Question about Wintergreen CMV CT-723A 17" LCD Monitor
First post is misleading...sorry..not one pin bent bb.but none were bent (typo) sorry
Whenever I turn on the monitor i get no video images. I do get the OSD (On Screen Display) Menu. Which shows me the Resolution/s of which the Pc video card is sending. If i switch resolutions in the Control Panel it shows that it has been Changed But still no video images. I checked to see if any pins were bent ..but.. NONE of them are. I tried this Monitor on numerous Computers with the same result/s. I am stumped. It is a lovely monitor.
  • 432 Answers
It could be the monitors invertor board has gone bad. Call a local computer shop and tell them you need a new invertor board for your monitor and see what they say. Write me back and let me know.
Posted on Jun 25, 2007
My acer desktop turns on and beeps with no picture
>make sure your video cable is plugged in on both sides.
>make sure your video cable has no bent or damaged pins.
>try a different video cable
>connect a different monitor that you know for sure works
>take YOUR monitor and connect it to a different computer Does it work? If no, the monitor is bad. If yes, either your video cable is bad or the video card in your computer has failed.
If none of the above work, I hang out at www.suggest-a-fix.com
which is a free computer help forum. Post in the Hardware section and I (or someone else) will be along. This forum is not set up for complicated problems that require repeated, in-depth communication.
Jul 21, 2014 | Acer America Acer AX1920-UR10P...
My monitor's backlight flickers whenever switched on....please help me.
You need to do two things. First, switch out your monitor input cord (the blue one) and get a new one. If you don't have a new one, then unplug both ends and make sure none of the pins are bent or broken. Then plug and screw in completly. If that doesnt work, google your monitors name and drivers, and redownload the drive for it. It should take you through a repair proccess which should fix it
Sep 05, 2011 | Samsung SyncMaster 740N 17" LCD Monitor
I need to find the VGA controller for the Dell 2005FPW monitor
you can use on all vga cards(you dont need any special controler), this monitor has a USB hub
and its is detected normaly on winxp or above, and the vga cards detect the monitor auto.
i give you the monitor specs, take form website
Display Type LCD display / TFT active matrix
  • Built-in Devices USB hub
  • Width 18.6 in
  • Depth 9 in
  • Height 15.3 in
  • Weight 17.6 lbs
  • Enclosure Color Midnight gray
  • Image
    • Display (projector) image aspect ratio 16:10
    • Image brightness 300 cd/m2
    • Image Contrast Ratio 600:1
    • Max horizontal view angle +88 / -88
    • Max vertical view angle +88 / -88
    Display
    • Diagonal Size 20.1 in
    • Viewable Size 20.1 in
    • Dot Pitch / Pixel Pitch 0.258 mm
    • Max Resolution 1680 x 1050 / 60 Hz
    • Color Support 24-bit (16.7 million colors)
    • Max Sync Rate (V x H) 75 Hz x 83 KHz
    • Video Bandwidth 146 MHz
    • Response Time 12 ms
    • Controls / Adjustments Zoom , Clock , Phase , Contrast , Sharpness , Brightness , Saturation , H/V position , Color balance
    • Display Positions Adjustments Height
    • OSD Languages French , German , English , Spanish , Japanese
    • Display Screen Coating Anti-glare , Hard coating
    • Video Output None
    • Signal Input DVI-D, VGA
    • Features Picture by picture , Picture in picture
    Video Input
    • Analog Video Signal RGB , S-Video , Composite video
    • Digital Video Standard Digital Visual Interface (DVI)
    Audio Output
    • Type None
    Input Device
    • Type None
    Expansion / Connectivity
    • Interfaces 1 x VGA - 15 pin HD D-Sub (HD-15) , 1 x DVI-D - 24 pin digital DVI , 1 x Composite video input - RCA , 1 x S-video input - 4 pin mini-DIN , 4 x Hi-Speed USB downstream - 4 pin USB Type A , 1 x Hi-Speed USB upstream - 4 pin USB Type B
    Miscellaneous
    • Flat Panel Mount Interface 100 x 100 mm
    • Features Security lock slot (cable lock sold separately)
    • Compliant Standards CE , CCC , MIC , NOM , PSB , BSMI , GOST , SASO , NEMKO , TUV S , C-Tick , TUV GS , EN55022 , TCO '99 , EN 60950 , ICES-003 , TUV Ergo , UL 60950 , IEC 60950 , EN 61000-3-2 , EN 61000-3-3 , FCC Part 15 B , VCCI Class B ITE
    Power
    • Form Factor External
    • Voltage Required AC 120/230 V
    • Power Consumption Operational 55 Watt
    • Power Consumption Stand by / Sleep 3 Watt
    Environmental Parameters
    • Min operating temperature 41 °F
    • Max operating temperature 95 °F
    • Operating humidity range 10 - 80%
    Sustainability
    • EPA Energy Star Compliant Yes
    Feb 13, 2010 | Dell UltraSharp 2005FPW 20.1" LCD Monitor
    Screen turns green. another monitor works fine on same computer
    check the pins on the monitor cable to be sure none of them are bent. If the pins look fine then the screen is bad.
    Aug 27, 2009 | Computers & Internet
    The monitor is green the color is not
    Check the pins out on the monitor and make sure they are straight, even and none of them are bent cause if the cable goes in with bent pins that would cause weird colors to come up on the screen.
    Also make sure its connected to the video card properly as well and snug. If that still doesn't fix it, try another known working monitor on the computer and if that works then the lcd is bad on your original monitor, if you still get green even with a new monitor then its a problem with your video card.
    Jun 24, 2009 | HP Pavilion F1703 17" LCD Monitor
    Samsun15'' monitor (2003 model) crt monitor appearing fully green
    Sounds like the red guns aren't firing. Check the pins on the VGA cable to make sure that none are bent. Also plug in a different video card (or plug the monitor in to a different computer). If the monitor is fine, then you need to replace the video card.
    If they aren't, you're looking at a fairly expensive repair.
    Feb 15, 2009 | Samsung Computers & Internet
    Why is my monitor screen changing colours. Goes green and blue. Also wavers making it very hard to look at.
    Check the cable connections on the back of the computer and make sure none of the pins are bent on the cable , also check the same connection into the monitor and that none of those pins are bent either , it may be as simple as buying a new cable.
    Cheers
    Aug 19, 2008 | Acer Computers & Internet
    No Video
    Did you take the monitor out and put it back in before the pin was bent? Or did it just all of a sudden blank out.
    Jun 24, 2007 | Wintergreen CMV CT-723A 17" LCD Monitor
    Screen is not clear ( red color is not there)
    Check the cable for kinks at either end. VGA cables that are bent at a 90degree angle for lon periods of time become damaged. The next step is to remove cable from computer and check the pins for damage. A bent pin from accidental force from inserting and seating connector can catch a pin and contact with another pin or ground. If none of these conditions exist, consider monitor replacement. I would try another monitor to rule out the video card as well.
    Apr 28, 2007 | LG Studioworks 552V 15" CRT Monitor
    Wintergreen CMV CT-723A 17" LCD Monitor Logo
    63 people viewed this question
    Top Wintergreen Computers & Internet Experts
    Alun Cox
    k24674
    Are you a Wintergreen Computer and Internet Expert? Answer questions, earn points and help others
