Question about Kenmore 63942 Dryer
I put the clothes in and set the dials an nothing happens
I checked the power supply it is fine I am wondering if it is the switch on the door. I can use some help.. help!!!
  • 979 Answers
Check the wiring in the back and to where the contacts are made. There will be a little box where the ends are connected. Then check the thermal fuse which probably is located under the top of the dryer. It may be bad. The door switch could be bad but I doubt it. Good luck and let me know how it turns out.
Posted on Jan 20, 2009
Electrolux 617 Dryer control board unresponsive- dial changes the settings, but the start light just blinks and won't start dryer when I press. Pressing other buttons, nothing happens. No error code.
if the belt broke it won't start,that isn't a model number?open the door,look around the opening where you put the clothes in and you should see the model number.
Nov 29, 2017 | Electrolux Dryers
My white knight tumble dryer wont start
Nothing works or drum fails to turn (tumble dryers)
Ensure that the power supply to the dryer is switched on, the timer is set to the desired drying time and the door is correctly closed. If you have a condenser model, also check that the bottle is empty and is fully pushed into the machine.
http://www.whiteknightrange.co.uk/whiteknight/faq.html
The first thing to establish when troubleshooting the clothes dryer is whether the dryer will start or not. If it won't, start by checking the outlet and the circuit breaker. Is the dryer plugged in or has it tripped the circuit breaker? If the breaker has been tripped, flip it back on and try the dryer again. The drum should turn without a problem.
If both plug and breaker are fine, you'll need to inspect the door switch as you continue to troubleshoot the tumble dryer. When you close the door on the dryer, a plastic peg should click and operate the switch which allows the dryer to work. The peg might be bent or broken, in which case it won't connect with the switch. You can try to straighten the peg, but if it's broken, you'll need to replace it. If the peg is fine, the switch has probably failed and will need to be replaced.
http://www.doityourself.com/stry/troubleshooting-a-clothes-dryer-drum-doesnt-tumble#b#ixzz3FOOQgtAT
Oct 06, 2014 | White Knight Press Genuine Tumble Dryer...
I have a roper washer 5 years old and it won't drain or turn on now it was working fine yesterday ive unplugged replugged pulled out all the clothes checked power supply and hoses what now?
I looked up your model number. You particular machine allows for wash with the lid open. You nothing happens. On that case I would check the motor capacitor.
Nov 13, 2011 | Roper RAS8445KQ Top Load Washer
Dryer won't start in Frigidaire FGX831CS0 stackable. Assumed it was a bad start switch because honey bunny had broken the knob off and was using a pliers to start it but have replaced that and still nada,...
Check the door switch. Turn on dryer as you push in on switch where the door catch is and see if it starts . when closed the pin may not be pushing it in.
Mike
Jun 05, 2017 | Frigidaire FGX831CS Top Load Stacked...
Will not turn on
A dryer can not start for many reasons...
This tip that I wrote will help you to figure out what is happening...
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Apr 05, 2010 | Dryers
Kenmore dryer does not turon on
CHECK THE FOLLOWING---
1. No power to the dryer
Make sure there's power getting to the dryer. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power with a voltmeter or by plugging something else in.
2. Door switch / Door switch actuator lever
The dryer would not start with a broken door switch. Replace the door switch if found defective.
Most dryers have a door switch actuator lever - when you close a dryer door, it presses against the lever, which actuates the door switch. If the lever is broken, the switch would not activate and the dryer would not start. Replace the lever, if broken.
Note: Door switch actuator lever usually comes with the door switch assembly and it is recommended to get the whole assembly since there is almost no price difference between the door switch assembly and just the lever. Check your model for more details.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
4. Timer/control
Replace if defective (note: uncommon problem).
May 31, 2009 | Kenmore Dryers
Washer stopped after wash cycle
The lid switch is the culprit. Push down on the lid it should start. It needs to be adjusted . the tab on the lid is not activating the switch. Try triming the door bumpers.
Apr 10, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Door locked & nothing happens Whirlpool duet wfw8300sw01
hi there,
sounds like the machine has no power at all.
there was no need to break the lock.
unplug the machine
take off the console
check connections from the touchpad to the CCU board
make sure nothing is corroded, burned, bent or pinched
unplug and replug the wiring harness
plug the machine back in and try it again.
let me know if this works.
Sep 26, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Frigidaire front loader washing machine won't spin...
just had my frigidaire fronter loader repaired,,try the door switch ...mines wouldnt spin clothes were soaked did everything else fine... what may have happen is when the spin cycle is ready to do its part it double checks to see if door is locked but with a bad switch it sends the wrong signal and computer this the door is open so it shuts off....well gl mines is running got lots of laundry to do,.,,,hope this helps
May 29, 2008 | Frigidaire GLTF2940ES Front Load Washer
Kenmore 63942 Dryer Logo
27 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
