Question about Kenmore Refrigerators
Fan next to water pan and compressor is not coming on. compressor is to hot to touch. should fan be on when compressor is on?
Ken more m# 71209100
22yooper
  • 828 Answers
SOURCE: compressor is extremely hot
Compressor will be hot to the touch. You stated the fan was replaced and then said the fan is not cooling. If you replaced the fan and it is now operating, reinstall the panel you removed to install the fan motor. That panel determines proper air circulation to cool the system.
Posted on Jun 15, 2008
rpbuice
  • 161 Answers
SOURCE: kenmore refrigerator compressor clicking
Relay on the compressor bad.
Try unpluging for 30 - 45 min until the compressor has cooled down then plug it back in. If it doesn't start replace the relay. Most service techs carry a universal relay and wiil put the relay on, if it starts, your good to go, if not, then the compressor is bad.
Posted on Dec 17, 2008
Sea Breeze
  • 4654 Answers
SOURCE: Refrigerator Compressor smoke hot to touch
Yes this is a sign of a burn out or start relay or start capacitor defect you made the correct choice. If you need assistance let me know, Sea Breeze
Posted on Jul 02, 2009
  • 66 Answers
SOURCE: fan running compressor not kicking on. canister feels really hot.
check that both wires to compressor are connected, trace them back to solinoid, , if the compressor isnot humming u only have 1 leg of power or it is bad
Posted on May 07, 2010
diodeic
  • 1622 Answers
SOURCE: Fridge no longer stays cold
Insufficient cooling is a fridge repair job that you can do without the help of a professional. Often the fridge has a frost-free failure, or the compressor is faulty but there are many other reasons for a fridge not cooling properly.
Step 1 – Find the Problem
Your first job is to locate the source of the problem. Consider each of the following:
* Gaskets - Make sure the gaskets/seals are not torn and are sealing properly.
* Evaporator fan – Make sure it is working. If it is now working you may have a problem with the fan motor. Check for power to the motor and also examine the fan switches around the door (not all fridges have these switches).
* Air damper – Sometimes the air damper will not open up to allow the cold air from the freezer part to blow into the fridge section.
* Condenser coils – Check to see that the condenser coils don’t have a dust build-up and that the condenser motor is working.
* Compressor – Make sure your compressor is working with on and off clicking noises.
Step 2 – Frost-Free Failure
This is the most common cooling problem in fridges. Expose the evaporator coils by accessing the panel in the freezer section. The coils in the freezer section can sometimes get clogged up with frost. This can stop the evaporator fan motor from blowing cold air around, or cause the fan to hit it and stop, or become noisy. The defrost timer can be a bit tricky to find but it is usually located behind the back bottom corners of the fridge, although they can sometimes be found in the ceiling of the fresh food section, or behind the cold control cover.
Step 3 – Find the Timer
When you find the timer, turn the wheel-like screw slowly with a screwdriver until the fridge shuts off. The refrigerator is now defrosting. If you find that the fridge starts now, you will need to replace the defrost thermostat and the defrost timer.
Step 4 – Volt Test
If the heaters do not come on, use a volt meter to ohm test the defrost heater or volt test for 120 volts to the heater. You can bypass the defrost thermostat if you haven’t got power to the defrost heater to check if the defrost heater will come on. To bypass the thermostat, join the two wires together. Replace the defrost thermostat and the defrost timer if the heater comes on now.
If there is a ticking or squealing noise in the defrost timer, or it seems hot to touch, replace it.
Many fridges have and inline fuse on both sides of the defrost heater. You will need to replace the whole heater if one of those fuses blows. Check these fuses with a volt meter if the defrost heater doesn’t work.
A quick check if you have a cooling problem is to inspect the evaporator coils. If there is a build up of white snow on the coils, this indicates a frost free problem; if there is balled ice on part of the coils with the rest bare, this indicates a system problem, like a problem with the pumping compressor.
Hope this helpout in solving the problem
Posted on Aug 15, 2010
Testimonial: "Good thorough reply! Thanks so much!"
In garage/works perfectly/slow leak coming from an insulated hose that goes directly into the bottom of the freezer itself.
The hose coming from the bottom of the freezer is draining the melted water produced during the automatic defrost cycle. Usually the water is collected in a pan somewhere around the hot compressor motor so the heat can evaporate the water.
The hot copper tube by the compressor is the high pressure tube going to the condenser. The other tube going to the compressor is the return line from the evaporator and, after normal operation, is cold to the touch. It is this cold refrigerant returning to the compressor that cools the motor.
