Question about Mr. Heater (F274825)
Stays lit for 25 minutes and shuts off
Model MH 18 B Stays lit for about twenty minutes then shuts off. Will relite in several minutes and stay lit for another 20 minutes or so. The heater has been used only two times.
  • offshoretoo Jan 19, 2009
    Thanks. I am using the two 1 lb. cylinders. No light breeze. Thank you.
  • 20 Answers
How large and sealed of an area are you using it in? I ask because those units have a low oxygen sensor which will shut it down if there is not enough oxygen in the space.(kinda prevents that pesky suffocation thing). Otherwise if using it in larger cold spaces, the issue is can be from the smaller tanks. As mentioned above, a larger tank can solve this, because these units have a fairly good input rate, which will cause the smaller tanks to freeze, and lower the propane temperature and evaporation rate, basically runs out of gas until the tank warms back up.
Posted on Sep 26, 2009
    Problem Solver:
  • 4 Answers
Is your Mr. Heater the model that uses two small one pound cylinders or you have the choice to hook it up to a single larger tank? if so, you must use the special filter connected to the Mr. Heater and then your hose to tank.
This happened to me and after I hooked up the filter my problem was fixed.
Ron
Posted on Jan 19, 2009
    New Friend:
Mr Heater has an 800 number. They will tell you how to clean the pilot light. I have a buddy and a big buddy. I had this problem with my big buddy also. If they are stored in a dusty area you need to clean the pilot light.
Posted on Dec 30, 2012
  • Gary Dec 30, 2012
  • 28 Answers
Try just one new cylinder, it will run on just one, to verify a problem with the cylinders. Also it could be the pilot light, sit and watch the pilot light to see if it goes out for some reason. If it does the heater will shutdown automatically, but you already know that.
Posted on Feb 21, 2009
  • 241 Answers
I have one of these and it works great, but it will go out if there is a light breeze that blows out the pilot light. Is that your problem?
  • Crap Iemael
    Crap Iemael Mar 10, 2009
    20 minutes is long enough to get warm!!!
My Kozy World nat gas wall heater has worked beautifully for the past three winters. I cleaned it this morning with canned air, got all the dust off the ceramic plates, blew out the burner inlets, blew out...
Does the pilot light stay lit if you continually depress the control valve?
If the pilot light stays lit as long as you keep the valve depressed, then the problem is the thermocouple is bad. The pilot light makes enough electricity via the thermocouple to hold open the gas valve that feeds the burners. If the thermocouple fails to produce that electricity, the gas valve will shut down and switch off the gas flow to the whole unit.
Mar 05, 2015 | World Heating & Cooling
My 2000 grand prix starts and stays on for about 20 minutes and than shuts off what should I do to fix it
when it dies after twenty minutes check the fuel pressure and volume. the pump may be getting weak and losing pressure or shutting off.
May 26, 2012 | 2000 Pontiac Grand Prix
My universal lp forced air heater model 30 fsa wont stay lit
if its lit by a pilot your thermocouple is bad the purpose of the thermocouple it to keep the gas valve open
Oct 24, 2009 | Reddy HEATER RLP30 30,000-BTU PORTABLE LP...
55" TV keeps shutting off automatically
Green light flashes 5 and then red light flashes 6
Sep 14, 2009 | Sony KDF-E55A20 55 in. LCD Television
GWN10T pilot blows itself out
You must clean the pilot regularly to ensure it burns properly. Use a small can of air for cleaning computers and blow air through the pilot to remove dust and small particles that accumulate in the pilot barrel. Use several burst being that it is 2 years old and has not been blown out. THe manual references cleaning the pilot in the maintenance section.
Mar 29, 2009 | Desa International GWN10T Wall Mounted...
My ventless propane heating stove shuts off by itself
I have a Rinnai Ventless heater hooked up to a 20 lb propane cly with a Moble home type regulator in line, and when I light it the pilot light lights and stays on. When I turn it to the heat position the pilot light go's out and that it!
Jan 28, 2009 | Rinnai Desa Vent-Free Infrared Gas Heater:...
MH 18 B wont stay lit
sounds like you have a limit safety issue, the unit is over heating and kicking out on high limit, or the limit is weak, either way you should look into replacing the limit, hope that helps
Jan 19, 2009 | Mr. Heater (F274825)
The control panel stays lit after cycle ends. it won't shut off and beeps several times during cycle
Hello grumpy 96
Welcome,
You said, the control panel stays lit after cycle ends. it won't shut off and beeps several times during cycle
First try Pressing STOP/CANCEL to clear the display.
If this does not do the trick.
Sounds like we need to try to reset the system!
Huuum At your service!
Lets try this,
Like with an error code.
This can reset the system if it is electronic!
Unplug the appliance and wait a 5 minutes then restart it.
If you can't reach the plug, use the breaker to cut the power for 5 minutes.
It's like rebooting your computer when its acting strange!
Usually it corrects some error problems if they are not serious.
Or they are sometimes just a glitch.
Let me know how it works!
Waiting for your reply!
Please remember to leave a rating when you are done!
Thank You
Huuum
Please remember to leave a rating before you go!
Thank you
Sep 06, 2008 | Whirlpool GEW9250P Electric Dryer
Mr. Heater (F274825) Logo
962 people viewed this question
Top Mr. Heater Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Mack Baxter
Are you a Mr. Heater Heating and Cooling Expert? Answer questions, earn points and help others
