Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Replaced dlp chip and now flashing yellow lamp light and tv won't turn on? any advice?
Tv is 5 years old.. i know i should replace but would rather fix. I replaced the bulb successfully 6 months ago and ordered a DLP chip to fix an occurring "white dot" problem. Followed the instructional video exact, and when turned on after replacing with new chip i had a blank lit screen (dark bluish) and static noise. so i took it apart again thinking i had not seated the chip properly... next time i turned on i got a flashing yellow lamp light and unit will not power on. Any suggestions?
SOURCE: just replaced dlp lamp
From what I remember, when you turn on the tv, use the remote and when it asks if you replaced lamp say yes.
Posted on Jul 28, 2008
  • 1030 Answers
SOURCE: blinking green light and clicking noise AFTER bulb replacement
do this. press and hold device and menu button on set for 5 seconds. this will retrieve a 2 digit error code .. the led will flash the first digit and pause the flash second digit. This unit is known to have capacitor problems on the power board. getting to these capacitors involves taking alot apart. let me know error codes and we can continue troubleshooting
Posted on Jan 15, 2009
ladywinn
  • 5138 Answers
SOURCE: new lamp replaced but yellow lamp light is flashing
Go to this Website they will list all Parts/boards and everything you need for this TV
WEBSITE:
Encompass Parts Distrubtion 1-800-638-3328
Posted on Jan 16, 2010
  • 20 Answers
SOURCE: I have a Mitsubishi WD-62627
this sounds silly but I had the same problem . due to heat and wear and tear. Make sure the vented air holes are not blocked by dust and the back of the TV is in a well ventilated area where air can circulate.You can use a paint brush and compressed air blowing the debri away from the inside circuitry.
Posted on Sep 03, 2011
  • 8457 Answers
SOURCE: just paid to replace the
Mitsubishi that the one,who u should contact.Talk to them make some kind of deal with them to help u to do a repairing or replace the tv Light Engine Projection Block.That the tv problems,this problems a design flaw on the tv Light Projection Egine Block the IC they put in that causes of this white spots are showing up will continue showing up more and more white dots.It will not stops.
Posted on Sep 04, 2011
Replaced DLP chip now yellow Lamp Light on the front of my Mitsubishi TV is flashing.
Look for the reset button behind the cover door in the center of the TV. It may only be a tiny hole that a paper clip will fit in. Turn off the TV, straighten a paper clip and insert it until you feel the reset button. Bush slightly and hold it in and then power up the TV. That should stop the lamp light indicator from flashing. Make sure the lamp is fully seated and the cover is firmly in place.
Aug 08, 2017 | Mitsubishi Televison & Video
Why would lamp go bad after replacing chip?
Did you have to remove the lamp during the chip replacement? If so, did you physically touch the glass of the lamp with your skin? Oils from the skin can cause lamp failures due to hot spots that can form on the glass.
Jul 07, 2015 | Toshiba 65HM167 65" Projection Television
I have a 65737 Model Mitsubishi DLP TV. I changed out the DMD formatter Board and DLP Chip Yesterday and now the Lamp will not come on. It worked fine until I changed the Board because it had Vertic
Hello, make sure all the covers are on correctly, then recheck all the wiring connections, unplug each one and inspect them for a bent pin. Let me know....tks
Jan 03, 2015 | Mitsubishi WD65737 65" DLP TV
Replaced dlp chip
Kelly,
The yellow blinking light generally means that the lamp cover is open. You may have accidentally jarred the lamp while changing the DMD chip, and the lamp safety switch is not engaging. The first thing I would try would be to re-install the lamp and make sure the cover is on correctly. Let us know if that solves the problems. Thanks.
Feb 10, 2014 | Mitsubishi WD-73733 73" HDTV
I recently replaced the TY-LA1000 lamp but I'm getting a yellow flashing light that goes on every 5 secs.I made sure that it was installed correctly and tried resetting the timer by pressing + and - o
Yellow flashing light? Did you get any picture? Bet, not!
It means: your lamp door interlock is not engaged: did you forget to turn the locking knob? Did you install lamp compartment door? That might be the only issue. Lamp timer blinks 'red", while TV works normally. Reset the timer, it's gone, along with annoying message. Yellow means: interlock or thermal protection is off. Try to repeat lamp installation procedure. then, you'll find out your mistake. don't need to remove the lamp. It would be "red", if lamp won't fire up.
good luck,
Alex.
Dec 06, 2011 | Panasonic Televison & Video
Just paid to replace the lamp 2 weeks ago in our mitsubishi 73 dlp 1080p tv purchased a 5 year in home contract with Tweeter Sevice net 1/2008 lamp fixed and picture is once again great but now the 73...
Sep 03, 2011 | Mitsubishi WD-73833 73" HDTV
I have a Sony KDF-E50A10 Grand WEGA LCD. The picture cuts in and out and the green standby light flashes. One expert said the STKs need to be replaced??? How can I do this...please advise in detail.
Replace your lamp. Your DLP set does not have Stk ic's in it. I don't know what expert told you that but I can assure you he has never worked on a TV. You can purchase the lamp from www.dlplamps.com
Jan 18, 2011 | Sony Grand WEGA KDF-55XS955 55" Rear...
Please Help. I have a 56" DLP Samsung and the lights just flash
Sounds like the lamp might be burned out. The Lamp should be replaced every couple years. If they are not replaced they will eventually burn out. Replacement is not that difficult and just requires a screwdriver. The lamp is located at the back of the DLP TV on the left side. The lamp can be purchased online from Samsung for about $130 dollars. You might be able to find a aftermarket one for less. Just use your telivision's model number located on the right side of the TV on sticker to cross reference the bulb that is needed or there might be a sticker on the back at the lamp housing that has the lamp part number. And make sure to spend the extra money and get the Lamp with the housing together. You can buy just the lamp for cheaper but that will require you to remove the old lamp from the housing and they are fragile. Much easier installation with the housing/lamp combo.
Jan 12, 2010 | Samsung DLP HL-P5663W 56" TV
Ic chips?? light engine??
the color wheel has gone out. good luck finding a new one. I just had to have my whole unit replaced because parts could not be located.
Jan 31, 2008 | LG 52SX4D 52" HDTV
DLP TV Samsung HLP4674w No Picture
If you hear a ticking and or buzzing sound as it is trying to start up then most likely the replacement lamp is bad. Take it out and reseat it one more time to see what happens. The noise you hear is the ballast attempting to fire the lamp up.
Nov 30, 2007 | Samsung HLP4674W 46" Rear Projection HDTV
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
277 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
