Question about Sony KDL46EX700 46 in LCD TV
Kdl46ex700 wont power on red light blinks 5 times
  • 11 Answers
SOURCE: KDF-E55A20 red light blinks 5 times
it works!! First i took off the front panel. Just check your manual for instructions, very easy to do. If you do not have a manual just down load one from google.. The instruction are easy to follow. The screw they have you loosen with a alan wrench is attached to the plastic, so you do not have to worry about dropping it inside the tv. Removing the lamp was simple. once out you will notice on either side are two small mesh screens. One of mine was 80% blocked with dust, the other side was only 30-40% covered. I used a vacuum to remove the blockage, i did not want the dust and dirt to go inside the bulb. i then cleaned all around the lamp. Reinstalled, and we are go to go. The kids are happy and i am happier since my wife not be buying a new TV. if this does not work it is time to replace the bulb.
total cost of repair $.00
time required to fix, less than 15 minutes.
Also when my TV was loosing sound and picture and then return. I did turn off my TV, then turned on. I nothiced a red blinking light. Mine flashed 5 times. After some reserch, 5 times is video related, bulb or video board. google red flashing light with the model you have and you will find what all the codes mean.
So if yours is flashing 5 times try the above, it might work for you and it is well worth the time before you call a tech and drops hundreds of dollars.
hope this helps.
Posted on Oct 10, 2008
SOURCE: red standby light light blinking
there is in-line fuse that blowes,caused by the fan vents being restricted (smoking can be a big facter) the vents should vacumed a couple times a month. you will need to have it seviced (parts and labor cost me 270$
Posted on Feb 09, 2009
  • 4234 Answers
SOURCE: high voltage red standby light blinks 7 times what needs replaced
If you actually have a flat panel set, then the "fix" you list is not applicable. Those are for a standard CRT based Sony set. Can you please post the make and model of your unit. We can then look up the diagnostic code and provide you with a proper diagnosis and solution.
Thanks,
Dan
I'm not sure which question will get posted back to you so I have provided the same "solution" in each. Please only update one.
Thanks.
Posted on Mar 06, 2009
SOURCE: tv shuts off spontaneously. red power light blinks.
re: sony flat panel lcd tv mod. # klv s 40a10.
No power. When power button is pressed, nothing happens.
The stand-by at the power supply ( cn6201) measures to be 3.47 v. instead of 5 v. However, when I unplug cn6201 (5 pin connector) I can read 5v. at the power supply.
Any suggestions?
Posted on Aug 29, 2009
  • 16 Answers
SOURCE: Picture & sound suddenly shut off. power light blinks red 5X...5X
http://www.sonya20tvclassaction.com/main/home.sfx MAKE SONY FIX IT
Posted on Dec 03, 2009
My insignia flatscreen wont turn on red light flashes 5 times
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Jul 20, 2016 | Insignia 50 in. Flat-Panel Plasma HDTV
I have a sony rear projection TV model number kfws60s1 that will not turn on I press the on button and green light will flash 5 times then goes red again please help shed light into the problem pleaz
Understanding Sony Television Blinking Codes ' Techlore
www.techlore.com/article/understanding-sony-television-blinking-codes
Now the red light blinks 5 time while watching it. Is there any way of ..... 2006 that willnot power on and the green LED is blinking 6 times. We had a service ...
Sony KDF E55A20 - 5 Flashing Read Lights - TV Forums
www.tv-forums.com/.../TV.../TV.../Sony_KDF_E55A20_-_5_Flashing_...
Mar 17, 2012 - 14 posts - ‎4 authors
We have had a Sony KDF E55A20 since January 2006 and it has been trouble free. ...The TV will switch on fine green power lights. Then after about 20 ... If I turn off and turn on the power light will flash red 5 times. Leave it off ...
Sony TV - How to troubleshoot a red or blinking light ...
? 3:36
https://www.youtube.com/watch?v=BLkyFXv2-i4
Apr 6, 2012 - Uploaded by SonyListens
Sony TV - How to troubleshoot a red or blinking light ... and power lights, these easy steps will help you determine what the... 5:17. Easiest TV repair - How to Fix Power [TV turns off, freezes, ... Get video URL at current time.
Dec 02, 2015 | Sony Televison & Video
What does a blinking red light on a SONY Bravia TV model KDL46EX700 mean?
here is a trouble shooting video that may help http://blog.sony.com/2012/04/redorblinkinglight/comment-page-1/
Jun 04, 2014 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Red light blinks 5 times and wont power on. Is not the bulb
error code is model specific---some it means lamp door issue and others something else.
Oct 31, 2012 | Sony Televison & Video
I have a 4 year old Sony KDF-E42A10 television - the power/standby light blinks red 5 times, pauses, blinks red 5 times again, etc. I have replaced the lamp previously when the light was blinking red 3...
5 blinks means there is a problem with the video board. It could be as simple as unplugging everything, includding power. Wait 3 minutes then plug power only back in. Or it may be a damaged component that requires replacing.
Hope this helps
TV_Doctors
Jan 05, 2011 | Sony Televison & Video
The tv wont turn on
hello 2 blinks on this tv means you have this issue below
PT-44LCX65
2 blinks 5 secs you have your lamp cover open
check for this
hope this helps
Dec 14, 2008 | Panasonic PT-44LCX65 Television
Tv wont turn
The blinking red light at the the front of the television is the "Diagnostic STANDBY/TIMER LED".
This little red light will blink 2, 4, or 5 times and then stay off for three-seconds. And blink again for 2, 4, or 5 times. This cycle repeats. The most common diagnostic code is the 4-blink code.
When the red LED blinks 4-times, it means one of two possible causes:
1) +13V is not supplied on the A-board. Or, 2) IC502 is faulty.
It is best to take this television set to a repair facility and ask that the +13V power supply be repaired.
The copper tracks and integrated circuit pads are very thin and delicate on the KV-24FV12 circuit board, and will easily lift off of the circuit board, if the incorrect desoldering tool is used. Unless one has a good quality PACE vacuum desoldering unit, one should not attempt to repair the television.
Aug 17, 2008 | Sony KV-24FV12 24" TV
Sony LCD television will not power on.
I get 5 blinking red lights for about a minute or so before it powers back down. The Sony TV has a specific light that i presume is supposed to light up when the bulb is out. I'm unsure if this is what it is.
no picture, no sound. tries to boot with green light blinking a few times. then goes to red blinking light, six in all, then waits a few moments, then another 6 blinking red light.
Bulb was already replaced several months ago but we do have the TV on for long periods of time.
Jan 15, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
No picture or sound - Power Save light blinks red 5 times - nothing on the screen
i also have the same problem with the flashing green light for a while then a different red light starts blinking on and off around 5 times....and i replaced my burnt bulb with a new one...still no picture.
Oct 24, 2007 | Sony Grand WEGA KF50WE610 50" Rear...
Sony KDL46EX700 46 in LCD TV Logo
61 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
