Question about Kenmore 22422 Top Load Washer
Kenmore 80 Series top loader washer overflows
When I turn the washer on it continiously fills and overflows. I'm thinking the water sensor is bad. What do I do??? Can I replace a sensor? HELP!
  • jeffreywalde Jan 19, 2009
    After working on it last night I lifted the control panel. I immediately saw that the vacuum hose from the Water Fill Level was disconnected. I connected that and the problem was solved.
  • Anonymous Mar 03, 2009
    My washer overflowed also. My problem was the vacume hose off also. I put a clamp on it. Seems ok now.
    Sergeant:
    Champion:
  • 318 Answers
It will not be a sensor,,,it will be what is called a "Ball **** valve" and they are pretty cheap to replace.
This same valve is in your toilet tank.
Posted on Jan 19, 2009
Where is the reset button for a kenmore 80 washer wont stop filling water level
If this is a top loader then the vacuum line has come off of the dashpot or the water level switch is broken. UNPLUG the power-Standing in front of the washer, pry off the plastic trim strips on the left and right of the dash (control panel) Now you'll see a screw at the bottom where the strips mounted, remove ans KEEP the screws, now the dash will lift up and fold back, giving access to the parts.
Aug 17, 2014 | Kenmore series 80 Washer Motor 3363737-
How do I check and replace the water level sensor on my Kenmore 80 Series Hvy Dty Washer?
Try eserviceinfo.com/index as per your 80 series. There are various downloads there that may help access the water level sensor which is most likely the problem.
Aug 08, 2014 | Kenmore Washing Machines
My Sears series 80 washer fills till it is overflowing and doesnt shut off water flow, it was overflowing onto floor this morning, it is full to the rim now, and wont drain or do anything when it is turned...
The usual arrangement is there are 2 electrical water inlet valves, one for Hot and 1 for Cold. These valves are turned on by the timer, and remain on until the water level switch turns them on, and allows the washer to then run. It sounds like this water level switch is bad. This switch should be in the panel above the top of the washer, and has a rubber/plastic tube that goes toward the washer drum. It is also possible that the rubber tube is off or blocked. (if the water inlet valve is stuck open, turning the washer off will NOT stop the water).
Good Luck,
Bill
Aug 17, 2012 | Kenmore 23822 Top Load Washer
Kenmore 80 series won't agitate
You will need to check you water level switch. Sound like it is bad or has something clogging it. You can test it like this. Find the tube that runs from the back of the level switch down to the outer tub. Unplug it from the tub. Now turn machine on so that it will start to fill. Now blow pressure into the tube. If it does not cut the water off, you have a bad switch. I would think it's bad. I see them about 5 ir 6 times a week.
Please rate solution if helpful.
Aug 15, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 80 series washer. Agitates immediately and does not fill
it sounds like the water valve is bad,the water valve level(sm. med. lg.)controls the water valce-mike
Jul 17, 2009 | Kenmore 24032\24036 Top Load Washer
I have a series 80 top loader. It filled and
Screws holding the lid switch was broken. Had to replace lid switch.
Jun 11, 2009 | Kenmore 24902 Top Load Washer
Kenmore 80 series washer doesn't stop filling up with water
Almost went and bought a switch until I widened by search for "kenmore washer 80 series overflow" and came up with this:
http://www.fixya.com/support/t1206464-kenmore_80_series_overflow
Turns out that a couple weeks ago, I had a really unbalanced load that probably shook off the tubing. Anyhow, saved me a trip to the supply store AND cost. Thanks to the original poster!
Feb 11, 2009 | Kenmore 22422 Top Load Washer
I have a kenmore washer 80 series that over flowes help please
I had the same problem with a 90 series and there is a small hose connected to the water level knob that had slipped off.
Jan 21, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 80 Series will not fill up with water
if your washer will agitate when set to fill but not fill, then your pressure switch is bad.
also you may want to check and see if you are getting both hot and cold to your washer.
Nov 24, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 80 series overflow
Ok, it sounds either your hose from the water level pressure switch has come off or broke, or the pressure switch itself is bad.
Check the pressure switch hose first.
My tubing came loose and I just duct taped it back on and it works perfectly.
You would need to open your console as shown here:
http://www.applianceblog.com/mainfor...ead.php?t=1081
Pull forward and up on the console and you can hinge it open and hanging from the hinges.
Here is your water level pressure switch:
00092478.jpgWater fill level switch
Here is the pressure switch hose:
00021892.jpgHose for water level pressure switch
Dave
Nov 04, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 22422 Top Load Washer Logo
503 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
