We have a Sennheiser Diversity Receiver ew 100 and when the wireless mic is off the noise line is on the AF and makes alot of staic until you turn the mic on then it stops. How do I fix this?
Hello! Turn the unit on and push set on the receiver then push arrows until tune comes up, raise or lower frequency of the channel until the noise does not appear in the meter, push set to store settings then push power button to return to normal. Then take the mic and turn it on, push set then push arrow until tune comes up then push set and then set the channel the same way you set the receiver. P.S.. The receiver is locking on to a rouge frequency that is what causes the noise. Went you turn the mic on the receiver locks on to the mic and the noise stops.
Hope this helps you to fix the problem.
Steve
Posted on Jan 21, 2009
How do i sync my mic to my receiveri have a ew 100 g3 and after some kids were playing with it, I can't get any sound
Pressing the sync button whilst holding the mic close to the IR unit on the receiver should sync things back up. If this has already been done things to try next are as follows.
RF Mute. Press and release the power button. RF Mute should be displayed. Press the roccker switch and select RF mute OFF, press the rocker switch again.
Check in the advanced menu that the pilot tone is on on the handheld AND the receiver.
Jan 23, 2014 | Sennheiser Evolution G2 100 Series UHF...
What could be wrong?
Put it in MONO mode.
You can also make a cable where the TIP and RING are wired together....
Oct 09, 2017 | Sennheiser ew 300 IEM G3 In-Ear Wireless...
Wireless mic not sending signal
need more information.
what model?
handheld or beltpack? microphone or instrument?
check transmitter and receiver are set to same frequency.
does a different transmitter work with the receiver?
does the receiver show the transmitter is functioning (ie receiving rf) but not receiving audio signal (af)?
Nov 07, 2013 | Sennheiser Audio Players & Recorders
Issue more complicated than originally thought!
This isn't a solution. But after I've gotten into my microphone with the same issue using a torx screwdriver I found that I (Electrical Engineer) don't have the proper equipment to fix the issue. Roughly 100 dollars (Flat rate) and a send off to Sennheiser is your best bet.
May 22, 2012 | Sennheiser 100/500 G2 Series Wireless...
How do you troubleshoot phasing issues with the Sennheiser 135 G3 wireless microphone?
Phasing issues? Not sure what you mean by phasing. Phasing would be the phase of the audio pressure on the mic versus the electrical phase out of the receiver. DO NOT EXPECT the phase to be stable in any way as there is a communication and data conversion in the loop. The phase will be highly audio frequency dependent as well.
May 14, 2011 | Sennheiser EW 135 G3 Microphone
I feel that the 'normal' background hiss is a problem that I would like to minimize with the sennheiser IEM 300. I'm currently using the IE 4 ear phones. Would a different/better earset with maybe a...
No, that will not help. The his is a function of the receiver NOT receiving a signal from the transmitter as they apparently do NOT have a "squelch" circuit to mute the receiver noise when no signal is being received. The noise level when no signal is received is pretty high and apparently the volume control is not enough to reduce the hiss.
To solve this, LEAVE the transmitter ON and make yourself a switch at the receiver. DO this using one of those little in line lamp switches that fit on zip cord. Make one on a short length of zip cor with mating connectors to fit the received jack and the headphone plug. Don't worry about unshielded wire as the impedance is very low. Then you use this switch to mute the headphones when you want to. There are other switch types you can use, I am just suggesting what might be readily available to you.
Sennheiser SHOULD have include a mute switch on their unit as turning the power off on the receiver would be a pain. They could have used a volume control with switch to kill the audio line out... simple solution... oversight on their part.
Mar 25, 2011 | Sennheiser ew 300 IEM G3 In-Ear Wireless...
Some Headphones have an inherent hiss noise when they are connected to my wireless sennheiser EK 300 IEM G3 receiver. It seems to be a problem particularly with high-end IEMs which are highly sensitive...
Hiss is a problem of statistical noise in electronic devices due to the laws of physics plus circuit design.
One thing to do is to improve the signal to noise ratio (SNR) by properly setting gains. It is POSSIBLE that the IEM's you are using are too low impedance for the receivers resulting in you having to use excessive gain at the receiver. Your receiver gain control should not have to be above 60% of the way up. If you are above that, the ear buds are probably lower impedance than the receiver is designed for... and remember the manufacturer will LIE on the capability of the thing they are trying to sell.
The receiver is speced at 32 ohm drive... IF your ear buds are less than that impedance, they are NOT suitable. Conversely if they are too high, thaat will ALSO cause you to turn up the receiver gain too much and result in poor SNR.
You want to make sure the transmitter is being driven at line level so receivers get adequate input audio so gain doesn't have to be run too high.
Jan 04, 2011 | Sennheiser ew 300 IEM G3 In-Ear Wireless...
On/off button fell off Sennheiser wireless mic
This is quite common with G2's, and really annoying!
If you are lucky, 50% of the time the red button is pushed inside the mic.
You need to remove the bottom section:
- open the battery compartment
- there should be 3 star-bit screws around the outside (remove)
- pull the bottom of the mic off
If the red button is not inside, they are available as a spare part from Sennheiser dealers.
Be carefull when putting the mic back together, it needs to line up correctly with the internal guides, forcing the base back on could damage the ribbon cable. when the line-up is correct it slides on very easily.
Best of luck.
PTB
Jul 06, 2009 | Sennheiser 100/500 G2 Series Wireless...
Frequency clash
There are different frequencies available and being used in each location.
To get a basic idea of which frequencies are available in your area, try this online tool:
http://www.sennheiserusa.com/findfrequency/
or use the literature provided with the Sennheiser gear (usually a useful chart comes with the wireless gear).
Also, remember that your transmitting frequencies need to be spaced apart a minimum of .400 MHz (or 400 kHz).
Frequency selection shouldn't cause feedback problems though. If you select a frequency for a mic that a local TV station is already using to broadcast, it will cause RF Interference (Radio Frequency). You'll probably hear static noises, pops, or since your Sennheiser has a Squelch feature, just drop-outs in audio.
So first consult the available charts to find a set of frequencies that should be available in your area. Then, if one of your mics is experiencing such an issue, try moving it .400 MHz to the nearest unused frequency and see if the RFI goes away. Repeat until the RFI no longer manifests.
Jan 30, 2009 | Sennheiser 100/500 G2 Series Wireless...
232 people viewed this question
 Grubhead
Grubhead
