The 2 smaller wires to each motor disengage the brake when given power (24 volt, I think). The 2 larger wires run the motor.
Jun 17, 2012 | Pride Jazzy 1113 ATS Indoor Power...
Have a jazzy I bought from a cousin , its a jazzy jet 2 from the year 2000 need help to get manual ,where can i find it
log onto pridemobility.com and select jazzy then select user manuals then look under discontinued models and find Jet 2 you should be able to download the manual Hope this helps
Mar 12, 2011 | Heavyduty Jazzy 1121 Standard & Heavy Duty...
What kind of Jazzy select 6 power chair does my Mom have? Serial number J92037090688C30. We live far away from each other and I need to know what she got.
Here's a link to Pride Mobility, maker of the Jazzy wheelchairs. This takes you to the Select 6; there's also a Select 6 Ultra. Just click on models and it will display all of their line of equipment.
Sep 30, 2009 | Select Products Power Chair Pride Jazzy...
Pride Jazzy Select 6 Indoor Power Wheelchair Logo
386 people viewed this question
Top Pride Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
