I istalled a new Oem X215 Toner for a Lexmark X215 MFC. The machine still displays ''Toner low'' after installation. Please advise reset options. regards Johann
    Champion:
  • 320 Answers
Not to sure of lexmark however like all printers you have to push on of the keys to reset. you may try lexmark.com hope i was able to help
Posted on Jan 19, 2009
I have a Brother MFC-7440N machine. On 7/22/10
The toner cartridges have a small port on the side that the printer uses to check the toner level. Our 7440N tells us it will soon need a new toner cartridge and will then print another 400 copies. Search YouTube for Brother Toner Cartridge and it will show you how to modify the cartridge by covering up the portholes with tape. Since there is obviously some kind of sensor, you might need to get a can of air and clean out any extra toner. Lastly, the Brother cartridges have "reset gears" which are replaced when the cartridges are refilled. You might have a cartridge which the gears were not replaced on.
Jul 26, 2010 | Brother MFC-7440N Laser Printer
Installed new cartridge and comming up machine won't regognise it saying tonner life end install new cartridge
To reset the sensor after installing a new toner cartridge follow these steps. 1. With unit powered On, open the front cover. 2. Press the “Options” key. Display will show “Replace Drum?” 3. Press “Start” key. 4. Press 1,0 . 5. Display will show “Accepted” for approximately 2 seconds. Then display will change to “Cover Open”. 6. Close cover and see if Toner Life End error message has gone.
Try this. We are Brother authorized.
Apr 15, 2010 | Brother MFC-7420 Laser Printer
Had toner life end message. Replaced toner and drum with oem,machine reset but now just making blank copies. Tried to print internal report that's blank too
2. Press the "Options" key. Display will show "Replace Drum?"
3. Press "Start" key.
4. Press 1,0 .
5. Display will show "Accepted" for approximately 2 seconds. Then display will change to "Cover Open".
Please note that this must be done with a new cartridge so the unit will see that there is toner in the cartridge.
Aug 01, 2009 | Brother IntelliFax-2820 Laser Fax
BROTHER MFC 7820N MACHINE PUT IN NEW DRUM, CHANGE DRUM MESSAGE COMES ON. PUT IN NEW TONER, TONER END OF LIFE MESSAGE COMES ON.
To manually reset the counters, do the following:
  • Open front cover, press "option".
  • Answer Yes (by pressing 1) to the question in the display.
  • Your drum counter is now reseted. Press "option" again.
  • This time, press *, 0, 0.
  • Your toner counter is now reseted too.
(If nothing happens when pressing option, try using the back/clear button instead.)
Jun 15, 2009 | Brother DCP-7020 All-In-One Laser Printer
Toner Problem error message
remove the yellow plastic from the toner thats a protection. check around toner.
Jun 04, 2009 | Brother MFC-8460N All-In-One Printer
Lexmark x215 MFP All in one - prints fine but photocopy and faxes
you should clean the optics situed in the upper place of the machine, retirate the originals glass en clean all the mirrors are inside...
good luck...
Feb 11, 2009 | Lexmark X215 MFP All-In-One Laser Printer
MFC 7420 always say toner low after you change new toner
If you are using the MFC 7420, then you should see the option buttom just next with the LCD. press the option and hit 00. then the message will just go away.
Feb 10, 2009 | Brother MFC 8300 Laser Printer
LEXMARK X215 MFP ERROR MESSAGE
press menu-#-1-9-3-4 with the copier on enter in tech mode. press menu and scroll to new cartrige; select yes. press again menu-#-1-9-3-4 to exit service mode (do not modify other item; your machine will broken!)
good luck !
bogdan_enache89@yahoo.com
Apr 01, 2008 | Office Equipment & Supplies
Toner low, tone life end
There is a gear on the left hand side of the toner to reset the toner count this can cheated be rewinding it. Yes the design is to stop the refillers or at least slow them down a bit. If this fails purchase a new genuine toner but I have seen problems with the switch that resets the toner (Either the spring on the switch has popped off or the main board has failed).
Jan 10, 2008 | Brother MFC 7420 All-In-One Laser Printer
139 people viewed this question
jasbo
jasbo
