Question about Dishwashers
Door seal leaking
Door seal is leasing
  • 17,129 Answers
Please check on this link for tips: door seal
Posted on Jan 02, 2013
Fisher and Paykel washing machine model WL80T65D leaking water on filling
were is the leak if leaking at door a new door seal check no clothing trapped in door if you run your finger over loose rubber part of seal at bottom and your finger goes through the seal is perished new door seal i am afraid
Dec 10, 2016 | Fisher and Paykel Washing Machines
Tip
Fix water leak
Water leasing from glass part of cargo hatch. Ordered a New weather seal from Ford or lincoln, they take it to a Shop that's specialises in auto glass & repair. They know howto instal? the seal pr?perly. Most dealrs do not .
on May 18, 2016 | Miscellaneous
My dishwasher is leaking from the bottom of the front door. I can't seem to get to the drain filter. Can that be removed? I think there may be a clog in it.
If the leak is from the bottom of the front door than it is most likely the door seal. If the leak is from beneath the unit and appearing to leak out from the front there are many sources for the water.
Check the seal around the door. It may have some residue that has collected prohibiting the seal. The water in the machine actually sits in a tub. The seal on the door prohibits the water leaking as the spray arm rotates.
To test the door seal start the cycle and stop the unit as soon as the machine begins the spray cycle. Open the door and observe that the tub is full but still below the edge. Dry the seal around the door. Place colored paper towels or cloth beneath the door as close to the door seal as possible, Continue with the cycle and observe for water leaks. Stop allow the unit to sit a few seconds open door and observe the seal. You are looking for the location that it is leaking.
If you can confirm that the seal is leaking you can purchase replacement seals, On some models they can be easily replaced.
In my experience I have not seen a filter in the return line. If there is a blocked return hose the unit would not leak. The tub would remain filled after the cycle. There is an overflow switch that prohibits the tub from overfilling if the tub has not emptied between cycles.
Nov 21, 2015 | Dishwashers
Lg p/no 3850dd3006a leaks at door
Every dishwasher door has a door seal. If the dishwasher is leaking water, it might be that the door seal is defective or worn out. Try closing the dishwasher door on a sheet of paper and see if the door seal is making good contact all the way around the door. If not, replace the door seal. If the door seal is good or has been replaced and there is still a leak check the door hinges. If the hinges are bent the door will not close properly and the hinges will need to be replaced
Jun 19, 2014 | LG Dishwashers
AIR CONDITIONING LEAKING FREON
there are at lease a dozen poss leak area's, the most common is the front shaft seal of the AC compressor on the engine.
May 17, 2010 | 2000 Dodge Intrepid
Where th most common place th motor leaks oil
In order from most common to lease:
rear crank seal
valve cover gaskets
oil pan gasket
front crank seal
oil sending unit
head gasket
Jan 20, 2010 | 1993 Mazda Protege
1990 HONDA ACCORD DISTRIBUTOR LEAKING OIL INTERNALLY
Lease check and make sure that you replace with the right seal, that alone should have taken care of this problem. However if the valve cover gasket is loose or bad it will cause oil to leak around distributor are but NOT into distributor. This seal can be easily replaced by loosing 4 10mm bolts on top of valve cover. Contact if you need more help Good luck and thanks for using FIX YA
Mar 26, 2009 | 1990 Honda Accord
Duet 6hw9150p leaks when i put a full load
Is the door seal dirty?
A dirty door seal can cause a leak. Remove and clean any dirt or deposits around the inner door seal with a damp cloth. The door glass seals against the rubber seal; dirt or deposits can prevent a proper seal and cause leaks.
Nov 15, 2008 | Whirlpool Duet GHW9150P Front Load Washer
KitchenAid Dishwasher Leaking from under Door
I had a similar problem with a KUDM25SHWH1 dishwasher. Rubber seal looked fine. I found an incredible tip on another fixi it site. One possible problem iss the pump cover screws may have worked loose and is squirting water directly on the door seal. Man that was it! I saw a couple of looses screws and a small portion of the pump cover gasket showing. I loosened the pump top, reset the gasket tightened it all down...no leaks! The pump I refer to is located directly below the spray arm inside the washer. Easy to get to. Another tip was to look for a split sspray arrm that may spray water directly into the door seal.
Nov 04, 2008 | KitchenAid 24 in. KUDS25 Built-in...
Dishwashers Logo
Top Dishwashers Experts
Owen Barnes
