Question about HP Pavilion dv9308nr Notebook
Fan issue high speed
After I updated bios to ver. 4 HP dv9308nr
  • 335 Answers
Using an air compressor, blast air into where the hot air comes out of the laptop. This may produce a cloud of dust coming out of the bottom of the laptop. If so, good - you likely had a heat issue caused by insufficient airflow. If still no good, go back to the other bios - usually a new bios offers little enhancement - newer is not always better. Hope this helps!
Posted on Aug 09, 2009
Displays momentarily and asks for CPU fan connection. I have changed 4 fans and still get the same error message and the display goes off.
You're sure you have the cpu fan connected to the correct socket? sounds like it's not connected, or is connected to a different socket. Does the fan turn?
Apr 22, 2015 | Computers & Internet
My fan is stuck on high
Boot into the BIOS (press F2) and look for a "Thermal Setting".
Make sure it's not set to the highest setting. You can adjust it to your preference and make sure to save before you exit.
Apr 11, 2014 | Dell Dimension 8250 PC Desktop
Bios update version for hp a1420n
keep the flash drive in hand. try to install xp. while install it was asking for bios update and ask for press f8 for bios update and insert pen drive and select the path it will automatically update the bios and start installing
Apr 03, 2012 | HP Pavilion a1420n PC Desktop
I have an HP Pavilion a1730n. For the past 5 times I turned it on, I received an error message Error: The System Fan Has Failed!Service PC to prevent damage to the system.PressF2 to Continue I ran HW...
1. Check if fan is spinning. If not, replace with new one or check cables.
2. Check if there are no swapped fan connectors when reconnecting mb cables.
3. Check BIOS update on HP website. Choose your OS here: http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&dlc=en&cc=us&lang=en&product=3339287&
4. Check for a BIOS setting for disabling the fan monitoring.
5. Install a monitoring app which reports fan speeds and temps. See http://www.cpuid.com/softwares/hwmonitor.html
6. Check if CPU fan works.
Mar 14, 2011 | Computers & Internet
Pavilion dv9308nr PC Notebook: hp dv9308nr wont power on all the time... works if...
Due to regular use of the notebook, some static charges tend to stay in the computer, and sometimes results in not allowing the computer to function properly.
Please follow the power drain procedure to confirm the same:
1. Disconnect the AC Adapter.
2. Remove the Battery.
3. Hold the Power button down for 30seconds to 1 minute.
4. Put the Battery in.
5. Reconnect the AC adapter.
6. Turn on the Notebook power.
7. Restart the Notebook.
If the Notebook boots up you may fix the battery back. Try restarting the computer only with the AC power, without the battery & vice-versa. If the issue still persists then I request you to reset the memory modules, as sometimes the memory module connection get loose.
May 17, 2010 | HP Pavilion dv9308nr Notebook
Need bios update for Hannstar J MV-4 94V-0
I am sorry to say but, I think  your prombelm is that the cpu is the wrong size if you want it to run at that pro speed youneed to get a dual core instead a single core and update the bios then lala linda I hope this helps
Dec 23, 2009 | Computers & Internet
Compaq SR5510f,ATI4550HD no display after resume from sleep mode
Have you tried a beefier power supply? Between the processor and the video card you have, you may be right at the minimum to run the machine. Ive had similar problems with machines in the past and they have all been resolved with more powerful power supplies. Step up to a 600 watt or higher supply and see how things go. Good luck.
Sep 19, 2009 | HP COMPAQ Presario SR5510F Athlon 64 X2...
S-ATA Hard Disk not detect
hi Dear,
You have to update your BIOS. If you have intel mother board just go thought their website and download BIOS Flash utility of your particular Board and Update BIOS.
The above fix will surely solved your problem.I had same problem as you and it's now fixed.
May 10, 2009 | Computers & Internet
CPU FAN SPEED IN HP Compaq d530 Small Form Factor Desktop PC
The fan/heat sink on these models get plugged with dust very easily, use an air compressor or can of air to blow the dust out of the heat sink and fan. In extreme cases the thermal paste gets dried out and needs to be re-applied to properly cool the processor.
Dec 01, 2008 | HP Compaq d530 SFF PC Desktop
HP Pavilion dv9308nr Notebook Logo
91 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