Aug 19, 2015 | Refrigerators
Kbra22kmss fan never stops freezer has frost
adjust the thermal level switch to normal position
Aug 01, 2012 | Refrigerators
Traulsen refrigerator drain pan sizzles as the hot water is being evaporated. what can absorb and/or safely deflect this hot water as it hits the pan?
The problem is not in your drain pan, the problem is why is your drain pan getting hot enough to sizzle water as it hits it?
Are there hot spots on the cabinet? That would be a sign that the condenser grill is not able to transfer heat out of the sealed unit compartment. Which could mean a dirty condenser grill or back panel. Are items stored behind the unit that is affecting air flow? Is the compressor fan working and pushing air across the condenser grill and compressor.
Jul 28, 2011 | Refrigerators
Not cooling good
There is a fan down by the compressor that aids in cooling compressor and getting rid of the water that comes out of the freezer during defrost cycle. I am sure that you took the paper cover off the back of the unit on the lower back side so your unit might not have a fan. Now lets look at the fan inside the freezer is it running can you hear it when you open the door? Does the compressor make a clicking sound as it is hot to touch and trying to come on? get back with me ok ken
Jan 31, 2010 | Roper RT21AKXKQ Top Freezer Refrigerator
Amana 20 - 20 years old. Freezer thawing - refreezing. Fan running very hot in the compressor arae at the bottom. Drip pan full of water - never saw that before.
IT SOUNDS LIKE YOU HAVE DEFINITE ISSUE WITH YOUR COMPRESSOR, IT MAY BE CONSTANTLY RUNNING OR RUNNING TOO OFTEN, THIS WOULD CAUSE THE LARGE AMOUNT OF HEAT COMING FORM THE BOTTOM. IF YOUR COMPRESSOR IS RUNNING TOO MUCH YOU WILL ALSO GET AN EXCESS AMOUNT OF WATER EVAPORATING DUE TO CONDENSATION ON THE EVAPORATOR COILS THEREFORE FILLING UP YOUR DRAIN PAN THAT MUCH QUICKER. YOUR FRIDGES COMPRESSOR MAY BE ON THE WAY OUT BUT YOUR FRIDGE SOUNDS LIKE IT'S WORKING THE WAY IT SHOULD BE.HOPE THIS HELPS
THANKS
Oct 12, 2009 | Amana Freezers
My refrigerator is leaking water underneath it. the ice maker is not hooked up
Is it leaking water INSIDE the fridge at the bottom - if so that is an indication of a clogged defrost drain - if you have a drip cup in your refrigerator, that connects to a tube at the back of your fridge, to carry the water from the defrost cycle down the drip pan at the bottom.
If you see water OUTSIDE your unit, the only explanation is an overflowing drip pan ! Water from the defrost cycle drains and drips on a pan that sits on the compressor or besides it - the hot air from the compressor will cause water in the pan to evaporate quickly - either through a fan or when the pan is placed directly above compressor. If your model has a fan at the bottom next to compressor, that blows the hot air on it, check to see if it's working when compressor cycle is on.
There is no reason for that drip pan to overflow otherwise, it is quite big enough, and the water from the defrost cycle is usually around 2 ounces and should evaporate quickly.
Oct 09, 2009 | Whirlpool Refrigerators
Water is leaking under fridge. The pan keeps filling up and overflowing
On some models, when the water dispenser is clogged the water will bypass to the drain pan. The water from the defrosted freezer also drips to the pan but it shouldn't fill it under normal conditions. Try to see where the water is coming from.
Sep 20, 2009 | GE Refrigerators
Drain pan overflowing, evaporator not working
Usually the pan sits on the compressor and the heat from the compressor should evaporate it - unless you have abnormally excessive defrost cycles - if you notice your defrost cycle coming on too frequently then your coils are getting frost up quickly (poor door gasket seals, too frequent openings, etc can cause this).
If the pan is not on the compressor it is usually besides it, look for a fan down there - that one should be blowing the compressor's hot air there - if fan is not working this might be your problem.
Sep 17, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
AC blows cold while moving, and gets warmer while I'm stopped
There are two fans behind the radiator. One is suppose to begin running when the AC is turned on. The other is to cool the radiator when it gets too warm. Raise the hood with the engine running and AC "on"and see if at least one fan is running.
May 04, 2009 | 1995 Buick LeSabre
Compressor is extremely hot
Jun 14, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Refrigerators Logo
20 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
